The Physics of the Primary State of Matter
  • Randy YouTube - true electric arc
    dont now about that one
    but this one
    YouTube - 230 kV Vacrupter Switch Failure
    if you stop it at 18 seconds you can see the two parts of the spark!
    also think the YouTube - 850 KV
    has the two parts in it already.
    • My undersatanding of the wind
      So we Got wind off the flyback, the flyback is stressed so this pushers the air stress,and if the planet shoots out stress like the flyback and this stress meets another stress like cold/hot, wet/dry air you get wind!
      • no static magnet position to make electret
        Originally posted by Bodkins View Post
        ....I dont now what to do with a magnet when this is baking ...
        Me neither.
        I just wanted to point out the parallels between magnet making and electret making.
        Namely the application of an unchanging (i.e. static) maximum (stress)field (i.e. max. field strength, minimum distance and constant direction) taking care to keep the field present during cooling.
        Thinking further about the parallels between the two processes, I see it like this:
        One needs a static magnetic field (= moving current) for making magnets and this makes me believe that one needs a static electric (HV) field (= moving 'three guesses') for making electret.
        To put it another way: I don't see the benefit of a static magnet for electret making.
        Naturally if somebody knows better, I'm looking forward to learning.
        • I dont think a magnet is static Marxist
          • I agree. I don't think that either.
            I meant a magnet in a fixed position (as opposed to a 'moving magnet') ...
            It's difficult (for me) to talk about this stuff in a precise way.
            • I find that too my friend,Im working on a way of putting this stuff on paper!
              • Somehow I find this thread the closest to post this:
                YouTube - New John Chang video
                I apologise in advance to anyone thinking of me hijacking the thread.
                • Originally posted by amigo View Post
                  Hemoglobin is Iron based and if the above was the case then the Nature made a terrible f*cking mistake to incorporate it into all oxygen breathing vertebrates.
                  As far as I could remember I was taught that Copper pots should not be used to cook in as they are toxic in a way, while Iron pots are fine, due to the above mentioned connection to blood.
                  My understanding is that when Schauberger wrote the above quoted about Copper and Iron he was referring to soil (ground) and the method of plowing fields, as he had designed and built a copper plow which was beneficial to the soil itself.
                  He has different explanation for that. He use silver plated copper for egg container. I'll try to find the closest answer from Schauberger as possible. Diamagnetic is also the property of ormus, which as you know has healing property and levitation.
                  Forgive the very long post. This answer a couple of question at one go.
                  If you don't have time, just read the bold part
                  Alexandersson - Living Water - Viktor Schauberger and the Secrets of Natural Energy (1990).pdf
                  page 81 (76)
                  Schauberger strove to duplicate Nature's implosion through the design of his 'implosion machines', which he claimed were unique in that they needed no fuel.
                  In the case of a power generator, nine times as much energy in the form of fuel is required in the conversion to electricity or other kind of output. This system of plundering the resources of the earth, which has resulted in the murderous scramble for the earth's energy, is based upon the explosion motor, which operates centrifugallv. The implosion motor, however, is centripetally operated. It produces its own driving source through the diamagnetic use of water and air. It does not require any other fuel such as coal, oil, uranium or energy derived from atom splitting, since it can produce its own energy (atomic power) by biological means in unlimited amounts - almost without cost. It has been overlooked that energy is also bipolar and appears freely as part of the motion of the earth's medium - water and air, which have the effect of reviving energy. The type of energy can be either bio-electrical, that is destructive, or biomagnetic, ie. levitative.
                  Implosion and Diamagnetism
                  Schauberger tried to explain the natural phenomena that gave rise to the understanding of implosion power and its associated 'diamagnetism',16 and their opposites in the following way. Let us begin with the most elementary aspect: the basic elements hydrogen and oxygen, the chief components of water and air, oppose each other in the following manner Hydrogen (H) becomes active by cooling and combines with the passive oxygen (O) to produce a concentrated form of energy of lift and growth, 'biological magnetism'. This lifting power of diamagnetism operates in opposition to gravitation. In the case of hydrogen gas, which was used to fill the Zeppelins, the lifting force amounted to 2km per second. Above all the ' play of nature' turns on these two forces. Thus the biological magnetic or levitation tendency of the plant as it is attracted towards the light, influences its growth, while simultaneously increasing its weight and consequently the force of gravity. As iron and steel are attracted bv magnetism so the elements hydrogen and oxygen, essential for sustaining life, as also are the highly valuable trace elements - the 'chromosomes' of water and air - are attracted by diamagnetism. It is the opposite to electricity. Stale water is reactivated and increased in volume through biological magnetism.
