Originally posted by bolt1
KILL ANY VIRUS OF BACTERIA IN YOUR BODY!!! Robert Beck and Micro-currents
Based on the information stated in the video and the Beck manual - the 4Hz isn't necessary and doesn't really matter. What matters is the amount of electricity that the blood picks up. The microcurrents are the key.Last edited by Savvypro; 06-15-2011, 08:50 AM....
Regular service Signature:
The Master Cleanse is suppose to detox you I've heard. I've known people who used it and all I could see was weight loss. Of course that happens when you basically stop eating but I don't understand how it "detox" and exactly what it is suppose to detox?
The best detox to me is MMS and using the Beck Protocol. They remove the pathogens in your blood. That to me is detox. The other toxins in your body will be removed when your body's immune system is unburdened.
My problem with the Master Cleanse:
1) It could rob your body of essential vitamins and minerals if you follow the detox strictly. I would also take vitamins if I were you doing this detox.
2) You can't sustain that regiment and what happens when you go off the Master Cleanse?
If you are set on using the Master Cleanse, I would say to do it first and when you've done, do the Beck Protocol. Not sure it's a good idea to do both at the same time. Remember that the Beck device will increase your bodies ability to take in products in the blood serum. This affects the effective dosage rate for things in your blood.
From my experience, the best "instantaneous" benefit to the body is to provide it with all the raw materials it needs on a daily basis to rebuild itself. If you want some instant and immediate health benefits, start taking a good multivitamin. If you have not taken vitamins before, the results will be quite drastic. From my testing on myself and friends, your energy level will jump to new highs within 24 hours. My allergies to food all disappeared! I was suffering like a dog from food allergies and taking in essential vitamins has freed me (though I have to make sure I take my vitamins daily if you call that free).
Not to say this is the best multivitamin but it's one that is easily available everywhere and that works for me and others I've got to try it is GNC Mega Men Sport. Not all multivitamins are equal!
Originally posted by Madnate View PostThanks I'll check these links out. I have not really looked into the magnetic pulser but I can probably use it as an attachment to my red light therapy device.
I found a local store that stocked some of the parts I needed so I can start building this soon.
I'm thinking about doing the Master Cleanse for at least a week when I start the blood electrification. Anyone see a problem with that? (I'll talk to my doctor just to be sure).
Stainless steel or even better if they are .99 silver.
You will also need cotton pads between your skin and the electrodes. They don't make direct contact with your skin. Make sure that the water you place on the cotton pads is conductive enough (You will know because you'll feel the current through your wrist). I like to use colloidal silver water.
Originally posted by Madnate View PostWhat is needed for the electrodes?
Great comments Bolt1.
I've heard great things about these TENS units.
I believe that Beck's brain tuner is based on some work with these TENS units. Beck's brain tuner is able to get you off of addictions and help with depression.
I have a Beck brain tuner and use it from time to time and love this device. It definitely increases my mental focus and helps to clear my mind noticeably.
Originally posted by bolt1 View PostYou can use TENS unit pads for the electrodes they are better than making your own cotton pads. Sometimes the TENS pads are too large so you can cut them into a strip about 1/4" inch wide to fit on your wrist but be careful you do not cut thru the electrode wire inside the pad. The TENS pads last ages but when the glue gets weak i use a soft elastic strap to hold the pads in place. Eventually you need a new set. Please do NOT share any electrode pads with other people. Make sure you have a clean personal set each.
BTW there are many fully programmable TENS units that can go from 1 Hz to about 10Khz. In the U.S. you may have a very hard time buying one as they are FDA restricted (cos they work and the FDA doesn't want you to have access to things that make you well)
In most other countries you can buy these TENS units anywhere off ebay etc and "SOME" will produce 4 HZ pulsed AC EXACTLY as per becks system to save you making one. (look for fully programmable and check the specs for frequency coverage.) In addition once you have a professional TENS unit with timer controls and rechargeable batteries in compact unit it does a thousand other things that are NOT known from the instructions like Cranial Brain Stimulation, pain relief, sleep induction, energy enhancement, stress relief, depression, drug addition withdrawal relief from opiates and alcohol addiction relief. This box has just abolished about 8 different rehab centres saving tens of $ thousands and several doctor visits while the kit cost about the same as a good restaurant meal. You know anyone hooked on Oxycontin? Well you check this out. Bob Beck spent years researching addiction not just a bug killer.
NOW can you see why the FDA does not want you to own these things!
