The Physics of the Primary State of Matter
  • I get error like this when accessing video:
    "Currently BBC iPlayer TV programmes are available to play in the UK only, but all BBC iPlayer Radio programmes are available to you. Why?"
    The only time I got purple is when I spark gapping the 240 Volts part of the secondary, the purple do not show up at 110 Volts part. I guess the voltage and current play important role in this. Look forward for your diagram .
    BTW, I found rare book of grebenikov which mention low resonant of geometry here:
    There also many book in english here:
    Mатериалите се предоставят с образователна цел и не са тествани!
    • must be just the uk in the program, they talk of a moon around saturn that have a water geever! the moon is making water!
      paper and ion gas
      YouTube - 555/MOSFET Driving Flyback Transformer
      also branden a great friend put me on to the thread!
      My heat generating pyramid - picture
      I think the great pyramids had a electrats on the outside!!
      how to get the purple flash:
      Have the energy going down the inside of a tube or down a coil with a rap of coil on the outside.The outside coil goes to ground with no other connections. Have a spark gap after the inside coil tube going to ground with a neon bulb atfer the gap.(the gap is the electrat to top to bottom)
      once you have the purple light flashing with the gap, cut the power them tap the top and bottom of the electrat gap this will light big tube and the neon.
      will do a diagram to clean all this up!
      take care all
      • Why
        I am still wondering why my neon flashes repeatedly after one coil collapse. I will be utilizing a comment on youtube that after the neons stop flashing purple, change their polarity and they start again. I'm thinking the coil collapse enters a reverberation if it can, which it can, if a neon is new. Got some tests in mind with neons and diodes to see if pulses are ac or dc radiant but need more neons. Hope I'm not hijacking your thread richard. Or if I am, that it's ok ;-)
        • stop talking like you hijacking its perfect, is the energy echoing ben,
          The way i see it is its time future and past meeting,
          ye Im back to time again
          • Ben, after hearing you talk .. I should dig a hole and use concert to cover myself up with. hijacking .. What's that mean?
            These postings are an archive of research material.
            There's relationships in them with PP or junk SP to know what is faulty and what is a close match.
            I think Richard has it right, echo.. I was thinking that, but like water.
            There are videos of tests filming water hammer knocking back and forth in
            the pipe, very violent, in the water hammer thread.
            You force a large "happening" .. it does not slam shut all at once
            A sphere shape "happening" is different in that it does not keep knocking around, In&Out, once each way.
            sucahyo, I starting reading the grebenikov document but I started loosing focus in the middle about the nuts and bolts. I have to go do bed now.
            There's new info I had not read before in it
            and now me sleeping --->
              Thank you
              reading now
              I work in the hospital ye in operating theatre we have a machine that gives hv pulses in a beem of argone gas to stop bleeding, scare you get on the skin form the beem of light is honeycomb
              I love nature
              • Originally posted by Vortex View Post
                We must use matter to build a device that interfaces with the stressfields.
                Putting matter into / under stress (potential) allows tapping into, ah, that energy-matter ..
                It's different. A spark isn't the same energy that travels down a copper wire.
                It must change into "glowing" energy state to cross the air, thus we can see it.
                Randy
                1. Electrat is the only device we have up to now!
                2. The HV flow video is the answer to this one! Two glowing states HV Flow video.
                NiceOne Randy
                • Originally posted by Bodkins View Post
                  NiceOne Randy
                  I agree, but then also disagree. There are known forces with NAMES.
                  The source of the force , is unexplained. The reason of the LARGE unexpected
                  force is unknown, but is known and named. These should be looked at
                  with head cocked to one side and reexamined with PP/Etc perspective.
                  When a force X turns into force 3X, 100X, 1000X, etc. that's coming from
                  somewhere, the stressfields/etc !!
                  These forces played upon themselves or another in osculation is what KEELY
                  did. It isn't directly tapping into the lowest level "big" power source but uses
                  the upper levels/layers just below the state of matter.
                  What one generally sees is geometry plays a role or can be used to enhance
                  these "forces".
                  An example is the Magnus Effect which uses geometry and motion to multiple the power from a
                  moving fluid by a factor of 10 over and above normal fluid mechanics.
                  It's the exceptions to the rules that are of interest here, the exceptions point
                  towards a stressfield interactions do that not?
                  They allow force to bubble up which normally would not exist.
                  Knowing a stress field exists is a problem, but not the problem. Knowing the
                  "how" to tickle it (without using a very large hammer) to get it to give up a
                  force which can be extracted for power is the problem.
                  just
                  • Here is more to read :
                    Kiril BurrisovChukanov writing.
                    I think the document title is interesting enough:
                    - Final Quantum Revelation - General Theory of World Organization
                    - General Quantum Mechanics - The Great Reform of Science
                    - The Unveiled Secrets of the Primary Substance:
                    Chapter III - Critics of the Standard Model
                    Chapter IV - Energy, Gravity – some fundamental answers
                    - Universe - That’s Simple!
                    Many illustration and so many equation.
                    Skim reading Henry Moray "Harnessing Cosmic Energy", unseen energy can easily be harvested with radioactive.
                    Just watching the video. The flashes that you guys made are bright! The toilet paper also blown in more significant way than mine. I guess mine has too little current.
                    • Originally posted by barbosi View Post
                      How about a break from the stressfields for a while and enjoy The Fifth Element ?
                      What I mean let the fields flow freely, if I don't offend anyone...
                      Bottom line,
                      Will read this soon thank you!!!
                      • sucahyo, this was a good find. orgon meter
                        Detectors of any kind, for any thing, no matter how little energy they detect is important.
                        We do not now know that a tiny (itty-bitty) force could not be the window
                        or "stress field" into a very large extraction of energy.
                        I finished the grebenikov .. I have to say I was lost. I didn't understand what was meant by some of the words and therefore didn't get a handle or direct feel about the flow of energy in the device.
                        I understood it was anti-gravity and some bugs have this built in ..
                        I did get that geometry was very important and electrostatic was involved.
                        What did strike me was this something that could be tested.
                        (I have to retype it .. can not copy/paste from the document)
                        "Put a shower head on a tap and turn on cold water. Slowly bring your palm to a beam of falling drops aside: most people feel heat at this moment. In fact, this is ECS increased by motion of new elements of the "multilayer net": falling water drops and gaps between them. After training in a kitchen or in a bathroom, feel stronger ECS at fountains or waterfalls. Even if atmosphere is not falling, remote rain creates a strong ECS filed influencing at a distance of many kilometers. Remember how we want to sleep before rain even in a closed room: ECS cannot be screened."
                        What is a multilayer net and what is ECS again?
                        I was looking for other things that could be tested. I thought there was another thing but I can not recall now what it was.
                        @Bodkins
                        "scare you get on the skin form the beam of light is honeycomb" ..
                        Very ODD, What is that telling us?
                        Ask someone why it is a honeycomb, what is their answer?
                        Oh.. I started a new link. Thank sucahyo for the source to
                        New Energy Technologies the MAGAZINE
                        Start with the last issue and work upwards ...
                        I've not even taken the time to read all the CONTENTS I posted yet.
                        I have all the issues downloaded.
                        • They dont now!!!!!why its honeycomb
                          its natures blue prints
                          • guys, check your PM
                            • N.e.t. #1 200%
                              Source page 48 issue #23
                              open electric capacitorspatent of 1877.). The factor of output increase reached 200%.
                                Thats what Im doing with the next electrat, was talking with braden and we had the idea too put little pin on the Hv ^ input when cooking slowy.
                                Also on the lines of Geometrey like pyramids and pulsing it is key!
