Hi Mike - I noticed your question here since last night and simply don't know the answer. How does one progress this system to higher values as needed?
As I see it the problems are to do with those RF frequencies - the same things that prevent you filming the circuit. As I remember it the actual noise pollution - on higher ac applications (from utility supplies) is extreme. Not sure if these can be muffled or how one does it.
But I wonder if Fuzzy's solution is perhaps the best. I think he suggested that batteries in series with a plug would allow one a chance to exploit the spike. And I'm also not sure if capacitors enable the effect or frustrate it. So. This is the new ground that you guys will need to forge. But, for now, I do see a really neat little circuit to extend the life of your average torch - and - with some neat circuitry - it may be possible to keep the car battery rechaged - in that awful event that one leaves on the car lights. I know I've done this too often to be recalled - and I've got one of those alarms that warn me they're on! But one of the most obvious advantages are to the geyser or hot water cylinder application as it's called in the States. Here there would be an immediate advantage and it goes back to your STEAP designs.
I was intrigued with your two resistor arrangement. It's innovative and neat. But how about this? design the cylinder around a hollow tube in its centre - and then insert a really long resistor through that tube to get a quick dispersion of the heat into the water. Then switch the energy to that resistor but put batteries in series with the plug and the resistor in series with the battery and its switch. That way the draw down from the plug should be reduced to 'topping' the battery - when and as required.
That way research can be confined to the optimised cylinder design coupled to the optimised resistor design. But you'll still need to experiment on the resistor and the type of windings. At the risk of getting overly technical - I'd recommend that you keep the resistive wire 'thick' - LOL.
That's the best I can suggest but I'll keep thinking about applications. Get some hefty wattages and we'll definitely start making inroads, and, hopefully, you guys can start getting some returns for your hard work here.
