last edit...
Ionization & Water Fuel
I am using conventional science. "when ionize N is exposed with ionized H," in an ionizer of whatever form, the balance between resulting N2, H2 and NH3 will be predicted by graph bellow:Originally posted by Aaron View PostIf you elaborate just a bit more on the underlined part of your sentence, you may wind up explaining one of the keys.
ionizer is heat, plasma, spark, HV, microwave, LED, Laser, etc. And the graph suggest that temperature should not be too high. WIki also confirm this mentioning similar heat limit.
By theory if the middle tube H is all combined with N then there is more O left. This O if combined with NH3 can form HNO3, nitric acid. Nitric acid is said to disassociate at room temperature, maybe tube temperature should be cold?
BTW, since spark seems damaging my monitor, I found that I can safely use insulated electrode type of ionizer. I don't have coated tube so I just use insulated wire. Configured in a spark distance I can smell ozone:
Sorry for not getting it clear enough. Yes, that diagram is Meyer's mixer. I don't know tutanka method and I also seek other non Meyer's ionizer.Originally posted by tutanka View PostSorry but that diagram don't have any sense.. O-, O+, H+, H-... for me you are more confused.. I don't understand what is your project.. I suppose that your idea is use an NTP reactor but image that you have posted don't have sense.. that in fact is mix part of STEAM RESONATOR.. regards
I propose to make it a tube inside a tube inside a tube, a deviation from Meyer design. The middle is wire that being charged with pulsed high voltage positive and first outer tube charged with pulsed high voltage negative.
Because H2O will break into 2H+ and O- when excited with electricity, the most inner one will produce H+ and O-. Since the middle wire is positive, the middle is O- because O will be attracted to "positive electrical voltage potential", and the outer is H+ because H will be attracted to "negative electrical voltage potential".
See page 1-16 (23) of Meyer Technical Brief if you still confuse about this O- and H+.
Second layer is Ambient air which I assume will contain ionized N- and O- because I am not sure which one more positive, maybe N, and to give indication that N maybe more likely to combine with H+ instead of O-, because unlike pole attract more. Last layer is exhaust gas which I assume will contain ionized N-, O- and H+.
Sorry but for me don't have sense.. I suggest you to study pulsed corona discharge.. RegardsOriginally posted by sucahyo View Post
nh3
There is more than one way to skin a cat and they all deal with NH3Originally posted by chasson321 View PostSo you might as well include yourself in with us as to what "His" process is.
production.Sincerely,
oxygen
What is commonly said to happen specifically to oxygen in Meyer'sOriginally posted by sucahyo View PostI am using conventional science. "when ionize N is exposed with ionized H," in an ionizer of whatever form, the balance between resulting N2, H2 and NH3 will be predicted by graph bellow
process? It is something that Meyer fans like to repeat over and over
about what happens to oxygen in the ionization process.Sincerely,
Hi,Originally posted by tutanka View PostTim..
I have decided to mount Water system directy on LPG generator made in greenpower.cn. Model used is CC5000-LPG. Engine is an 4 stroke 398cc.. now Im working on that and I aspect to finish for the end of this month.. Next prototype an chevrolet matiz 1000cc..
Only for curiosity.. how proceed the work of h2opower? In all cases I respect him.
Does your Water system come in different sizes, for small engines to large? Will the Nascent Plugs (plasma plugs) be standard for using in different size engines?
Regards, Mike R.
Hello..Originally posted by vrand View PostHi,
Regards, Mike R.
Yes, all depend not from chemical formula that remain the same but from system that produce new combustible. I have just found an solution for don't use nascent plug.. Regards
Hi,Originally posted by tutanka View PostHello..
That is interesting. So can we still use our regular sparkplugs? And use our existing ignition system also? Or will need to update ignition system?
Regards, Mike R.
The circuit I see for corona ionizing use awesome power (10 amp 10000V). I only want to use my 1.2 watt version of HV generator. The application seems to be either voltage onlyonly, insulated electrode or silent discharge.Originally posted by tutanka View PostSorry but for me don't have sense.. I suggest you to study pulsed corona discharge.. Regards
According to Meyer Patents CA1227094:Originally posted by Aaron View PostWhat is commonly said to happen specifically to oxygen in Meyer's process? It is something that Meyer fans like to repeat over and over about what happens to oxygen in the ionization process.
espacenet — Bibliographic data
Summary of the process is:
Water droplet is break into Oxygen and Hydrogen with the help of 40KV DC. The mixed it with part of exhaust air and then with ambient air. This is not water fuel injector process, but it still Meyer. and prove that meyer do use every gas contained in ambient air such as nitrogen and oxygen. In this patent the ambient air do not even need to be ionized. In news Meyer also mention that ionized air is optional.
