KILL ANY VIRUS OF BACTERIA IN YOUR BODY!!! Robert Beck and Micro-currents
  • #16
    Does anyone have a copy of the original paper that is mentioned in the video like in the first post.
    I've found a section on keelynet which covers the flash/magnetic coil device over at: Thumpy Index page
    Info from the video:
    Stainless steel 316 diped into sea salt before use.
    Put 3 to 4 milliamps into the skin. 50 microampere into the blood (50 millionths of an amp)
    4 hertz - not critical
    For the coil:
    Minimum of 17.5 J - optimum of 35 J
    You can not use ac
    Regular service Signature:
    • #17
      I don't know if this is the same paper, but this booklet pretty much covers everything needed to know the history of Beck's device. It includes patents and reference articles to the original Albert Einstein College. It's about $20 but I was able to find a free copy here for you guys.
      http://anndann.musicker.net/books/beck.pdf
      The Pulse Coil has to use DC since polarity is very important. Only North pole pulsing of the body is recommended. South pole pulsing is said to have negative effects on the body. The magnetic pulses causes micro currents within the body from "eddy currents" and this kills the pathogens within the body.
      For the coil:
      You can not use ac
      • #18
        I understand and I very much believe that MMS and a Beck machine should be in everyone's survival/emergency bag.
        Looking at the circuit and the cob web filled recesses of my memory, I believe the waveform is just a DC pulse square wave at 4 cps. Goes from 0V to 27V. No negative parts of the waveform. Just plain pulse DC.
        And yes, watch the videos!
        Originally posted by Madnate View Post
        I don't have the exact parts on hand and it will be some time before I order parts. I just wanted to make sure I understand what the circuit is doing and I also wanted to experiment with the parts I have now . I do understand the importance of the maintenance and I have the discipline to do it. I want to build a couple extra units with electrodes and silver wire for our survival bags.
        The videos are long but worth watching.
        • #19
          This is a good point, we don't want to kill any beneficial bacteria like the ones in our intestines but with the Beck device being applied only to the blood at the wrist, those bacteria are safe.
          This device is not a replacement for the immune system, it's a assistant. Just like a how a bicycle can help you get there faster than just walking but you're still using your legs and getting exercise!
          Our bodies are more than able to handle any disease thrown at it if our immune system is not over burdened. All these anti-bacterial soaps and other chemical assaults on our bodies actually harm our immune system and make us more susceptible to pathogens.
          Which is why I love the Beck device, it's simple and it's operation straightforward. Micro-currents through the pathogens! Kind of like a hammer, you know what it is and how it works. It's just a matter of knowing where to hammer.
          Originally posted by khabe View Post
          Yeah, perhaps necessary sometimes for different reasons,
          but when to think dissimilarly then one of reason of poor health is panic fear of bacterias - meretricious hygiene today - every kind of anti-bacterial soaps and so on kills all microorganism, inkluded useful ones, whereby killing "only harmful" bacterias our body will lose our inbuilt natural-born ability to fight with diseases - man will lose acquired immunity and the rest of life need to be spent inside sterilized G suit, no sex no normal food, no fresh air
          cheers,
          khabe
          • #20
            Blood Electrification/Colloidal Silver Circuit
            Originally posted by http://www.sharinghealth.com/pdfs/buildyourown.pdf
            U1A, the second comparator, is used to invert the output of oscillator U1B. A ~54 Volt peak-to-peak signal will be generated between the op-amps due to their outputs being 180 degrees out-of-phase.
            Does 54v peak to peak mean it goes +27V then -27V?
            I don't think I will have a problem building this circuit and the magnetic pulser once I get the parts.
            Building the device to pump ozone into the water might be a problem for me.
            • #21
              You may be correct! I would have to actually connect a scope to the device and see what it looks like. I'll do that and get back to you with what I find out.
              The ozone generator is a more challenging item to build. I just bought mine pre-built.
              Ozone Generator | BeckProtocols.com
              There was some talk of cold vs hot corona. All I can say is that the water treated with ozone taste just like fresh rain water!
              • #22
                unfortunately I'm not an electrician so building this is out of the question (at least for now). Is there any place to get one of these?
                • #23
                  BeckProtocols.com - The Complete Beck Protocol Kit | BeckProtocols.com
                  There are probably other sites that have them too.
                  I cant even afford the parts so buying the units is out of the question for me
                  • #24
                    Thanks for the links. And your not kidding on it being a bit pricey.
                    On a side note, these kind of remind me of the wands of horas.
                    • #25
                      Not cheap but worth it
                      Looking around the internet for the best prices and I will post what I find.
                      http://i567.photobucket.com/albums/s...s/ImBatman.jpg
                      • #26
                        I made ozone generator from the exact same circuit I post above.
                        I believe the output has to be AC or it may burn skin.
                        2 hours a day is much too long. 30 minutes is more than sufficient.
                        Anyone replicating mine, please use neon bulb or analog volt meter as indicator. Use under 40V or you may get jolted even with 3V source.
                        • #27
                          Thanks! I will try this out.
                          • #28
                            I'm in the process of ordering the part to build the circuit show above.
                            It's been a while since I've got my hand "messy" with electronic components, so have a question for thoes who have more experience: is it ok to substitute similar spec components for those listed. For example:
                            18v 500mW Zener diode BZX55C18V for the 18v Zener diode listed in the parts list as NTE5027A.
                            Also for the LM358 CMOS Operational Amplifier - I can easily get LM358N chips but not LM358.
                            • #29
                              I checked my scope and you are correct. It's 54 V PP, +27 V then -27 V at 4.17 Hz.
                              • #30
                                This is the Beck Protocol and is not the same as your device and method. I don't mind you posting your info on this thread since it is interesting and somewhat related but again, it is not exactly the same thing as Beck's device.
                                With the Beck Protocol, 2 hours a day for a month is what is recommended when starting off. You can do an hour in the morning an hour later or 2 hours in one sitting.
                                Make sure to drink enough water, due to the detox effect, your body will want to eliminate waste more frequently.
                                I have never experienced anything I would consider burns, just some dry skin at the contact points on the wrist. The output is an AC square wave.
