Peter, whatever happened with Eric P. Dollard?
This topic is closed.
This is a sticky topic.
The Four Quadrant Theory of Electrical Activity, Part Two, or more? (3 of 7)
The two time spans, the charge time span,
, and the discharge time span,
, are now equal and opposite. Hence a single time span can represent both
and
(28)
, seconds.
This time span is the one quarter period of a complete cycle of Energy Exchange, T. In the condition of cyclic energy exchange the magnification factor is expressed by the relation
(29)
, versor.
Hence the magnification factor is always unity. The Magnetic Power, Pm, is equal to the Dielectric Power, Pd. This is to say the Charge Power Flow is equal to the Discharge Power Flow. No charge-discharge magnification exists here. This magnification factor is now just a versor operator establishing the Law of Energy Conservation.
For the condition of energy transfer, the single energy transient, the transfer of energy is into, or out of the single stored energy. It is a one way flow, backward flow, or forward flow. It is uni-directional like a direct current. However, for the condition of the double energy transient the energy is reflected back upon itself between an opposing pair of energy storages. The double energy transient is a bi-directional power flow like an alternating current.
The single energy transient can be considered a traveling wave in time, the double energy transient can be considered a standing wave in time. This is in analogy to traveling and standing waves on a transmission line. Here time is an analog of length in the movement of electric energy.
The activity of the oscillatory energy exchange is given by the product of the Electro-Motive Force, E, and the Displacement Current, I. The four quadrantal activities are thus given by,
Fig, 1A, -EI
Fig, 1B, -IE
Fig, 1C, +EI
Fig, 1D, +IE
Each of the above activities exist in their respective quadrant in the cycle of energy exchange. It is given algebraically that,
(30) -EI = -IE
+EI = +IE
No energy is gained or lost, thus the activity is identical for each quadrant in the time cycle of energy exchange. Hereby a single effective activity exists for the double energy transient in its exchange of energy between Magnetic Form and Dielectric Form. This is given as in equation (24)
(24a) Po = EI volt-ampere
This is the electric activity of the oscillatory energy exchange between the Inductor and the Condenser. This is not an actual power in watts, but an electric activity in volt-amperes.
For the condition of energy transfer, the single energy transient, a pair of electrical activities exist,
eI , iE , watts.
Each represents the flow of power in the Dielectric, or Magnetic Energy Transfer. Here the charge time span and the discharge time span are independent time frames. An indefinite static time interval can exist between these two time frames. However, the double energy transient of oscillatory energy exchange has no possible static time interval, no possible steady state. Also the charge time span is identical to the discharge time span. One is the mirror image of the other, both of equal length in time. The two opposing energy transfers cancel out, just as do two opposing traveling waves. This leads to a stationary wave and one resultant electric activity only, that of the Cyclic Energy Exchange. No energy is gained or lost, it is confined to the oscillating system. This represents a stored alternating current and as such must posses an angular velocity of energy exchange since A.C. is a circular function. Hence it is,
(31)
, radian per second
Where T is the time span of one cycle of energy exchange.
This exchange is then in the form of a perpetual motion which gradually weakens due to energy leakage, that is, the losses in the metallic-dielectric geometries where the energy exchange takes place.
Power magnification in the oscillating energy transfer takes on a different form in the oscillating energy exchange. No magnification is possible between the charge and discharge portions of the cycle of energy exchange, they are equal and opposite time spans. It is however that a finite quantity of stored energy exists, and its activity is the time rate of energy exchange between magnetic and dielectric forms. A definite time cycle exists, where the transfer time, to, is one fourth the time span of a complete cycle of energy exchange, T. The transfer time defines the rate at which the stored energy is transferred back and forth, that is, the rate at which it is exchanged. Thus the relations for power and energy are given by
(32)
watt-second
(33)
watt, or volt-ampere.
Where to is one fourth period T. The Time Period, T, and thus the angular velocity of energy exchange can be derived from the Laws of Induction, these for an alternating current form. Thus given
The Law of Magnetic Induction,
(34)
, weber per second
The Law of Dielectric Induction,
(35)
, coulomb per second
Rearranging (34) and (35) gives
(36)
, and
, radians per second
And substituting the relations
(37)
, and
, Induction
Furthermore on Sept 19th Tesla also states for "obvious" reasons 3/4 wave lenght for extra coil and 1/4 wave length for secondary coil for figures 5 & 6.Originally posted by madhatter View PostWire length, the eq l=c/w would be for a straight horizontal length. However in a coil the inductance and capacitance would change that as Tesla notes in the use of inductance and distributed capacitance equations to calculate the free resonance of the coil. The frequency of charge impressed into the primary was 1600Hz per the notes and the resonance was based on inductance and capacitance at that fq in the length of the primary, it was then calculated to have the length of the secondary match that resonant wavelength based again on the inductance and capacitance.
