3 things
The capacitor recycling method works and is similar to what I did here to
keep this oscillator self running. I initially charge the front side cap (instead
of having a battery). Then I remove the charge, and it keeps going. I do
have a simple earth ground rod that I'm using and it keeps all the pressures
balanced. Input goes down, then climbs up to a happy medium and stays
there.
YouTube - Self Running Bedini Oscillator
I tried it with this heater circuit with mixed results. There are really a lot
of possibilities of using capacitors in this circuit. But if the front side power
supply sees the recovery capacitor, then the recovery will be sabotaged.
With capacitance discharges. If you connect the positive and dump the
cap by switching the negative side and have increased resistance there
at the negative point, you will amplify the negative energy. With positive
connected, the destination ALREADY has the positive potential sitting it in
and doesn't have to get there. So it is just an extension of the diode that
the cap is acting like. The e-amp effect seems to be very real because I
always had stronger battery charging effect by switching on the negative
with the inverted circuits and having a resistor there at that point.
I see that it is completely true that a positive potential is dissipated by
resistance but a negative potential is amplified by resistance. The
experiments show this to be the most likely case every single time.
The link I put in this post is a great walk through for anyone for ionization
by collision.
there.
by collision.
it works.
aboard!
I will try and do this again.
