Let's start exercising your brains here...see how good they are.
Hello again, and by posting the following sketches I do not mean at all, that Part G does not work...and, as a matter of fact the IMG below will prove it is rather much simple to use it, instead of going through this concept...However, the point is that both will work as well...
[IMG]
[/IMG]
Let's start exercising your brains...even if they are Ant's Brains...
On top is just a 16 elements commutator like Figuera...say same small motor, same single brush splitting the Positive, and mainly same way as Figuera had elements joint together...
And so, we could mount this concept into a round single steel solid rod...or square laminated...as you prefer.
The Brush rotation on the Upper (Green Cycle Arrow) generates a sequential turning On of the Green Series Connected Coils from tap 1 to tap 8...
While, in that same upper cycle the Gold Series Connected Coils would be disconnecting as the brush keeps turning in the same direction...
The red lines at commutator means the connections between terminals-elements (same exact as Figuera did)
The Red intermittent lines between taps means the Highly Compressed Repulse Field Center line between active coils of the same polarization.
This method is more accurate on field's steps as there are no Spatial Gaps...
And it is very obvious that the fluctuations take place in a longer and dictated by coils on-off extending all along the whole core, except to the End Coils of each "Primary"...which stay on at all times.
It is also obvious that the "Secondary" will wrap around all these interlaced coils, taking the traveling distance of the red intermittent line...meaning from 1-16 to 8-9 taps
We could apply this same method to a Toroid Core...and add Two Sets of Overlapped-Interlaced Coils...
What do you all think?
Originally posted by Ufopolitics
[IMG]
[/IMG]Let's start exercising your brains...even if they are Ant's Brains...