I have another question, in previous posts you mention the wavelengths of the primary,2nd and extra as:
Primary: 1/2
Secondary: 3/4
Extra: 1/4
The notes have these relations:
Primary: 1/4 or 1/2 depending on series of both turns
Secondary: Sep 4th 1/4
Extra: Sep 4th 1/16 ; Sep 19th 1/2 per diagram #4
May be for starter we should just follow Eric's recommendation, since he has decades of on-hand experience and knows best what was probably Tesla's most successful arrangement. After that anyone is free to experiment different coil lengths wrt wave length.
The Four Quadrant Theory of Electrical Activity, Part Two, or more? (6 of 7)
Thus the relations exist for the scalar condition as analogs to the exchange condition. This gives,
(56)
, ohm per siemens
(57)
, siemens per ohm
And
(58)
, scalar numeric.
Where
Rc , the natural resistance
GcLast edited by t-rex; 02-11-2012, 04:23 PM.SUPPORT ERIC DOLLARD'S WORK AT EPD LABORATORIES, INC.
Part 6 of 7 didn't make into the sequence of posts. I hadn't noticed until Eric pointed out the missing pages. I had to delete 7 of 7 and repost it after adding part 6 of 7. I apologize about the screw up. The original scans for part one and two can be found here:Originally posted by madhatter View Postwhat's going on with the post order?
Index of /David/Four Quadrant Energy Exchange in Magnetic and Dielectric Fields of Induction, Part One
Index of /David/The Four Quadrant Theory of Electrical Activity, Part Two
When I spoke to Eric, he told me to let everybody know that he has finally grown sick of interacting with society. His driveshaft is still missing after many email attempts of getting a hold of the individual that supposedly has it. On top of that, the car parts that were promised to him have still not manifested. It seems like it is just easier for some people not to help Mr. Dollard rather than sacrifice a little time and effort...
He told me that he will be cutting ties with society as much as possible. He may write another book just for the sake of boredom as he doesn't see a laboratory becoming a reality at this rate. If there is anybody out there that can possibly do some fundraising for Eric or get in touch with him about investing in furthering his research, there is a load of equipment at a scrapyard in Morro Bay that has most everything that he would need to build a lab. Estimated cost is a couple of thousand U.S. Dollars. It would be a shame to see Mr. Dollard share the same fate as Dr. Nikola Tesla, broke and homeless (lab-less).
Eric, I just wanted to say thank you for everything that you have presented. I can guarantee that your efforts will bear fruit. It will just take longer than expected since none of us are properly funded for R&D. Don't lose hope yet.
Thanks.Originally posted by Web000x View PostPart 6 of 7 didn't make into the sequence of posts. I hadn't noticed until Eric pointed out the missing pages. I had to delete 7 of 7 and repost it after adding part 6 of 7. I apologize about the screw up. The original scans for part one and two can be found here:
I'm still trying to resolve the discrepancies of the Colorado notes, any ideas on where to obtain an accurate account?
Disappointing to hear about Erics decision, what happened with the temp coastal residence he was at?
I don't expect Eric to hand hold anyone. I've been going over the reference material Eric suggests, and so far the only sticking point is the tesla notes. Eric mentions that the design requirements are there, however I can not find the same. This is most frustrating.
Even though I have not heard from Eric regarding my offer to turn on a marketing machine, I think I'll go ahead and do it without his permission.Originally posted by Web000x View PostIt would be a shame to see Mr. Dollard share the same fate as Dr. Nikola Tesla, broke and homeless (lab-less).
I will set up a consumer cooperative, website, funding channel, funding transparency, voting board, banner ads and much, much more. As with many people, I don't have spare cash, but I do have spare time. As a marketer, I can use that to generate a cash flow for him and his projects.
Proof is in the pudding, time to start baking.
rw
Morro Bay
Let suppose with the effort of everyone on this forum we could get the required money together to by that Morro Bay stuff. But I think first we have to find out if Eric would be interested. If he is interested then a suitable lab site must be found and that will also cost money. Also the Morro Bay equipment should be checked by Eric and an accurate cost of the useful equipment be determined. Any thoughts on this matter?Originally posted by Web000x View PostPart Two[/url]
