Thanks T-1000... If your using video signal generators I'm most likely going to have to find another way if it's possible. I don't have the funds to invest in any equipment at this point in time. Have to use what I have, I'm stuck with lots of parts and my creativity for now.
Wesley or stivep1 video high voltage&frequency OU
There is only basic concept in wiki.Originally posted by dragon View PostThanks T-1000... If your using video signal generators I'm most likely going to have to find another way if it's possible. I don't have the funds to invest in any equipment at this point in time. Have to use what I have, I'm stuck with lots of parts and my creativity for now.
Any circuit from old TV set would do a job because their design is to control horizontal and vertical refresh on display.
You will need 3 of them(2 in beginning):
One for 51 turns coil resonance;
Second for 50Hz(+/- few hertz) on 15 turns coil;
Last one for making spike signal on copper plates with ferrite core resonant frequency (emulate spark gap discharge and that is experimental and is not tested properly):
P.S> HV discharge or generator should fire on 50hz(15 turns coil) and resonant wave peaks(51 turns coil), in ideal world, where they intersect on top(bottom part of pic): http://freeenergylt.narod2.ru/aidas/5.png
Good luck!Last edited by T-1000; 11-04-2011, 04:01 AM.
Hi T-1000Originally posted by T-1000 View PostThere is only basic concept in wiki.
Good luck!
What kind of signal we need for tuning...
Square, sine, something else? what frequency range?
PS...you are doing awesome things on this....I'm excited just by reading all this
gogreenbuildyourownmotionlesssolidstatefreeenergy. flv - YouTubeMindFreer's Channel - YouTube a/ also mindfree'r b/ rapidly moving magnetic flux and c/ This video has also been erased off you tube
There have been very few successful replications because a quirk of the system is the first drive has to be speed controllable and very efficient.
That led me to consider where the origins of this machine might have been formed and that leads to some almost forgotten work done in the 1950s combining the observation and experimentation of a French Prof Professor Maurice Allais - a genius before his time - as are they all Who noticed and then proved an anomaly in the action of the simple pendulum The work of the good prof was picked up by a particularly skilled watch and Clockmaker who went on to construct a mini mechanical universe complete with gravity and magnetism
In order to prove the work of Prof Allais. This work drives a coach and horses through current teaching.
Raoul Hatem made no attempt to patent his OU work who's benefit to the public good is obvious .
neither did he wish to attract the attention of of the American sharks and so for a long time he has been helping people install multi KW working systems like this one
New Free Energy by George Mitchell - YouTubeLeon Raoul HATEM -- magnet motorAt rest (a) the magnets of both the drive and the slave rotor will fall into balanced equilibration at a point of equal attraction.
When the driven rotor is turned (b) there must be a certain amount of slip between the drive and the slave, The tendency is for the slave to accelerate in an impossible attempt to come into synchronous lock with the drive.
Of course should the drive be accelerated to fast or the load be increased to fast beyond a certain point the synchronous link is lost.
If the magnets are still an attraction, but the alternation create a sort of detent natural limit slippage.
The magnet blue central line is red attracts the magnet on the left, but if there is slippage, not only the magnet will retain the red blue, but the magnets are in the same orientation is also pushing to participate in maintaining magnet blue right in his window.
Whilst it is difficult at first sight to deduce a mathematical foundation for this natural acceleration effect in the first instance. It is possible to make a direct comparison of magnetic forces by alternating the magnetic poles. At rest (a) the driven rotor and the slave are again in balanced equilibrium.
However when being driven and slippage occurs there is natural cogging and the tendency is to retard.Last edited by Duncan; 11-04-2011, 01:34 PM.Whatever you can do,or dream you can,begin it.Boldness has genius,power and magic in it.Begin it now.
addendum
A pleasure Monsieurm I Just hope I'm pointing at the right trackOriginally posted by MonsieurM View PostPrinciple of Mentalism: the Universe is all Wave....
thank you for the lesson
ps: the same principle you mention works as well for a Muller generator
WOW This is attracting some readers may I try a little more tentative crawling forward with a little guess work ? I here assume what is thought probable is actual fact !! It is probable that Luminous Etheric energy is a linear wave why??? Eric P Dollard says so and demonstrates it one or two years ago here Part 1 of 6: Eric Dollard Tesla Longitudinal wave Energy SBARC Ham Radio with Chris Carson - YouTube
ThaneCHeins's Channel - YouTube
F.M.CHALKALIS ENERGY MULTIPLIER - YouTube
TARIEL KAPANADZE EVERYTHING .. WE KNOW FOR NOW..swf - YouTubeLast edited by Duncan; 11-06-2011, 12:20 AM.Whatever you can do,or dream you can,begin it.Boldness has genius,power and magic in it.Begin it now.