Do not be fooled by these devices and after 2 sessions think nothing is happening then go for 2 or 3 hours in one session. These things pack an immune system punch so hard it can make you feel you just taken 2000mg of Amoxicillin. The toxin die off will hit you hard and you will feel as sick as a dog so take it easy. I have nothing to sell you only 6 years personal use. I never leave home without it together with MMS chlorine dioxide and ionic silver.
Good health!
I never heard about the winding of coils around the body but it makes some sense. Though I think it would greatly reduce the micro-currents below the needed threshold to be fully effective? 50-100 uA is what was recommended.
The off the shelf device I have (SOTA brand) uses only one 9 V battery but it's output is exactly the same as the original Beck device. So for this brand I would say it is exactly as Beck intended.
I have used the Beck device. I am in pretty good health with no major problems (aside from my previous food allergies which I was able to cure with vitamin supplementation). I have not had any major illnesses in many years. No colds, no flu, nothing really. So I have not seen any major changes from my use of the Beck Protocol of myself. I only used it for a month since I am not disciplined enough to use it daily. But I was not sick, so did not notice any major changes.
I did have an elderly lady friend of mine use it. She used it religiously for months as I suggested. She has thinning hair on top of her head as many women her age do. One day many months later I noticed she had very noticeable hair growth on top of her head! I mentioned it to her and she said other had given her the same comment. So Beck's hair growth claim seems to be solid.
Right now, I am using Beck's magnetic pulser on my scalp every other day. I have male pattern baldness setting in and I want to see if I can stop/reverse it with Beck's magnetic pulser. Only been a couple of weeks so can't report anything yet.
As far as Beck's health issues, he stated in the video that he was in good health aside from hair loss and being over weight when he started using the device. And claims his machine fixed both of those things.
Not sure where this idea that Beck was in poor health before using his device on himself came from and I can't say it isn't true BUT according to his own words in the video, he claims he was in good health.
Remember, he was an elderly man so of course he probably has some health issues but nothing major according to him.
To me, the Beck device is an emergency device I could use if I start to feel any illness coming on. The more disciplined among us will use it properly and get the maximum effects. Perhaps this is something I should try? Being more disciplined that is.
Originally posted by sucahyo View PostOk.
Reducing the detox effect is what most people skip.
Some people express concern that off the self Beck device are not built exactly as Beck suggested circuit.
There are method to actually wound the coil around the body and pulse it.
Have you use Beck protocol, SilverToGold? Any results you can share?
BTW, do you know the true reason for Beck health? This is important because some people say it is because of disease. If it is, then we should see it as limitation that should be known.Last edited by SilverToGold; 06-15-2011, 03:48 PM.
This is probably good advice. Build up to 2 hours a day.
From my own experience, I didn't have any problems going 2 hours a day starting off and my friend also didn't, but if someone is not in the greatest of health, that might be too much pathogens at one time to remove from your system. So your advice might be a good idea to start off with.
Originally posted by bolt1 View PostBTW 2 hours a day is far too much to start. I use 15 mins to start an increase 15 mins per day. You make someone sick on 2 hours first day they wont come back again LOL
Do you know where I can find a list of the frequencies/waves and what they do?Originally posted by bolt1 View PostYes if you have a 1Hz to 10Khz machine you can do everything i described above. My TENS unit provides DC pulse. AC Square, AC pulse, Sweep, Triangle wave, Sine wave, it has 2 channels so you can treat 2 people at the same time
and for other body features. Also all the waveforms are adjustable for mS pulse width variable for pulse repetitive rates and can mix 2 frequencies etc.
Can adjust the amplitude intensity and a timer to self shut down so your can not "overdose" on it. By setting to 4 Hz AC square drive this is the BECK blood cleaning setting its absolutely no different to any other beck device that conforms to correct specifications. BTW 2 hours a day is far too much to start. I use 15 mins to start an increase 15 mins per day. You make someone sick on 2 hours first day they wont come back again LOL
If you want to build one the fastest construction method is ONE 555 and ONE inverted FET driver IC to give the alternating AC o/p's then use a little audio transformer from old AM radio to step the voltage up adjustable around 50v to 100v PP with a control pot then it will work from one pp3 battery.
I did the master cleanse last year for 5 days, my energy levels just started to go up around the 4-5 day mark and then I stopped. It was a lot easier for me to breathe (partly from food allergies).Originally posted by SilverToGold View PostThe Master Cleanse is suppose to detox you I've heard. I've known people who used it and all I could see was weight loss. Of course that happens when you basically stop eating but I don't understand how it "detox" and exactly what it is suppose to detox?
