AXIAL SSG with Nd magnets vs Ferrites grade 8
Explaining my setup.
two similar sized rotors (11'') with six magnets embedded on the circumferce.
The one having 6 x 30mm (disk) ferrite grade 8 10mm thick double stacked (20mm)
The other having 6 x 25mm (disk) Nd grade 38? 10mm thkc double stacked (20mm)
I used a standard Besini SSG circuit with 3 BD243c transistors and a coil of 300 feet 5 x 22awg wire and 24 (trigger)
My double confirmed findings
In the Nd rotor having an larger appropriate distance of coil core to magnets with the 0.5 amp at 15volt power consumption i achieve rotor speed about 500-600 rmp and some good torque.
In the ferrite rotor the same coil with tha same power consumption (0.5 amp at 15volt) outputs some 250-300 rmp and considerable lesser torque. (half of the other rotor i would say)
I am asking. Why in SSG we are not suppose to uses neos? By the way, neos or not, my view is fixed that the greater the magnet the better the mechanical efficiency of the SSG "motor"
Baroutologos
Baroutologos
Hmm, I am not quite conviced that the charging effect is diminished. In fact when i have a hooked DMM on the charging batt it level off to the same voltage for both rotors at the same power consumpion.