                  Oxygen (O) is activated by heat (every oven burns better by adding oxygen!) and combines with the then passive hydrogen (H) to produce a dispersing energy which results in decomposition. This occurs with every explosion. It is produced whenever pressure, heating and explosion are used and is particularly found in weapon design and atom splitting, whether for war or peaceful purposes. Heat is the lowest form of water decomposing energy. As the molecules are redistributed, heat is generated (the predominating H combines with O, instead of O with H, as would be necessary for organic growth), then the water (as in the sap of plants and blood) becomes stale, lacking in higher quality matter (which burns up due to the excess of oxygen). Decomposition sets in, cancer develops and at the same time the decomposing element traces and pathogenic bacteria multiply, overcoming the natural restorative processes of higher forms of organic life.
                  The molecular build-up of cancer growth, causing fever, is stimulated by impulses of a physical, chemical and a psychic nature. All energy (heat, electricity, magnetism, or diamagnetism) is the result of bi-polar action, originating in mutual attraction. The whole universe is composed of living organisms, which with little effort can be forced into a straight-jacket by the human operation of using hammer, tongs, hatchet, screws or explosives, and with even less effort can be made to produce in abundance. It is not pressure, but attraction that the 'eternal woman' employs; so we can talk of negative pressure, or the negative electricity of diamagnetism.
                  The invention of the 'suction spiral' and the 'suction turbine' is based on the same principle as the twisting action of rivers, which is caused by the movement and rotation of the earth. In the river, the water is thrown hither and thither, spins, reels on itself, as the rope in the hands of the ropemaker. It forms whirlpools, eddies, spiral-forming currents, where the water rotates on its own axis and condenses. Vacuums are formed, creating a negative pressure, which affect the breathing of the water through suction, and this generates a cool air stream. This is the 'falling temperature phenomenon', which physics has not considered to be mechanically produced. It is, however, produced in the suction turbine, which rediscovers an ancient principle.
                  In other words, they have been compressed back into their 4th dimensional origins, creating what Viktor referred to as a 'void' in the physical matrix, which in turn increases the inward suction of air to fill it. This is no inert, empty vacuity, however, but a living vacuum of huge potential, for all it now contains is pure neutronic energy, which in the light of the above should be the most primordial of life-cohering essences and therefore originate from higher, more sublimely dynamic realms such as the 5th. Freed of its function as the magnetic 'cement' of the now dematerialised particles, it interacts and energises the atomic nuclei of its physical diamagnetic counterpart, the copper components of the flying saucer, endowing them with antigravitational properties that contribute towards the craft's ascent.
                  Coats & Schauberger - Living Energies - Viktor Schaubergers Brilliant Work With Natural Energy Explained (2001).pdf
                  page 255 (261)
                  Type A: Comprises bio-magnetism and bioelectricity, the former more commonly referred to as diamagnetism. It is the form of electro-magnetism that energises and animates all living organisms. Diamagnetic elements are copper, bismuth and hydrogen.
                  Type B: Comprises ferro-magnetism, usually just called magnetism, and electricity, which here we shall refer to as ferro-electricity to give both terms a common root. This type of electromagnetism is the one commonly in use in our technical world in electric motors and dynamos for the generation of electricity. Ferromagnetic elements are iron, cobalt and nickel.
                  page 279 (285)
                  Coats & Schauberger - Nature as teacher - New principles in the working of nature (1998).pdf
                  page 114 (121)
                  Professor Ernst Ferdinand Sauerbruch discovered the organic low-pressure chamber that lies between the pleura and the surface of the lungs, which functions as a biological vacuum and enables the inhalation of breathable matter and the resistance-free expansion of the lungs. Professor Sauerbruch was not aware, however, that this phenomenon is only possible through planetary motion. In this process positive atmospheric pressure is countered by a negative pressure, variable at will, whose power increases by the square of the in-winding rotational velocity.
                  Moreover, if water is centrifuged, positive pressure increases in precisely the same measure, resulting in the lateral ejection of bipolar sediments. The naturalesque way, however, is to centripetalise them along the central axis. Otherwise a bioelectric nuclear axis surrounded by a decadent magnetic field will develop (as with electromagnets) at the same time as a diamagnetic, oxygenrepelling, but nonetheless iron-attracting magnetic function. In this case a pole-reversal occurs, i.e. an atomic excess pressure evolves in the longitudinal axis of a watercourse, which makes all respiration and insuction of diffuse, atmospheric oxygen impossible. The water inevitably suffocates, and with further direct or indirect over-illumination it decomposes due to the increasingly aggressive concentration of oxygen.
