Originally posted by revizal
I like your setup idea
If you can test with Diesel it would be better. The Oil Mafia
oops, I mean Companies have been adding chemicals in Gasoline to prevent fuel cracking. I believe Diesel is not altered yet. They change the chemical additives in Gasoline up to 4 times a year, so if you had a GEET vehicle you would need to re-tune the reactor rod every time the additives change. Also, if you traveled from State to State you would also possibly have fuel additive changes, even changing from one garage Company to another can get a different blend. This is the number one reason the GEET system has never taken off in America as Diesel is not the Fuel of choice for cars! ... Gasoline is. I think they are trying to keep it this way also since for the last 2 years Diesel is higher priced than Gasoline and is now up to a $1 more per U.S. Gallon. Before this, for as long as I can remember Diesel use to be less than Gasoline.The GEET has really taken off in France and the main reason for that is Diesel is the number one choice for vehicle fuel. They are years ahead on GEET Diesel development. I know about this because I researched it a year ago and French is my mother tung.
One way or the other Diesel has more energy content. Not much difference than Jet fuel.
Great work revizal and thanks for sharing.
Luc
I bet that engine will last longer and it will run cooler obviously with the steam injection and get almost the same benefits as the hydroxy. If Bugs came off the production line like that ill take 5 of them
The only direction left to go is forward. On with the experiments, later..............................Mike
