3 Battery Generating System
This topic is closed.
  • Originally posted by erfinder View Post
    Please forgive me for saying this Duncan, but I must. When dealing with multiple resonant harmonic frequencies, at resonance the wave isn't sine, its square. Technically it could be any shape, I see square waves even at resonance in my systems, I again point out the fact that I am dealing with "multiple harmonic frequencies" I restate that to make it clear that there is a huge difference between single frequency resonance, and multiple resonant harmonics operating at a common resonant frequency. I personally think the latter has more to do with whats going on in the 3BGS, this owing to the connections between batteries and motor.
    you don't need to restate anything erfinder I noticed your reference to harmonics regarding your machine before ..IMHO the 3bgs is absolutely nothing to do with harmonics at all! neither if your machine works on harmonics is there any relationship. Further IMHO the 3bgs certainly has nothing to do with single frequencies (apart from the resultant of course) or resonance as your contraption does. The 3bgs runs on "stochastic" resonance which is a very different thing. That you are dealing with harmonic resonance is a very different concept that IMHO is of no concern to this system which is current based. It is also obvious and blatent that the 3bgs does not produce a square wave or a triangle however as Matt asked and I have just explained there is no waveform to see only the transition perhaps you didn't read the whole thing. its obviously the concept I wanted folks to understand and thats why I posted a parellel resonant video ... however unlike your machine .. this isn't Anyway thanks for your post kind regards
    • Originally posted by Mario View Post
      @Matt. Thanks, I'll draw the schematic as soon as I get a moment.
      @Duncan, it all depends on how you look at things. I know the difference between series and parallel resonance, and I've done quite a few experiments with this. You're talking about an ac source with a coil and cap in series, ok, but what if the source is the secondary of a transformer... it's a coil and it's in series with the cap, stick a low resistance load into the circuit between cap and coil and the load gets the amps and almost no voltage. This is what's shown in the vid.
      What I mean is, drive a parallel tank circuit from a source and at resonance the source doesn't have to supply almost anything, while a series setup at resonance is almost like a short to the source, from ITS point of view. BUT in this case the source of the tank IS the coil (since it's the secondary of a trafo).
      @ resonance the primary has to supply very little, while in the secondary circuit volts and amps are maximized at resonance, the load sits in between cap and coil and gets all the amps, the lower its resistance the better the Q of the resonance, and the more amps will circulate in there, and the lower the reflected load on the primary.
      Personally I think this does not relate to the 3BGS, at least not in this way of resonant thinking.
      Mario
      Part 5 of 6: Eric Dollard & Chris Carson Tesla Longitudinal Wave Energy SBARC Ham Radio - YouTube
      • Duncan, I wonder. Have you ever done hands on experiments on the resonant subject or are you just talking, repeating and assuming (and mixing) different things you heard or read somewhere?
        I really want to know. If what you're saying is based on your experience, show and build a circuit that does what you say. If you haven't done that, or don't intend to, then please say so as I don't want to waste time with endless discussions about thousands of theories that float around.
        Mario
          Mario
          ah well straight from the hip .. haven't you read though this thread Mario? here's the basic concept outlined long ago
          3bs - YouTube
          I did it again with series resonance and ossies circuit .. up through the x6 resonant cascade. I'm certainly not going to try and do your home work for you. and as for wasting your time .. like every one else .. you pays your money you takes your chance. whichever way the cards fall tracking and holding the position is a different matter
          like a spice girl who really really wants to know .. now you do,
          I
          • Some practical experience
            The self charging phenomenon of a conditioned battery has some "rules".
            1 "Use it or lose it".
            The phenomenon unfortunately goes away if the battery is left alone for several days. Missing this point could explain some wide discrepancies in testing.
            ie you go away for 2 weeks, put the same circuit on and it performs badly.
            2 Once conditioned a battery charges up with conventional charging much quicker. So there's a double wammy effect. I personally have charged a battery bank of 4 heavy duty batteries with nothing more than a 12 volt power supply.
            3 To condition a battery requires cold electricity. The terminals feel icy to the touch.
            Bearing these points in mind could be the difference between a massive success in testing or just a marginal success.
            Turion: You once had a huge effect when charging your father's battery array. Can you remember the circuit you used. ie what was the configuration of your father's battery bank? The info may give us some clues. If you have already posted the circuit diagram could you point me in the correct direction please?
