DIY PMG Generators cheap and easy to make whit in a day!
  • #91
    I am not selling them, but if I get access to a bunch I would be happy to offer them to anyone who needed them.
    I called my friend and he said he thinks these magnets will lift 300-400 lbs each, they came out of a devise for lifting 2000lb sheets of steel with an overhead crane.
    • #92
      @Brian
      Is there any difference between the DVD and the download?
      Is it just: one is in physical form and the other is just downloaded, but all the content is the same for both.
      Regular service Signature:
      • #93
        Originally posted by Savvypro View Post
        @Brian
        Energy Creator, Home build PMG Gnerators / alternators
        The movie Energy-Creator High efficiency DIY-generators the Movie
        cheers
        Brian
        • #94
          Brian,
          Just bought it, download started running steady at about 4.5mbps, but dropped a bit. Either way, I should have it in about an hour.
          Question: could your techniques be used to produce an AC generator which outputs high voltage or high frequency?
          update: Just started watching the videos. Would the following resin do?
          Low Cost Resins - CFS Fibreglass Supplies
          • #95
            Brian,
            • #96
              • #97
                Brian,
                hello Savvypro
                this one for the rotor: LR35 Low Cost Polyester Resin 5kg
                Low Cost Resins, Low Cost Re-Blended Resin, - CFS Fibreglass Supplies
                and I think this one for the stator? 5kg pack Chemical & Heat Resistant
                Special Purpose Resins, Chemical & Heat Resistant, - CFS Fibreglass Supplies
                • #98
                  Yea sure, always like to try new things!
                  Still reading your post to find out what it is?
                  Brian
                  • #99
                    Hi Brian,
                    I have just thrown a new design concept out there for a HHO pump that is a hybrid between a standard alternator and a tesla pump:
                    The main difference is that the coil is the rotor and hard wired to the discs via a full bridge rectifier.
                    If you are interested in having a look and have any comments I would love to hear them.
                    Rob
                    • Originally posted by Savvypro View Post
                      Brian,
                      I'm still recovering from the shock of the simplicity of the design and how they are made.
                      http://www.energy-creator.com
                      • The algae bit is my "signature", that is automatically added to the end of every post by the forum software.
                        Brian, algae are really easy to care for and grow, especially Spirulina. I've been thinking about putting together a DVD on how to do it cheaply and easily. I may copy your format, when I put all the videos that I have taken over the past 6 months together.
                        One thing I did notice about your movie was the copyright. You may have issues if you need copyright law to back you up.
                        PM me and I'll explain what I mean.
                          • @Brian,
                            What camera did you use to record the videos?
                              @Brian,
                              • forgot, take a camera what records on a SD card!
                                Brian
