Originally posted by tutanka
Originally posted by Vickers
Originally posted by Aaron
Originally posted by pengrove
Originally posted by Michael John Nunnerley
I am beginning to wonder if ionizing the exhause gas & hho is better than using ambient air because exhaust gas should has lower oxygen content. Exhaust gas oxygen already bond with other molecule. This way we don't have to worry about lack of oxygen in case our ionizer do too much and deplete the ambient air oxygen.
Maybe a 10Amp hydroxy booster output combined with exhaust gas at 3:2 ratio that we ionized before forwarded to fuel source line in a carburetor.
But Bob Boyce is total guru? At today him build ONLY standard HHO cells with electrolyte using a lot of ampere
and however also HHO interact a lot with metals.. about energy used.. all depend on the state of water and method used for create new combustible.. Sucahyo have posted first meyer system of meyer (needed more changes for work properly), of course..that was first idea of meyer on the creation of new combustible because only HHO CAN'T RUN AN ENGINE PROPERLY IN THE TIME. Meyer after more experiments using HHO have understand that electrolyte can't be used because change final reaction and for that have created WFC cell.. after experiments, using distilled water, him have understand that instead transform water in HHO can be useful water directly using in part the same method of mix water,air, exaust gas but I know for sure that sometime car stopped to run, the special injector don't work properly because is needed high technology inside.. my object now is run properly an engine for that I have decided to use gas production way using normal spark plug and secure method of gas production. About catalyst .. that is every chemical way for accelerate reaction but you don't need in that process.. you don't have to read patent of meyer but only see designs present inside these. Regards
