DIY PMG Generators cheap and easy to make whit in a day!
  • #46
    Originally posted by kcarring View Post
    I purchased the DVD and reviewed the clips today. It is excellent. From materials found around town + magnets & magnet wire you can build a powerful generator
    from these plans. The stator uses a very novel approach I've never seen. I will be building one. I see no reason that this generator would not outperform cheap chinese offerings, and could be built for much less $.
    Brian has taken the time to really make this a concise educational package, worth every cent. The films are edited very well, it would probably take a several day seminar to see everything you see in this film, and surely that would cost more than $40!
    Interestingly, as well, Brian purposely sets out to not only show you how to do it right, but to demonstrate how varying the plan will effect the build. In other words, he demonstrates the pitfalls; which will serve to save people a lot of money due to screwups / bad modifications.
    Congratulations Brian, you have put out an excellent product, at an excellent price.
    It's a rare thing to find an e-book / DVD that actually gets you building a renewable energy device that delivers results, this is one of few, and the only one I have personally seen on this forum!
    Well worth the money if you are interested in wind, water or human powered generators.
    Hi
    good to hear comments like that
    Still waiting for the slowest UPS around 20 days had gone and still counting for a small dvd to be delivered Hope Brian is reading this
    and keep his promise to me lol
    Dont know if I can use my dc magverter 24.06.11 avi to spin the gen WISHFUL THINKING
    totoalas
    • #47
      • #48
        Hi Brian, thanks for your quick response TRUE TO YOUR WORDS IN LESS THAN A DAY LOL
        That solves the silly questions made on my projects
        If no Solar , then wind , if no wind then rain,
        If nothing else there then USE YOUR IMAGINATION DREAM TO BUILD
        TOTOALAS
        • #49
          I'm beginning to think there is probably very little in the way of rotary devices that Brian can't make out of PVC LOL.
          @Energy Creator
          What do you think of these, they are the most affordable i have found, I think Neo's went up in price in the last year?!
          Brain said "So we recommend magnets of 15mm X 8mm whit a pulling power of 6,7kg instead. (6.7 kilograms = 14.7709716 pounds)"
          For sale at:
          Neodymium Disc Magnets 1/2 in x 1/4 in Rare Earth N42
          Neodymium Disc Magnets 0.5 inch Diameter x 0.25 inch Thick Rare Earth Disc Magnet N42
          Strong Neodymium Magnet Grade N42
          Magnetized through the Thickness.
          Br Max: 13200 gauss
          .25 inches = 6.35 millimeters
          .5 inches = 12.7 millimeters
          Approximate Pulling force: over 14 lbs.
          Cost: $0.65 ea.
          Over 500 cost: $0.60 ea.
          Over 900 cost: $0.59 ea.
          ISO Certified, top notch quality and superior performance guaranteed.
          Nickel-Copper-Nickel triple layer coated for durability and excellent protection against corrosion
          Nickel + Copper + Nickel 3-layer coating vs. Epoxy single layer coating
          • #50
            [QUOTE=kcarring;177440]I'm beginning to think there is probably very little in the way of rotary devices that Brian can't make out of PVC LOL.
            Hy Kyle totally 100% agree on brians pvc precision casing out of ordinary tools and compact winding
            Will try to encapsulate 4 berilium oxide ring magnets from microwave oven
            and use the 3 phase winding
            thanks Brian
            totoalas
            • #51
              [QUOTE=totoalas;177447]
              thanks Brian
              totoalas
              Normally, I would say don't bother making any kind of generator out of anything, without high powered magnets (Neo's) but given Brian's method, the cost is so low, that it actually is worth a shot.
              I would use very fine wire such that you can keep the coil height to a minimum, OR, plan on it charging a 6V instead of a 12V, and modify accordingly. Another thing you could do, totoalas is PLAN on using a voltage doubler with AC caps, such that while it comes at the cost of current; at least you will have your useful output. The main thing you do not want to do is make a stator that does not get penetrated by whatever field your magnets output.
