This is probably going to go over most heads here but I ask that those who do follow and understand this to take a moment and think about it.
Snells Law, I was thinking about the relationship of electron waves and incident angles and potential charges on the inter turn capacitance to optic waves of photons. the N factor is based on the speed of light divided by the speed of light in the denser medium. In this case it's a bit backwords but none the less it applies, although in electrostatic optics it's the charge of the field and kinetic moment that determines the angle for a particle electron, it can be modified to a wave field as well.
There has to be a relationship between the wire spacing, turns etc for capacitance and a 'phase' shift and that is where impedance arises from. from some quick back of the envelope calcs it would seem that the critical angle for complete reflection is 100 degrees, although I question this as a sin theta greater than 1 makes no sense. If we were starting from the extra coil then slowing to secondary it would give a theta less than 1. otherwise it gets into hyperbolic trig again.
I could be waaaaay out in left field here, but the i+j rotation has to be somewhere, and the N factor of optics in plasma physics fits to me, filtering out relativistic terms and modifying the equations needs to be done to see what the result is.
For those not aware, there is an interesting effect with reflected waves where at just above the critical angle there is no longer two waves refracted and reflected, a prism is a simple and prime example, the 45* angle reflects the light in whats called total reflection i.e. a 100% efficient no loss on reflection and no refraction. which means I could theoretically build a trap that endlessly reflects the waves with no losses.
just a thought I had last night. need to dig into the high energy texts I have to see what I can come up with.
