Bedini motor why stress can only use ceramic magnets?
  • #31
    Originally posted by darkwizard View Post
    Neodymiun Magnets work very well on the SG with air core coil
    same here i always use neomagnets on all of my motor projects.
    whit air core. but i find ferrit core work the best like Bill Muller.
    becous de swhits faster than metal
    i use reed, coil, and optic trigger and the last work the best
    The radiant energy is here!
    The energy revolution is now!
    Ray0energy
    http://www.youtube.com/profile?user=ray0energy
    • #32
      yes it is,
      Iron core with Neo's. John Bedini's of course but...
      YouTube - baja 22 063.avi
      Half bipolar switch, Hall sensor and timing wheel driven.
      Matt
      but it is not a simple SG circuit it is a window motor circuit
      http://www.teslagenx.com
      • #33
        neos work perfectly
        neodymium's work perfect if you space the coils far enough apart I switched to neodymium's 2 years ago and had no issues with them the VMG project is neos and its the only way I have found to get enough torque to make a motor and not just a energizer but I only use 24 chips on my motor Mr Bedini uses alot more chips on his energizer, ZPF motors all about the torque both solutions are valid and should be studied to gain a better understanding of pulse motors/energizers
        Tecknomancer
        Zeropointfuel.com
        • #34
          Technomancer, haven't you heard? Bedini motors don't have torque
          YouTube - Bedini Motors Have NO Torque!
          (yes it uses neos as well but with air core)
          • #35
            year of the electron
            I will have some new vids soon, the VMG is now spinning 16lbs of flywheel 16 mags and a converted alternator with 12 neos magnets and 1 1/8 " cores I have used both coat hangers and welding rods both work fine I hope this will be a big year for FE
            sorry permanent magnets make it a generator not a alternator
            Tecknomancer
            Zeropointfuel.com
            • #36
              Actually the existence of a shaft Commutator is the technical difference between an Alternator and a Generator (although the other common usage of the word "generator" as any rotating device that produces current ignores this).
              There certainly are PM Alternators.. generally more expensive that "field" ones, fitted as after-market on boats and cars, usually for higher current output (and they are more efficient, especially for slower RPM applications like wind turbines since they don't need field current).
              Permanent Magnet Alternators PMA wind power wind turbines wind mills PMG Permanent Magnet generators PMA wind power turbine hydro power wind turbine
              Fossil Freedom - Permanent Magnet Alternator
              Outboard motor PM-Alternator built into the flywheel (which has an interesting design with all mags facing the same pole direction, and the coils in series but wound alternately "CW" and "CCW").
              continuousWave: Whaler: Reference: Permanent Magnet Alternators
              • #37
                PM-Alternator
                thanks for the links I stand corrected
                Tecknomancer
                Zeropointfuel.com
                • #38
                  Window motor, the stronger the magnetic properties of the higher efficiency
                  Window motor select the neodymium magnet efficiency will be higher, but the stronger the higher the efficiency of magnetic!
