KILL ANY VIRUS OF BACTERIA IN YOUR BODY!!! Robert Beck and Micro-currents
  • #31
    Any 18V Zener should work fine. We're dealing with very small power (micro currents) so 500mW should be fine.
    The LM358N is the LM358. The N denotes it's package type. The N type is the typical dip pin type we are all familiar with. So you're good to go.
    Originally posted by Savvypro View Post
    I'm in the process of ordering the part to build the circuit show above.
    It's been a while since I've got my hand "messy" with electronic components, so have a question for thoes who have more experience: is it ok to substitute similar spec components for those listed. For example:
    18v 500mW Zener diode BZX55C18V for the 18v Zener diode listed in the parts list as NTE5027A.
    Also for the LM358 CMOS Operational Amplifier - I can easily get LM358N chips but not LM358.
    • #32
      Originally posted by occy30 View Post
      unfortunately I'm not an electrician so building this is out of the question (at least for now). Is there any place to get one of these?
      Sometimes, they come up on ebay built by hobbyist. Search under "Beck device", "Beck pulser" or "Beck zapper". The price varies but you may be able to get a deal.
      Or if you have a friend who is handy with electronics, why not have him build it for you.
      • #33
        Regular service Signature:
        • #34
          If any of you guys are successful in getting this device built maybe those of us with no electronic skills could purchase your devices I trust people here vs people on ebay.
          • #35
            • #36
              @SilverToGold
              Do you know of any working/usable flasher/strobe circuits that could be made for use as a Magnetic Pulse Generator circuit. The Beck document that you posted covers how to alter a flash and gives the spec of a commercially available Magnetic Pulse Generator. On page 47 it states:
              • #37
                Build a Low cost & simple Magnetic Pulser - Share The Wealth
                My Home-Made Bob Beck Electromagnetic Pulser
                The draw back is that it has to be manually pulsed. If you are a little industrious, you could use the second half of the Bedini's SG circuit to pulse the cap automatically.
                As a mater of fact, with a little modification, a Bedini SG could be used as a Beck magnetic pulser.
                Or you could use a Joule Thief circuit to charge the capacitor and the second half of the Bedini's SG circuit to discharge the cap automatically into the coil.
                There are lots of options, I just gave you 4 distinct methods right here.
                @SilverToGold
                • #38
                  An important note to any people doing magnetic pulsing of living tissue.
                  Always use the NORTH pole of the magnetic coil!
                  The south pole is bad for living tissue.
                  • #39
                    Thanks I'll check these links out. I have not really looked into the magnetic pulser but I can probably use it as an attachment to my red light therapy device.
                    I found a local store that stocked some of the parts I needed so I can start building this soon.
                    I'm thinking about doing the Master Cleanse for at least a week when I start the blood electrification. Anyone see a problem with that? (I'll talk to my doctor just to be sure).
                    • #40
                      Electrodes
                      What is needed for the electrodes?
                      • #41
                        You can use TENS unit pads for the electrodes they are better than making your own cotton pads. Sometimes the TENS pads are too large so you can cut them into a strip about 1/4" inch wide to fit on your wrist but be careful you do not cut thru the electrode wire inside the pad. The TENS pads last ages but when the glue gets weak i use a soft elastic strap to hold the pads in place. Eventually you need a new set. Please do NOT share any electrode pads with other people. Make sure you have a clean personal set each.
                        BTW there are many fully programmable TENS units that can go from 1 Hz to about 10Khz. In the U.S. you may have a very hard time buying one as they are FDA restricted (cos they work and the FDA doesn't want you to have access to things that make you well)
                        In most other countries you can buy these TENS units anywhere off ebay etc and "SOME" will produce 4 HZ pulsed AC EXACTLY as per becks system to save you making one. (look for fully programmable and check the specs for frequency coverage.) In addition once you have a professional TENS unit with timer controls and rechargeable batteries in compact unit it does a thousand other things that are NOT known from the instructions like Cranial Brain Stimulation, pain relief, sleep induction, energy enhancement, stress relief, depression, drug addition withdrawal relief from opiates and alcohol addiction relief. This box has just abolished about 8 different rehab centres saving tens of $ thousands and several doctor visits while the kit cost about the same as a good restaurant meal. You know anyone hooked on Oxycontin? Well you check this out. Bob Beck spent years researching addiction not just a bug killer.
                        NOW can you see why the FDA does not want you to own these things!
                        Do not be fooled by these devices and after 2 sessions think nothing is happening then go for 2 or 3 hours in one session. These things pack an immune system punch so hard it can make you feel you just taken 2000mg of Amoxicillin. The toxin die off will hit you hard and you will feel as sick as a dog so take it easy. I have nothing to sell you only 6 years personal use. I never leave home without it together with MMS chlorine dioxide and ionic silver.
                        Good health!
                        • #42
                          Good health!
                          Thanks I did not know about tens units or pads. Are the other features of the tens unit controlled by frequency? I'm going to replicate the 4hz ac beck circuit but I would like to build an advanced version in the near future.
                          • #43
                            How to build a breadboard blood electrification circuit
                            Another good link
                            Unleash Health | Build Your Own Blood Electrification Circuit
                            • #44
                              With the Beck Protocol, 2 hours a day for a month is what is recommended when starting off. You can do an hour in the morning an hour later or 2 hours in one sitting.
                              Make sure to drink enough water, due to the detox effect, your body will want to eliminate waste more frequently.
                              Ok.
                              Reducing the detox effect is what most people skip.
                              Some people express concern that off the self Beck device are not built exactly as Beck suggested circuit.
                              There are method to actually wound the coil around the body and pulse it.
                              Have you use Beck protocol, SilverToGold? Any results you can share?
                              BTW, do you know the true reason for Beck health? This is important because some people say it is because of disease. If it is, then we should see it as limitation that should be known.
                              • #45
                                Yes if you have a 1Hz to 10Khz machine you can do everything i described above. My TENS unit provides DC pulse. AC Square, AC pulse, Sweep, Triangle wave, Sine wave, it has 2 channels so you can treat 2 people at the same time and for other body features. Also all the waveforms are adjustable for mS pulse width variable for pulse repetitive rates and can mix 2 frequencies etc.
                                Can adjust the amplitude intensity and a timer to self shut down so your can not "overdose" on it. By setting to 4 Hz AC square drive this is the BECK blood cleaning setting its absolutely no different to any other beck device that conforms to correct specifications. BTW 2 hours a day is far too much to start. I use 15 mins to start an increase 15 mins per day. You make someone sick on 2 hours first day they wont come back again LOL
                                If you want to build one the fastest construction method is ONE 555 and ONE inverted FET driver IC to give the alternating AC o/p's then use a little audio transformer from old AM radio to step the voltage up adjustable around 50v to 100v PP with a control pot then it will work from one pp3 battery.