PART#1 of article:
[in regards and addition to article that was QUOTE=T-1000;165188]Draft for tunning instuctions:
Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
[/QUOTE]
YOU WANTED COMPLEX INFORMATION IN ONE PLACE ...SO THIS ONE IS LOOOOOOOONG BUT PROVIDING WITH MOST OF DETAILS THE REST WILL BE DONE BY ARUNAS
Note that steps of me and Arunas differ a litle that is because of personal experience between to of us. Do not disregard Arunas notes ( post below my post) both approaches should give you desired effect
Quote from: grizli on November 03, 2011, 09:06:30 PM
I will connect my questions with yours
WILL device work if 50hz and 386khz are NOT synced ?
IT WILL NOT.. THE FREQUENCIES ARE NOT ALWAYS THE SAME as properties of ferrite are not the same.
I have got ferite cores just few minutes ago... American made and will attempt to check them out. I have 6 of them two of them are different.. the ferrites are in different shape more cylindrical and just smaller.. I have paid $5 per one. plus $28 shipping charges.
Do not count on fixed frequencies.. The whole process is not that easy as it looks like..
1 . connect 50 winds to Vector Network Analyzer output
2 . connect (ekran) shield / cooper strip winding to output.
3 .analyze if you see pick on 1.2Mhz to 1.8 Mhz
4 .than connect generator with square or ramp at frequency of pick say 1.3 MHz to (ekran) shield / coper strip
than tune it left right to maximum amplitude of 50 winds ( OSCILLOSCOPE AT OUTPUT)
5. than read the frequency and voltage on 50 winds ( OSCILLOSCOPE AT OUTPUT)
6. than connect generator to 50winds with frequency of readout
ALL OF THE STEPS SHOULD BE DONE WITH ONE GENERATOR ONLY!!! AT THE TIME..
7. tune that generator to maximum voltage on bifilar output.( OSCILLOSCOPE AT OUTPUT + hv probe)
8. than connect second generator to 15 winds at starting frequency of 50 Hz ,and tune it to maximum at bifilar
9.connect flyback to (ekran) shield / coper strip winding and give one spark only
10. see the response on oscilloscope and/or light bulb at bifilar output.
11. re tune circuit with two generators readjustment//
method #2
instead of point 1.
connect generator square to 50 winds
and connect spectrum analyzer at (ekran) shield / coper strip winding
look for more than 1MHz pick..
than fallow the other points of instruction
ARUNAS:
5 minutes ago correction from Arunas:
quote"[4:47:10 PM] Arunas point # 3 ."analyze if you see pick on 1.2Mhz to 1.8 Mhz" -> see where is peak on spectrum analizer when white noise is fed into copper plates"
[4:49:14 PM] Arunas point#: 5. than look for lowest harmonic resonant frequency of 50 winds coil with highest amplitude ( OSCILLOSCOPE AT OUTPUT)
[4:51:00 PM] Arunaspoint#: 8. than connect second generator to 15 winds and tune it to maximum at bifilar
( OSCILLOSCOPE AT OUTPUT). It should be low frequency around 50Hz. Look for best match between 2 frequencies so low frequency will be carrier of 51 turns coil frequency(in our case it was 47 Hz)
[4:53:15 PM] point#: 9.connect flyback circuit with spark gap from our first experiment schematics to copper plates and tune variable capacitor attached to copper plates for maximum output.
[4:54:34 PM] Arunas Note: this most likely will heat up ferrite core and destroy it after 15-20 minutes
[5:00:47 PM] Arunas Note#2: Arunas -Note#2:" -For impedance match you will probably need unwind secondary coil or wind more wire on it. The method determining that is: if you touch with one of secondary coil wires with finger or additional wire which would be as antenna and see more bright halogen, you need more turns on secondary. If halogen bulb brightness fades, you need less turns on secondary coil.