                  Coats & Schauberger - The Energy Evolution - Harnessing Free Energy from Nature (2000).pdf
                  page 184(197)
                  Moreover; science uses paramagnetic material (steel, etc.), which with an increase in heat (heat is the lowest form of electricity) gives birth to additional decomposive energy (electricity). As a result of this finding experiments were also made to rotate water in meander-forms made of diamagnetic material (copper, bronze, etc.). Even diamagnetic wood can be used. Out of these experiments arose the doublemembrane, which with increasing radius automatically increases the flow-through velocity, if the angle of the alternately disposed slip-surfaces is flattened out towards the periphery.
                  Implosion - Viktor Schauberger and the Path of Natural Energy (1985).pdf
                  page 15 (17)
                  Now then, when an organism that has been attacked by cancer supplied with diamagnetically charged, high grade water containing up to 90% energized hydro-carbons (and correspondingly less used up oxygen) the negatively charged diamagnetic reduction elements bind and emulsify the excess oxygen and inactivate it by cooling it. As a result, the fever recedes and that, which Prof. Warburg calls the Vital Force, is restored. It concentrates in new cells, forcing them to proliferate steadily, arrests the development of the adjoining cancerous cells, and finally destroys them. Cancer, which is the result of fire (i.e., over heating and combustion) can be cured only by diamagnetic negatively charged high grade water, as established already in 1935.
                  But although the production of such water would have benefitted millions of people, opposition supported by the medical authorities prevented the construction of water purification plants.
                  Bens purple flasher setup!
                  Can you post a bigger one? It is a bit hard to read.
                  • YouTube - EV Gray Understanding
                    Im trying
                    • Originally posted by barbosi View Post
                      Holy Smokes .
                      NO ONE SHOULD MISS SEEING THIS VIDEO.
                      There is more to this universe than our current physics tells us
                      and that is what we are looking for.
                      • In The Sky with Diamonds
                        B-I-N-G-O
                        ah, wow. .. I'm starting to understand what you are saying Richard
                        and it feels good to know that my questions were not in vain.
                        MAKE THAT GREEN LIGHT DANCE
                        (Dancing to "Green Light" by John Legend)
                        and dang, before your video this below meant NOTHING.. I
                        had no idea why you were trying to tell me TWO TWO ...
                        I thought you might be rehearsing for a double-mint commercial
                        now I think I know what you meant here also.
                        but this one
                        Bodkins is Smokin'
                        GREEN LIGHTS .. In The Sky with Diamonds
                        Amazing Northern Lights Time Lapse
                        Aurora (Northern Lights)
                        • Randy tonight Im going in a plane to see the northern lights, a plane just flighing around then home. Will post a video if I get any good shots,
                            y
                            If you feel like posting post it,
                            this thread will end up Very boring if poeple that see it dont tell
                              See, I still haven't read any of those books (on my To-do list) else I would've remembered it. I did find references to Silver coated Copper elsewhere and so I see now that it's not really pure Copper. Plus Silver adds bactericide effect to the mix.
                              I'll really have to look into reading all those titles...one of these weekends, sigh.
                              • New chemical element
                                From Dale Pond's website:
                                A major research institution (MRI) has recently announced the discovery of the heaviest chemical element yet known to science. The new element has been tentatively named Governmentium.
                                Governmentium has 1 neutron, 12 assistant neutrons, 75 deputy neutrons, and 224 assistant deputy neutrons, giving it an atomic mass of 312. These 312 particles are held together by forces called morons, which are surrounded by vast quantities of lepton-like particles called peons.
                                Since governmentium has no electrons, it is inert. However, it can be detected as it impedes every reaction with which it comes into contact. A minute amount of governmentium causes one reaction to take over four days to complete when it would normally take less than a second.
                                Governmentium has a normal half-life of three years; it does not decay, but instead undergoes a reorganization in which a portion of the assistant neutrons and deputy neutrons exchange places. In fact, governmentium's mass will actually increase over time, since each reorganization will cause some morons to become neutrons, forming isodopes.
                                This characteristic of moron-promotion leads some scientists to speculate that governmentium is formed whenever morons reach a certain quantity in concentration. This hypothetical quantity is referred to as Critical Morass.
