3 Battery Generating System
This topic is closed.
Lt.Bearden interview with Sirius
First, best wishes to all for 2014.
And thank you Turion, Matt and all for sharing information for a better healthier world.
At 03:00 minutes Lt.Bearden he explains what is possibly (imho) with your dipole:
Pulling Energy from the Vacuum - Lt. Col. Thomas Bearden - YouTube
So the question is how to preserve/condition the dipole, and additionally which type of load does not kill the dipole.
(can we somehow use/involve a permanent magnet with the setup?)
ps. This is an piece from the Energy from the Vacuum series IMHO.Last edited by bbem; 01-01-2014, 01:33 PM.
Dave, do you think capacitance and phase shift within the system (along the lines of Luc Choquette's recent work to foster 90 degree separation of magnetic current from voltage) might have some bearing on the 3BGS phenomenon?Originally posted by Turion View PostGentlemen,
At times the setup of the 3BGS causes this to happen because you hit the battery with the voltage of two batteries in series plus the output of the motor as generator. This effect has been witnessed by many, many, MANY people on the thread, but it is short lived because the system then tries to charge the flipped battery, instead of letting it charge itself, and we destroy the reaction. Much more experimentation needs to be done with this, but I have reports from private individuals that indicate that this is indeed the key, and flipping the MAGNETIC polarity on a battery is the answer we have all been searching for. I leave this with you for what it is worth.
Respectfully,
Bob
bravo of course it does you want to hold series resonance, there is no way to measure or see the linear impulse wave . its the one that's denied. Bob
I cant do this I do not have the programming skills but you can see the parallel resonant wave .. Its a sine wave at maximum voltage and minimum current I demonstrate on this thread somewhere How does that relate to series resonance ? EPD tells you here the speed of the linear wave
Part 1 of 6: Eric Dollard Tesla Longitudinal wave Energy SBARC Ham Radio with Chris Carson - YouTube
pi/2 xc
taking then the resonant frequency that you are scanning & monitoring is F then the frequency of the impulse should be pi/2 x F. that is an Ideal state of course in practice in may be slightly different but still a constant
in this way its possible to automatically adjust the impulse frequency and so automatically track what you call 'in the zone' no motors or bad batteries required. a very sharp impulse is required of course ... what you like to call a scalar .... The phase shift you talk of Bob 90 deg is of course also known as resonance .. however Its the other one you want the one you can't see series resonance ... the electrostatic wave .. and magnetic current ... that's my take at least. if you resolve that control loop and for all I know one of these arduino things might be able to do it then a variable sine wave oscillator with a series cap feeding a FWBR A'la capacitance battery charger should answer ... all untried and untested
Last edited by Duncan; 01-01-2014, 05:09 PM.Whatever you can do,or dream you can,begin it.Boldness has genius,power and magic in it.Begin it now.
Batteries Not included
I believe only ONE battery is necessary. Just one that you have reversed the magnetic polarity on. It opens the gate.
Understand I have ONLY seen this happen when connected to the 3BGS, but OTHERS who have contacted me off thread say you CAN reverse the magnetic polarity of a battery and it will then run loads for a really, really, REALLY long time.
It has been done by connecting a battery to a generator so that the generator wants to turn one way. Now shaft couple that generator to a motor that turns it the OPPOSITE way the battery wanted it to turn, and you have a means of flipping the polarity.
I tried this with two small motors and could not get it to work. Bigger motors or generators are needed.
BUT, here is the thing. The 3BGS has done this by using a motor as gen and two batteries in series. The motor allows for the PULSING action. What if we took three or four batteries in series and tried the same thing. Remember, the battery MUST be pulled OUT of the system once the polarity is flipped. And of course you still use the motor as generator
Imhotep Leedskalnin Magnetic Current Series
Hello Turion,
Do you think the magnetic current theory of Leedskalnin is correct?
Imhotep Leedskalnin Magnetic Current Series - Episode 6 - YouTube
and
Imhotep Leedskalnin Magnetic Current Series Episode 8 - YouTubeLast edited by bbem; 01-02-2014, 01:01 PM.
Resonant RLC CircuitsCapacitive Battery Charger - John Saves Energy
If that can charge a battery regardless of how well .. if it can do anything at all useful .. and It can and does I promise you .. but I'd rather you proved to yourself .. then all we need do is vastly improve what is happening . Now I stress to add here no one including me has built anything that will track the series resonance you need to follow .. I'm going to suggest how you go about it in a little ..which of course you'll ignore, here is a very close example
http://dnp.s3.amazonaws.com/b/b5/Bat...se charger.pdf
(needless to say if you have the nous to finish this off and set it to track series resonance the games over too)
Note to 80 % in 15 Min
and he's not particularly close to resonance ! It goes without saying had he discovered the relationship between the electromagnetic wave and the electrostatic wave and employed it to track the series resonant point the game would be well and truly over.
All those bad batteries .. motors and paraphernalia had one job to do and that is produce an impulse.
Or more accurately an adjustable impulse so you can hit the series resonant point of the lead acid battery. Better by far to use perhaps a $3 H Bridge
Dual H Bridge DC Stepper Motor Drive Controller Board Module Arduino L298N JT1 | eBayPart 1 of 6: Eric Dollard Tesla Longitudinal wave Energy SBARC Ham Radio with Chris Carson - YouTubeLast edited by Duncan; 01-03-2014, 10:30 AM.Whatever you can do,or dream you can,begin it.Boldness has genius,power and magic in it.Begin it now.
Dave,
I think you need to look at this -
Bedini free energy the other side of the wall wart - YouTube
Cheers, Garry
yes . I wrote quite a bit on this a little time ago .. because electric meters were being reversed with the bedini monpole ... if I can remember where I'll link to it. Its usually impossible to see the impulse wave ... I can't quite work out whats making it visable here. Its a useful tool to have in the box no doubt!
nice post!Whatever you can do,or dream you can,begin it.Boldness has genius,power and magic in it.Begin it now.
Cheers, Garry
This is insanity at its best. Someone tell the guy to stop now before he burns his house down!
Hi WW,Originally posted by Wallywonka View Postswitching battery poles from North South to East West is what you want to do.
And we do that by what method using what resources? How can we tell when we have achieved success?
Please advise...
Best regards to all,
LutherElectrostatic charges manipulating magneto-gravitic streams...
