Trying to explain...
Hello Hanon1492,
I will try my best to explain the way I see it works...HOWEVER, I have been watching how much you "approve" and "praise" over Lorentz Forces, and the "Entertainment" that has been put out for years related to the two differences in what I see as plain and simple the same exact experiment...:
Einstein proposed the "difference" between :
1-Moving the Magnet In-Out from the Static Coil.
2- Moving Coil In-Out from the Static Magnet.
Which (the way I see this) is the most stupid way to get people confused on such simple experiment...but what it really amazes me is how people believe in this so non sense reasoning for so long.
Both 1 & 2 are EXACTLY the same thing...and the result of course would be the same thing...whether one of the bodies stays static while the second moves...is just a way to "entertain" a confusion based on "relativistic views".
To start with Hendrik Lorentz completely discarded the slightest possibility of a Magnetic Field Polarity Spin AND Magnetic Field Divergence.
So, if You, Hanon1492, agree with Lorentz Forces, it means you agree that magnetic Field does not spin...therefore, You would NEVER, EVER, understand Part G Full Operation.
So, if You really want to understand Part G, for real, you will need to realize Magnetic Fields Polarizations (Poles) are a Spinning Flow.
Sorry, but You can't have both concepts together.
Now I will try with some graphics I made...to explain it (again) since you are asking for anyone who could do it...
[IMG]
[/IMG]
On above IMG N1 Magnetic Field is at Max Potential (Full Positive, High End connection), say that North spins CW at full potential...while N2 Magnetic Field is at Minimum Potential (retracting) therefore, the prevailing spin would be forced by N1 DIRECTION into N2 Primary Coil, look at N2 Coil Spin arrows, following a flow which returns to the opposite terminal from part G (red returning arrows), which would be sucking this flow and converting it "iso facto" in a Magnetic Field. at the G Toroid Iron Core.
Now, if you look at IMG below, it shows the completely opposite operation (N2 is at MAX):
[IMG]
[/IMG]
Here N2 is at Max Potential, same CW Spin at full input, but seen from different point of view (OPPOSITE DIRECTION AS N1), forcing the spin on the Retracting N1 (who is still spinning CW but now based on N2 direction) ...and so, returning back to the opposite end to the highest injected positive potential from the Part G Toroidal Iron Core.
There is absolutely no Magnetic Field Polarity reversal here at all, just lower-higher potential influences-Interactions from the same exact polarizations, in this case North Pole.
Another thing...This would work with a South Pole as well...right?...So, if we apply the Lorentz "B Field Theory" where it travels "one way only" from North to South...then Figuera should not work with South...however, it does work as well.
If we all start discussing about current flow directions as being always the same from positive to negative...or viceversa...or believe that magnetic field polarities does not spin...then it is really a waste of time to even attempt to explain how Part G works.
Part G ALONE is a Generator friend...based on exactly the same principle as Figuera's disclosure on his patent, using the same poles, whether South or North in repulsion mode. The only difference is that Part G Spins the two opposed Fields in a continuous Rotational Fashion...while Figuera Primaries does it in a Linear (back and forth) Fashion.
Same principle of moving the opposing (repulsion) virtual fields, and causing an Induced EMF on secondaries but in different displacement geometries.
[IMG]
[/IMG]On above IMG N1 Magnetic Field is at Max Potential (Full Positive, High End connection), say that North spins CW at full potential...while N2 Magnetic Field is at Minimum Potential (retracting) therefore, the prevailing spin would be forced by N1 DIRECTION into N2 Primary Coil, look at N2 Coil Spin arrows, following a flow which returns to the opposite terminal from part G (red returning arrows), which would be sucking this flow and converting it "iso facto" in a Magnetic Field. at the G Toroid Iron Core.
[IMG]
[/IMG]Here N2 is at Max Potential, same CW Spin at full input, but seen from different point of view (OPPOSITE DIRECTION AS N1), forcing the spin on the Retracting N1 (who is still spinning CW but now based on N2 direction) ...and so, returning back to the opposite end to the highest injected positive potential from the Part G Toroidal Iron Core.
