Let's back up to the beginning. As I understand it from reading most of this thread the Figuera device is NOT supposed to be a transformer. The theory is that by moving a strong magnetic field back and forth across the secondary coils power will be generated in those coils.
If that is true and I am not saying just yet that it isn't, then the normal relationship of primary turns to secondary turns should not apply. We only need two strong fields opposing each other and having those fields being varied in step with one another at 180 degrees difference between them. We have seen in a video posted on this thread of someone moving a coil back and forth between two opposing magnets and generating current this way. This certainly seems to confirm the theory.
So we only need two strong fields and a way to control them. We can easily get these fields by making the primaries of smaller gauge wire that is several times longer than the wire currently being used. That greatly lowers the current needed and simplifies the control of the current. It will also make it much easier to make a self powering unit if the input side current is lowered.
I don't buy at all the idea of bouncing the current back and forth between the primaries and part G. There is nothing in the patent that even hints of that being what is going on.
As soon as I get done with several other projects I am working on I will build a Figuera device using some real principles of how things work instead of fantasy ideas.
Respectfully,
Carroll
Respectfully,
Carroll
) / and stipulate some rules.