The master cleanse helps flush out sludge in the digestive track, it flushes the good and bad stuff so it will flush the vitamins before they can work iirc. I think of it as elimination process and I was thinking it might do well with the start of the blood electrification but it could also make for a really rough first week. I'll probably do the cleanse at another time.
To really answer your questions you should check out The Master Cleanser With Special Needs And Problems by Stanley Burroughs. From what I have read on the internet, A lot of people do the MC sloppily with their focus being only on loosing weight.
I use AST Sports Science MultiPro 32X Multi-Vitamin. I need to get more.
How does the brain tuner work? I saw a bio tuner on a site but it didn't really say how its used.Originally posted by SilverToGold View PostGreat comments Bolt1.
Basically put the electrode pads behind your ears on the bone part of you head. Turn the voltage up very slowly so you feel a tingle but not too high just enough to get the effect. Tuning to specific frequencies causes the brain to resonate at certain frequencies and harmonics which causes a release of natural endorphins etc.
Depending on the frequency drug addition can be quite easily overcome. I have got two people drug free in just 7 days each. One was addicted to codeine for many many years for back pain. Another was prescribed Oxycontin a VERY powerful synthetic opiate some 5 times more additive than heroin. Its a major problem in many countries and in my view should only ever be prescribed in a hospital for terminally ill patients.
Im not suggesting its an easy way out the first 72 hours is comfortable but day 3 and 4 still go thru quite bad withdrawal symptoms with vomiting an shakes but the effect are at least 60% less than going thru cold turkey with no support. By day 6 eating and drinking normally again and day 7 fully recovered.
Other frequencies can be used to induce sleep or energy and even severe back and leg pain can be muted by what i call a spinal tap which is a diamond shape electrode placement using 2 channels and 2 frequencies just over the bone that sticks out on the lower neck top of spine. The effect is pretty much instant as it blocks the spinal nerve transmissions.
Is this similar to binaural beats?Originally posted by bolt1 View PostBasically put the electrode pads behind your ears on the bone part of you head. Turn the voltage up very slowly so you feel a tingle but not too high just enough to get the effect. Tuning to specific frequencies causes the brain to resonate at certain frequencies and harmonics which causes a release of natural endorphins etc.
Thanks for the info SilverToGold and bolt1.
This is for magnetic cure. not electric.Originally posted by SilverToGold View PostI never heard about the winding of coils around the body but it makes some sense. Though I think it would greatly reduce the micro-currents below the needed threshold to be fully effective? 50-100 uA is what was recommended.
Do you measure 27V from your device when you put the electrode on your body or when you don't use it?
It is good that old lady can use it too. I don't hesitate to use mine on 6 months baby and already done so to reduce fever.
Nice results on hair. It surely help people sleep better and look younger.
I found two link about Beck death, one mention from old illness including diabetes, other from heart attack.
Any possible side effect from the device if used continuously like harder to sleep? Or you actually sleep better after?
Not really no Cranial Electro Stimulation is direct electrical contact using extremely low power its not electric shock treatment nor is it working through the audio pathways. A similar method is Transcranial magnetic stimulation using induction coils as magnetic pulsar modulators. This is dangerous in the wrong hands and i don't really agree with using Becks Pulsar directly on the head. Brain pathways and neural connections can be rerouted and rebooted using magnetic stimulation for like stroke victims or accident victims that have lost part of the brain function can be remapped by firing in a new sequence under computer control from a normal brain. Its literately like rewriting the flash memory chipOriginally posted by Madnate View PostIs this similar to binaural beats?
CES is restricted Class 3 by the FDA. They claim the results are poor which is why its restricted because it works! Only extremely expensive, invasive or toxic treatments get full FDA clearance
Thanks. This sounds like something I need to research really well before attempting to replicate.Originally posted by bolt1 View PostNot really no Cranial Electro Stimulation is direct electrical contact using extremely low power its not electric shock treatment nor is it working through the audio pathways. A similar method is Transcranial magnetic stimulation using induction coils as magnetic pulsar modulators. This is dangerous in the wrong hands and i don't really agree with using Becks Pulsar directly on the head. Brain pathways and neural connections can be rerouted and rebooted using magnetic stimulation for like stroke victims or accident victims that have lost part of the brain function can be remapped by firing in a new sequence under computer control from a normal brain. Its literately like rewriting the flash memory chip
