Question - Radiant Energy Battery charging using an aerial
What happend to this topic?
Hello, I've reading and collecting information about zero point energy and thanksfully I've found this site on google.
I wonder what happend with this experiment?
Is there anybody out there?
I will apreciate if you post any possitive o negattive facts about charging a 12V battery with a "cocked" coaxial cable electret
Thanks in advance
Regards from Uruguay, South America
Keep it green
Peace out
After a long searching once upon a time I found something which may be a great help for you. There are Tesla european patents explaining more detailed his radiant energy and the main point is that his magnifying transmitter is also depicted as a source of radiant energy.
12 volt radiant energy battery charger
Give this circuit a try. The harvested hi frequency,hi voltage AC EMF coming off the coil is rectified to DC and stored in a capacitor. Lets call that energy radiant because 12 volts just powers the magnet to spin over the coil.
That harvested energy is run through a mosfet thyristor and a neon lite into a 12 volt battery in need of a charge.
Build it yourself and watch it work. Very simple.
RADIANT ENERGY 12 VOLT BATTERY CHARGING - YouTube
Actually it exists just not that easy to get much power.
Check it out genuine WWI ZPE techOriginally posted by amigo View PostHi John,
welcome aboard
I believe there's a misconception regarding aerials and capturing RE, if you are refering to the Tesla's patent that is. He actually had a source of aetheric stream - his Transformer that is.
From my limited understanding, Radiant Energy (RE) is not accessible on its own or else we'd be home free long ago
RE is "entangled" with normal electrons and in order to get to it one must fraction that connection. Tesla did that through abrupt discharges on his magnetic gap disrupter, feeding the purified aetheric stream to his "special primary" or to any variaty of beamtubes he constructed for focusing and directing the aetheric stream. The aerial (the plate in the patent) actually received that directed stream and converts it to electron current usable on a load.
There was a discussion among some minds of that time about utilizing pure dielectric fields (heavily charged capacitor plates) to tap into aether flows, but because there was no material capable of interrupting the aetheric currents it was never practically resolved.
Not sure if this helped or not. Perhaps you want to look into works of Thomas Henry Moray who did use aerials as well...though no one had much success replicating those either.
and currently I've heard of at least one company working on making sheets of microscopic diodes for harvesting energy for high end projects.
Charging 48V batteries with Spark Gap Tesla Coil???
HELLO ALL!Originally posted by amigo View PostHi John,
welcome aboard
Anyone have any experience charging dead or used batteries with Tesla Coils? I've got a few 100kV Hamilton Drills High Voltage Tesla Coils with a positive and negative brass end (spark gap).
I've got some temporary success on smaller batteries, but I think I need to make a few conductors and run the current through them before charging the battery...ANY SUGGESTIONS?!?!!?!
Thanks ALL!
I have built and successfully used the antenna system to collect Back EMF off a coil operating on AC. Check my video for proof/Originally posted by amigo View PostThink about it this way John:
If it worked, wouldn't we be seeing tons of aerials collecting the Atmospheric energy that's out there, being used to power homes, charge batteries etc.
So far I haven't seen anything like this works. But that does not negate the fact that there is a huge dielectric potential waiting to be harnessed from our Atmosphere. The altitude differences give hundreds and thousands of volts/potential that could possibly be tapped into.
The aerials idea appears to have merit, but again has anyone really produced any useful energy from such a setup?
I don't understand how that proves anything, it is running off a battery.Originally posted by magnetman12003 View PostI have built and successfully used the antenna system to collect Back EMF off a coil operating on AC. Check my video for proof/
https://www.youtube.com/watch?v=KLL1C_RDTMQ
Can you explain further?