Note from Wesley:
if you have impedance meter that is capable of choosing particular frequency and or display impedance at desired frequency (50 ohm between output of commercial generator.. than connected winding will be a load to the generator in such way that after bifilar is connected with load than you measure impedance with
a- generator disconnected and impedance meter connected to 50winds winding than 15 winds winding NO POWER!!!!!!!!!!!!! NO signal delivered!!!!!!!!!!!but light bulb connected!!
b- you can also try to take few meters or bundle of wire and instead of inactive test make test on load you either cut the wire piece by piece or play with variable capacitor in series with the wire.. only one end of wire should be connected to say (15winds)(in my case16 wind winding)
Note#2 from Wesley:
that what Aidas called copper plates = what I called (ekran) shield / coper strip winding
Note#3 from Wesley
The confusion about impedance:
Explanation.
12.
electrical impedance is:Impedance - Wikipedia, the free encyclopedia
-the ratio of the voltage phasor to the electric current phasor, a measure of the opposition to time-varying electric current in an electric circuit
Wave impedance is:
-, a constant related to electromagnetic wave propagation in a medium
Impedance of free space is:
-, a universal constant
Mechanical impedance is:,
- a measure of opposition to motion of a structure subjected to a force
( that might be important only for mechanical response of our ferrite to the frequency response in resonance ( hissing sound of ferrite)
or for copper wire vibration:
Flexural vibrations induced in thin metal wires carrying high currents
13. application
a. output impedance of regular commercially available generators is 50 Ohm
b. for impedance match each coil must have 50 ohm impedance
c. when impedance is matched that capacitive Reactance and inductive Reactance may be uneven and still you will have 50 ohm of coil impedance;\
Say in one scenario
- coil has capacitive character and less inductive
in another scenario
coil has inductive character and less capacitive inductive
and still will maintain 50 ohm impedance match..!!!!!!!!!!
when coil character ( LC network character) is capacitive in nature than it represent higher voltage THAT IS WHAT WE NEED !!!!!!!!!
THIS PART IS IMPORTANT TO UNDERSTAND THE ESSENCE OF HOW TO TUNE COIL.
-every coil is the load to the source.so
15 winds coil is the load to generator
50 winds is a load to second generator
but because the coils are coupled to bifilar than their impedance will change when bifilar is introduced and/or paper dividing two halves of ferrite ring
-every coil is RLC network to the feeding device( generator)
Even when not connected to generators ...coils will have different impedance when load light bulb is connected to bifilar and not yet under power..
You will see that, when ready to use ferrite ring with light bulb connected is examined and you connect impedance meter to each of winding 15 or 50 ohm ( in my example 16 and 51)
PLEASE DO NOT SKIP THIS FEW LINKS AND PLAY WITH CAPACITANCE AND INDUCTANCE IN INTERACTIVE GRAPH You will understand capacitive and inductive dependencies while maintaining 50 ohm.
9. Impedance and Phase Angle
go in the midle of the page to:
Click where it says "Start"
than play with sliders try to get maximum capacitance and minimum inductance
at 50 ohm and look how voltage and current lag each other..
look at:25.1 Capacitance and inductance Capacitance and inductance
Phase shift
3. Graphs of y=asin(bx+c) and y=acos(bx+c)
go to :Flash Interactive
Play with it.
What we have access energy from? remember this is just my assumption for the present moment.
go to :Resonant Amplification of Magnetic Domain-Wall Motion by a Train of Current Pulses
The current-induced motion of magnetic domain walls confined to nanostructures is of interest for applications in magnetoelectronic devices in which the domain wall serves as the logic gate or memory element. The injection of spin-polarized current below a threshold value through a domain wall confined to a pinning potential results in its precessional motion within the potential well. We show that by using a short train of current pulses, whose length and spacing are tuned to this precession frequency, the domain wall's oscillations can be resonantly amplified. This makes possible the motion of domain walls with much reduced currents, more than five times smaller than in the absence of resonant amplification.
