Hi, i think the Frequency depends on the Voltage, may turn it higher, and see if the Freq changes.
I was about to ask myself if a change in the Freq does change anything.
A poor Man Reedswitch can be made with 2 cutted Razorblades, or one Blade and a copper contact. If the attraction to the Iron is to weak, you can glue a little Magnet on the blade. The Contact can be made from other more solid Material too, because Copper can may a bit burn.
Something else about the Reedswitch, they should work too, when you only bring them with one End into the Field,
because the Metal inside will magnetize and make a Contact. So its not needed to got them directly in the middle from the Coil or very close to the Magnet
