In Car Application Query
Aaron and/or Others,
What changes need to be done to this circuit and/or others here so that we can use them as a plasma ignition system in car? Thanks.
The cold running scenario sounds very interesting. I want it.
Best Regards,
Slovenia
Best Regards,
Slovenia
.jpg)
Works fine. I used a 75w light bulb as a resistor. At first I made a test with no vexus circuit attached, no booster side, just an ordinary spark. I made the test for longer time to get more accurate results. The ordinary spark circuit did consume all the fuel in 45m40S. Then I attached the vexus circuit with a voltage doubler. I also attached a microwave diode connecting the ignition coils LV positive to the HV output. And I attached a diode string in series with the ignition coil secondary to prevent the booster cap discharge through the secondary in between the pulses. This is the circuit that I used:
Did you use this on a running car or on a bench setup?