- for pulse density modulation affecting signal go to :
Pulse-density modulation - Wikipedia, the free encyclopedia
We are dealing with pulses and pulse modulation as well a density.
Look for part#2 of the article
WesleyLast edited by stivep; 11-04-2011, 03:46 PM.
Part #2 of the article
Note that steps of me and Arunas differ a litle that is because of personal experience between to of us. Do not disregard Arunas notes both approaches should give you desired effect
for phenomena in ferrites go to:
-easy lecture: atomic orbitals
- to more advanced who want to understand how copper ring reacts:
Composite Medium with Simultaneously Negative Permeability and Permittivity
- for these interested with understanding VNA and spectrum analysis easy to read
or
Network Analyzer Basics
this is easy do not be discouraged
very important is to understand this material than less questions I will have to answer
2.Basics of measuring the dielectric properties of materials
a.Resistivity
b.Dielectric constant
c.Permittivity
d.Permeability
e.Electromagnetic wave propagation
f.Dielectric mechanisms
g.Electronic and atomic polarization
h.Orientation polarization
i.Ionic conductivity
j.Interfacial or space charge polarization.
3.Measurement systems
a.High resistance meters
b.LCR meters and impedance LCR meters
c.Network analyzers A measurement of the reflection from and/or transmission through a material
Resonant transformers:
For more details on this topic, see Resonant inductive coupling.
A resonant transformer is a kind of leakage transformer. It uses the leakage inductance of its secondary windings in combination with external capacitors, to create one or more resonant circuits. Resonant transformers such as the Tesla coil can generate very high voltages, and are able to provide much higher current than electrostatic high-voltage generation machines such as the Van de Graaff generator.[52] One of the applications of the resonant transformer is for the CCFL inverter. Another application of the resonant transformer is to couple between stages of a superheterodyne receiver, where the selectivity of the receiver is provided by tuned transformers in the intermediate-frequency amplifiers.
For these who is not familiar with practical electronics:
this material is only for purpose of HOW TO BUILD VARIABLE TUNING CAPACITOR HV?
Electronic Bennet's doubler
Pfaff and Svanberg multiplier
this is interesting material I have to get closer to it:
Gyrator
it might be applicable . logic might be the simpler way to create tun-able generators.
Simulating Electromagnetic Interactions in High
Power Density Converters look at drawings
PERMANENT MAGNET AIR-CORED TUBULAR LINEAR
GENERATOR FOR MARINE ENERGY CONVERTERS
look at drawing and power factor notes.
Figure 5 : Axial force verses position for constant current
Figure 7: Tubular Machine Translator !!
Figure 12: Comparison of predicted and experimental voltage
for a 17 Ohm load
9. Conclusion
An Introduction to Barkhausen +44 (0)1981 541122
Noise and its Applications
Chapter 10. Phase Transformations in Metals
Former Army secrets:
EVALUATION OF DEVELOPMENTAL HIGH TEMPERATURE
PULSE FORMING NETWORK, Z-2922
MANUFACTURED BY SPRAGUE ELECTRIC COMPANY
NORTH ADAMS, MASSACHUSETTS
look at :
4. Comparing the standard AN/APS-45 pulse-forming network in the modulator circuit with the sample network indicated that the parasitic
oscillation was present only in the sample network. Principally, parasitic oscillations result from impedance mismatches. Many times these
mismatches are caused by stray inductances and capacitances. In this
particular case where the active volume of the network was reduced by
the incorporation of the expansion compartment, it is possible that the,,,,
(read to the rest of it)
Radars have been modulated by spark gap:
Q-16. What is nonpulse time?
Q-17. What is average power in a pulsed system?