What oxygen do in this particular system depend on the source. From water it will form combustible gases along with hydrogen and non-combustible gases. From ambient air, to help combustion.The system utilizes the hydrogen generator of my co-pending patent application serial no. 420,908, for developing hydrogen gas, and other non-combustible gases such as oxygen and nitrogen. ... The combined hydrogen, non-combustible gases, and the air after intermixing are fed to a combustion chamber where in the mixture is ignited. The exhaust gases of the combustion chamber are returned in a closed loop arrangement to the mixing chamber to provide the non-combustible gases for the mixture. More spesifically, generated hydrogen gas is fed to a gas mixing chamber where it is intermixed with non-combustible gases and such gas mixture is the fed to a carburetor (air-mixture) system
The gas mixture combine with the air to form a combustible mixture of hydrogen, non-combustible gas, and oxygen.
Further, as understood oxygen is required for combustion, and it is present in ambient air that enters into the gas mixture line through the air intake. Again, the ambient air is understood to contain many and variable gases other than oxygen.
Anyway,
1. Meyer also had a process that produce combustible gases from hydrogen, oxygen and some non-combustible gas.
2. Meyer mention that non-combustible gases are oxygen and nitrogen. However, when oxygen already explicitily mentioned, it is wise to assume that the non-combustible gas refer to nitrogen.
3. In this patent Gas processor do not exist.
4. In this patent the fuel is not molecule with only hydrogen as its component. The fuel is not hydrogen.The fuel is combustible gases from mixed of three gas type.
If Meyer talk about molecule, then it consist of Hydrogen, Oxygen and Nitrogen. So, in this spesific implementation a process that only ionize spesific gas is wrong , and avoiding nitrogen ionization is wrong.Last edited by sucahyo; 04-16-2010, 05:36 AM.
ionization
So Meyer ionizes oxygen.Originally posted by sucahyo View Postand prove that meyer do use every gas contained in ambient air such as nitrogen and oxygen. In this patent the ambient air do not even need to be ionized. In news Meyer also mention that ionized air is optional.
If Meyer talk about molecule, then it consist of Hydrogen, Oxygen and Nitrogen. So, a process that only ionize spesific gas is wrong. Selective ionization is wrong. Avoiding nitrogen ionization is wrong.
Selective ionization is wrong, I agree with you. I have never said that
oxygen does not get ionized but I can see that some people think I am
implying that by mentioning ionization of nitrogen - that's fine. Some people
see things as they are other make up stories in their own mind about
what they think they are seeing. I think you're seeing things pretty clear.
Avoiding nitrogen ionization is wrong, I agree with you. Not only is it
wrong, it is naive for some to believe that nitrogen turns into Ninja
molecules that stealthily sneaks through an ionizer without getting
ionized - and some that believe that hydrogen won't bind to the ionized
nitrogen is doubly or actually triply naive.
Sucahyo, you're seeing things pretty clear.
I'm hoping you will spell out the sequential steps of what happens to an
oxygen molecule as it enters an ionization process and exits.Sincerely,
That is something I still confuse too .....Originally posted by Aaron View PostI'm hoping you will spell out the sequential steps of what happens to an oxygen molecule as it enters an ionization process and exits.
The N, H and NH3 graph balance I post earlier show relation of atom and NH3 molecule depend on temperature. I imagine if we add oxygen in there, we should see chaos in the graph....
What make it confusing is there can be many atom combination, many balance or one way equation depend on many variable. It is possible that what is combust may not be a stable molecule, just like hidroxy powered engine.
At least we know there can be NOx, water vapor and NH3 at output. There will be more NH3 and less NOx if there is more hydrogen input. Or even H2 at output:
high H2 exhaust emissions
ionization
Forget about all the confusing stuff.Originally posted by sucahyo View PostThat is something I still confuse too .....
Simply, what does it mean to ionize oxygen?Sincerely,
Skeptical
Hello, I just finished reading this whole thread. It is very interesting as many threads on this subject are. I remain very skeptical and yet optimistic. I can`t tell you how many times I have seen people post that they have the answer but cant reveal anything due to nda`s and various other reasons, then they continue with supposed clues and riddles to a ever lasting puzzle that never gets solved. Hope the truth is being told here by the guys supposedly to have a answer.......I am VERY suspicious.......just my 2 cents.Aaron I admire your quest and tenacity.....you are one of the few real deal`s I have seen in a very long time.
Any gas which is electrically charged can be said to be ionized. ion energy is when molecules are electrically charged so that their properties are changed.
A word to the wise men here, get the show on the road. Before long electromagnetic reactions will give different effects.
Yes!Originally posted by pengrove View PostAny gas which is electrically charged can be said to be ionized. ion energy is when molecules are electrically charged so that their properties are changed.
Tutanka, Rosco1 and group, its been 10 weeks since your February 6th announcement.
Any update on when you will publish your proof of concept disclosure?We would like to say that we have confirmed the processes required to make any engine run on this new fuel(essentially water).
We are currently in the process of putting together a proof of concept disclosure.
Please allow us a few short weeks to get that done, at which time, we will go viral and make a general media announcement.
Regards, Mike R.
