V grove
Dear Asad,
Thanks for the guidance. Its better idea to make trials 1st with Water than with WMO n than with PP. Definitely I will proceed in the manner.
Surely your idea of placing big pipe over output pipe is good. I have done the same arrangement but it is horizantal. Hope it will work.
There are few points hope you can answer me.
A) I made U type of grove instead of V. The grove is about 2mm on bottom plate and male part is on top plate of same width but slightly more in height about 2.5mm. Hope this should nat be any problem.
B) I have fixed one Brass tube closed from bottom to fix Thermo couple on top plate of reactor. I hope I don't need tha same for Refluxor chamber.
C) About WMO I tried to search WMO with local automobile garages thay say it is the waste black color Engine Oil removed from Automobile Engines. Is it the same WMO. What they are asking for it os quite costly, about half the price of Diesel.
D) is it necessary to fix a Valve in outlet pipe. As local water Valve won't work at that temp. If necessary can I fix it after cooling pipe as temp will be low there.
Thanks again for the help.
Wish me good luck
Wish me good luck
signed an Joint-venture Agreement with a Getleman from Dubai to make a reactor for extracting Styrene Monomer from waste plastic .
