First Run
Hi
I had my first run yesterday and this is what i got.
(Kindly see the album at the end)
First I had started without a Thermo-couple, which has been rectified today so it was continuously heating no control.
At first Gas started coming through the Bubbler for around 2 hours. I could hear the Liquid in the Reflux splashing back down every few seconds like a cycle. Splash silence, splash. My Pipes did not heat I think there must have been a block in Th Reflux/pipe (the reflux was un-insulated and not heated) . After this time Gas stopped coming from the Bubbler. If there was a block why would gas come i was wondering? Anyway i switched of teh heat when gas reapeared in the Bubbler but not as much as previously. Applied the eat agin and this time I heard Liquid dripping into my Condensor/Seperator.
This lasted half an hour+.
When the reflux quitened along with no Gas in the Bubbler I switched it off.
net result: 1/1/2 Liters of Fuel from 4 kg of feedstock of mixed plastic.
Questions?
1.The Density of the fuel is 0.75 does that make it petrol/ gasoline?
The Fuel was not completley clear, and a viscous dark layer formed at the bottom after settling (is this carbon?)
2. I burned the excess gas from the Bubbler, how could I connect this to my existing Gas cylinder burner that i was using? Or would I need a completly seperate burner?
3. When I opened the retort i found White powdery waxy substance in the pipeline, what was this,I remember reading about some time ago but could not find it in the post its so long now. Kindly guide me.
4. Even when I thought teh process was working well towards the end my pipes/ Condensor hardly got hot, does this indicate blockage?
5. My reflux welding started leaking vapour was seen coming out of it slightly. (just been repaired) but again could this have resulted from backpressure from a block, if I install a Saftey pressure gauge should I place it on top of the Retort? Sorry i know these questions have been asked before.
5. Most importantly the fuel produced and the Gas smell very strong and obnoxious is this a sign of HCI, How can i neutralise this? apart from not using PVC which is impossible with domestic waste in India. A secondary Bubbler can help with the gas but why is the fuel smelling so strong?
6. how do I know if my Catalysts has done its job of aiding cracking? I used a Reflux column containing wire wool at the bottom and broken baked Red Clay at the top?
Apologies for so many questions which I know have been answered along the Forum some where and I am continuously rereading the entire thread taking notes everytime .
Thank you
Hi
Questions?
Thank you