            • Originally posted by a.king21 View Post
              how odd aking your bullet point 2 is actually at variance with Bedini who seems to think a conditioned battery charges up slightly less efficently on conventional chargers .. still its uncharted on the map isnt it ... "There be dragons"
                Not to speak for David but I am sure it was just the simple 3bgs with the output to the charging battery bank.
                Matt
                • Duncan, I don't want anyone to do homework for me, I'm doing that myself don't worry about that. I was trying to understand where you are getting at. Apparently there is resonance in batteries, and according to Bearden and others it's in the Mhz range. I have been sweeping frequencies up and down too a while back, by pulsing the batts with a mosfet up to the Mhz range. I don't know how you connected things together in that vid but I couldn't find a resonant point back then.
                  Mario
                  • you are correct Matt David told me the same thing at the conference .. it was the original set up with the original motor that he took to his Dads place.
                    seems he had a couple of really good "bad batteries" that kept going for a long long time ... in fact he thought they were pretty much indestructable.
                    you can imagine then his dissapointment when eventually it all stopped happening. I dont remember what motor it was .. certainly not a razor
                      Mario
                      home work only joking Mario and to be quite honest I cant get on firm ground with the battery resonance theory either .. except that it is there and I would suggest an extreamly high transfer impedance is the deciding factor as to if you can see it .. or not. In that particular case the battery was simply showing parellel resonance ... scope ... functon gen ... all in parellel . on that ocasion I just wanted to demostrate that a lead acid battery did have resonant conditions . I then went on to build this circuit of ozzies
                      The Callanan's Infinite Power Supply (IPS) : Full tests report by JL Naudin
                      The only reason being I wanted to put the battery in the middle leg of that transformer so I could adjust frequency in a series condition . I then did pretty much what I have just described to Matt .. I discoved that there is a cascade of resonant points ... you can see the trouble I had to hold resonance in the first video ... series resonance was much harder to find and hold so I had no chance of getting that on video .. I did post a picture of the circuit cobbled together in a lunch box somewhere however.
                      I'm not saying with 100% certainty I have everything covered here .. but you need to be aware of the possibility
                        Mario
                        Marcus Reid Crystal Converter Battery - Casimir Effect - Part 1 - YouTube
                        except we know it isn't electromagnetic .. rather electrostatic (because its a ground wave) however It still doesn't tell us what quadrant we are receiving from . And doesn't really help anyone to hold that sweet spot (if you don't want to call it resonance) also I suggest if you listen to this carefully you'll also hear the battery changing polarity ,, which of course everyone is making much ado about
                        • My dad's battery bank setup was entirely "home made" He had two long copper coated grounding rods secured to an 8 foot piece of plywood. (one was + and the other was -) The plywood was attached to the metal wall of his shop. In front of it was his row of 6 volt batteries. Two batteries were connected in series, and then each of his battery pairs was connected to each of the two grounding rods. (There were nine pairs, or 18 batteries. I do not know the amp hours of those batteries, but they were not small. I just called my dad to find out and he doesn't know and is too tired to go out and look. Power from his solar system on the roof was fed into one end of the copper rods through a voltage regulator. We disconnected the regulator from the rods and hooked up the 3BGS directly to the rods off battery 3. So all the battery pairs in his setup were in parallel with battery 3. It was the standard 3BGS circuit with a whole lot of batteries in parallel with battery 3. That's it. At the other end of his two rods he had an inverter connected, but we also disconnected that for our test.
                            Ding! Ding! Ding!
                            _
                            • Skeptic and all,
                              Here are two short videos from my setup of the water pump test. The first is the voltage readings on my batteries. The second is the pump running and pumping water with all batteries connected in parallel so that any voltage in all of the batteries can be used to keep the pump going.
                              Water Pump Test 1 - YouTube
                              Water Pump Test 2 - YouTube
                              • Originally posted by Duncan View Post
                                Yes, but Bedini uses a massive cap dump. I'm talking about pure radiant energy without the cap dump.
                                I've just built a mechanical Tesla switch type cap dump charger and it messes my ou batteries up! So remember there are two Bedini ways to charge batts.
                                1 Pure radiant aka 3 battery setup aka school girl motor-gen and
                                2 The "Tesla charger" way where he charges a cap and dumps 180 degrees later.
                                Incidentally the resonant point is........ 2 SECONDS!!! (with the Tesla charger).
                                ie one massive cap dump every 2 seconds.
                                And the best batteries are.... Gel cells! (Now where have we heard that before lol)