RADAR MODULATION
RADAR MODULATION
RADAR MODULATION#2
Radar modulation
This is how pulse- forming network is made
Radar Basics - Radar Modulator
Figure 3: charging currents path
PULSE FORMING NETWORK (PFN) FORMULAS
look at:Type A PFN and drawing below
Ness Engineering Tech Data - Pulse Forming Network Formulas
Practical explanation and advise to standing wave and terms used by ARUNAS
NODE AND ANTINODE
The Physics of Resonance
Standing wave:
Bill B's 3rd crackpot theory: walls made of standing waves
Materials:
-take deflection yoke from old TV the one that is on the CRT tube take ferrite out of it by puling gently snapping spring brackets out
-wire 18 gauge 50 winds in plastic insulation recommended
-wire 18 gauge 15 winds in plastic insulation recommended
-wire 18 gauge 150 winds x2 bifilar (in plastic insulation recommended)
- HV transformer ( no diodes build in!!!!) make sure that in plastic coil there is no diodes molded and you have access to windings of transformer directly
deflection yoke and ferrite cores for it:
everything about it
Yoke E70954(S) Cathode Ray Tube CRT Magnetic Beam Deflection Assembly
Sci.Electronics.Repair FAQ: Notes On The Troubleshooting And Repair Of Television Sets
DEFLECTION YOKE CORE - B. L. K. FERRITES PVT. LTD., C-105/4, NARAINA INDUSTRIAL AREA, PHASE-1,, New Delhi, India
23.2: Development of New Ferrite Material for Deflection Yoke Core
Series For Deflection Yoke Core(ceramic) - YOUNG JIN CERAMICS.CO.,LTD
weclome to DMEGC
Anything more in another book
Wesley
Part#3 addition to part #1
YOU WANTED COMPLEX INFORMATION IN ONE PLACE ...SO THIS ONE IS LOOOOOOOONG BUT PROVIDING WITH MOST OF DETAILS THE REST WILL BE DONE BY ARUNASOriginally posted by stivep View PostPART#1 of article:
[/QUOTE]
The reason he decided to do it this way is because we have tried at my lab to use sweeping generator from Vector Network Analyzer only at frequency range from say 0 to 2 MHz ( we did not use VNA at that very moment to measure but only to sweep. (as if we have had sweeping generator)Quote from Arunas:1.
Quote
Connect 51 turns coil to Vector Network Analyzer output / Spectrum Analyzer intput
2. Connect cooper plates half-ring winding to generator with white noise output.
Instead of that you can use Sweep Generator SG
The sweep generator is fast scanning generator and because of FF analysis at Spectrum analyzer you are able to see all of the spectral components and desired 1.3 to 1.5 Ghz.
The faster is the sweep generator the better is display of Spectrum analyzer.
but if you want to tune it manually as long as you have manual sweep generator you are able also to see that effect.. only with much greater difficulty..
Note that generator must maintain steady voltage at given range of frequency swept.
such as LEADER LFG-1300S
Molecular Expressions Microscopy Primer: Light and Color - Electromagnetic Wave Propagation - Interactive Java Tutorial
The Tom Bearden Website
Wesley
Ok, here is some food for theoretics
Corum Ball lightning
So, instead of making ball lightning, we're about to use this energy for our electrical circuits ...Originally posted by N.Tesla View Post"...it became apparent that the fireballs resulted form the interaction of two frequencies, a stray higher frequency wave imposed on the lower frequency oscillations of the main circuit....
This condition acts as a trigger which may cause the total energy of the powerful longer wave to be discharged in a infinitesimally small interval of time and the proportionately tremendously great rate of energy movement which cannot confine itself to the metal circuit and is released into surrounding space with inconceivable violence. It is but a step, from the learning how a high frequency current can explosively discharge a lower frequency current, to using the principle to design a system in which these explosions can be produced by intent." -N. Tesla
OK,Originally posted by T-1000 View PostOk, here is some food for theoretics
That looks like fun I think I might try to make that ball lightning
generator. Thanks for the link.
you touched the essence. Radiant electricity secret !
this is mighty interesting....thanks for the article...i posted an article written by the same authors here: http://www.energeticforum.com/renewa...d-true-48.html; thanks T-1000Originally posted by T-1000 View PostOk, here is some food for theoretics
I found this in the ref mentioned in the article:
RF coils, helical resonators and voltage magnification by coherent spatial modes
helically disposed surface waveguide, but also its resonances, ′self-capacitance′ (so-called), and its voltage magnification by standing waves. Further, the Tesla coil passes to a conventional lumped element inductor as the helix is electrically shortened.
And here is the inductance calculator based on the previous post: RF Inductance Calculator - HAMwaves.com
ps: did i mention the presence of silicate dust in the air