              • #52
                [QUOTE=kcarring;177608]
                Thanks Kyle good idea
                I have 50 pieces of 84 uf MGE 400 v ac caps now can be use on this project
                totoalas
                • #53
                  New Energy Creator Site
                  The new Energy Creator site is on line!
                  Energy Creator, Home build PMG Gnerators / alternators
                  not ready for 100% but a good inpresion how it's gone be
                  hoop you all like it
                  Brian
                  • #54
                    Output information of the generators
                    Hello Brian here
                    Some people did ask me for some output information of the generators.
                    I tested the generators under 4 differed conditions!
                    Got the statistics and the movies of generator 1, 1.2 and 2 on my site now.
                    The rest follows soon.
                    regards brian
                    • #55
                      Brian,
                      could you share with us what software & hardware your using
                      to produce the graphs that your sharing with us please ?
                      Thank you.
                      • #56
                        I can also echo K.carring's view. Well done Brian!
                        Some questions:
                        1. Can the disc magnets be replaced with block magnets. Apart from the increased cost being a disadvantage. Will they provide more power if they are of the same grade because of the surface area they cover?
                        2. If the windings were made commercially they would be tighter and more efficient. Have you approached any companies to improve your design / manufacturing processes?
                        3. The only thing I thought that was missing was a location where some of the parts that you used can be brought. For example was it fiber glass resin you used for the stator? Your terminology is slightly foreign to me.
                        4. Please consider making a video with the generator self running using:
                        CT6850, Impact Wrench, Cordless, 18 Volt, Slide-on Battery, 1/2" Drive (U.S.)
                        It starts running off the batteries.
                        Once started, then switch to self power.
                        Your sales will increase 10 fold!
                        • #57
                          Some questions:
                          Another way Im thinking of rotating the winding just like in a vacuum machine rotor
                          put the winding on the shaft and place neodyne disc magnets on top of the coils one winding acts as motor winding and the rest for pick up to generate power
                          WISHFUL THINKING
                          totoalas
                          • #58
                            You can increase power considerably with this design by wrapping the coil with a thin plastic layer ( such as the plastic "roll up sleds" ) then winding an iron wire over the top ( mechanics wire - fence wire - iron wire on rolls). this will help complete the magnetic path through the coils. It will induce a small amount of drag because you are magnetizing and demagnetizing sections of the iron wire but it is minimal in comparison to the output increase.
                            I've built a multitude of radial air core alternators, dual rotor axial flux machines and various silicon core machines. (I've designed and built literally thousands of them ). The best performers are the ones where the magnetic flux path is completed.
                            Brian's design is creatively unique with the novice and not so well equipped builder in mind. I applaud you for your creative approach to a simple alternator ! Well done sir !
                            • #59
                              Need some clarification
                              I'd like to buy this video but I have several question first.
                              If I understand correctly this generator can be built with ordinary parts, tools and skills. Correct?
                              What makes this generator different from a car alternator? I understand the attraction of DYI but right now I'm more interested in output or work performed.
                              Can this generator be used also as a motor?
                              I'd also be interested in watts input vs watts output. I saw the video with the drill but am wondering how much input produces how much output.
                              And is the video and parts and diagram description enough for a novice such as myself to build it.
                              I was also wondering what applications this generator can be used in.
                              Thanks, I appreciate any answers you care to provide.
                              -Lyn
                              • #60
                                hello
                                Hello We. Te. People
                                A Old p4 duo core , onboard everything. Studio MX2004 30days trial version. And word for spelling control.?
                                And tutorials from Learn web design and development online free at DevelopPHP this guy is the best!
                                Why?
                                Hello Soundiceuk
                                There is no iron in the generators so you can put as much magnets in the rotor as you want, disk or blocks dos not matter.
                                How more magnetic energy how higher the output of the generator, but maybe you should use a water cooling for the generator.
                                I am still working on the site, have to do the links. I know
                                The polyether whit a high chemical resistance what sticks to PVC is often the same polyether they use for swimming pools.
                                I tried to self power a power drill with the generator, but I am sorry it is not a over unity devise.
                                But I placed a new movie on my movie page ( Generator-3 power drill test
