Wesley or stivep1 video high voltage&frequency OU
  • question for T-1000 or STIVEP or WESLEY or....
    1) You've told us that consumption of 10W from yours supply(on 18T/50T). On HV side, how power do you have?
    2) I see in yours foto, on side with 150T, some caps(I think three...) 6800pf/3KV placed aprox. in the middle of the winding. Please can explain how many turns have between terminals of the caps? or how many turns remain between start - end of coil? or which is the position on coils(also nr. of turns)?
    • Originally posted by TAURADA NUTAD View Post
      Taurada, try to get a hold of them at overunity Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
      • replay to Tektron
        Thks!
        • New experience from Wesley:
          First Light of Hope in 2012 investigation of OU - YouTube
          Have fun!
            Have fun!
            Hi T1000 and all your team, like we say in quebec, felicitations....
            you're on a track now, a really good one.
            merci pour tous vos travaux.
            • More details needed
              Originally posted by Kokomoj0 View Post
              They hate that!
              There are no power measurements made LOL
              If it lights a bulb everyone seems to lose their minds and run off the cliff!
              The first thing I noticed is that he could not even read the voltage with his meter because the frequency was to high for the meter to respond to.
              So I guess I will help these guys out not that it will give pause to the stampede LOL
              Ok here you go peeps,
              You all need to build 2 or 3 of these and correctly size them for your project.
              You can measure either current by placing it across a series resistor to your device or across the input or output of your device directly, or any part of the device you wish to measure. You will need to make sure they are matched precisely to each other if you want to insure accuracy.
              It is to convert whatever gooblety gook you have for a wave form into dc because even the dumbest meter in the world can measure direct current and you do not need to worry about meter specs. so much.
              Now this will not give anyone the correct voltage, IT IS NOT MEANT TO DO THAT! It is meant to give you very accurate "COMPARATIVE" measurements between inputs and outputs. The exact voltages are relative and irrelevant.
              Farm this is another case where the inventor does not know how to "measure" his device and as we all know 99.99999% of all OU devices fail because people do not know how to "PROPERLY" measure them.
              Now if I see a similar circuit to the above used to make measurements on OU devices or those like Dollard uses then I am all ears, otherwise I write virtually all these gizmos off because people do not know how to properly measure them and they look kool but will not work or produce ou.
              ciao
              Hi Kokomoj0,
              for this schematic you have posted, do you have any other info on bridge rectifier diodes and capacitor nominals, as well as the final load resistor ??
              This apparently is very useful tool for non-linear measurement.
              Please advise,
              Thomas
                Have fun!
                Dear T1000 ,
                On Zariad forum was information that there is second part video of yours device
                successfully tuning .
                Is it possible to find it in internet ?
                Osiakosia
                "Nothing is impossible , except that the state of your mind makes it so '' . Prof John R.R. Searl
                • http://www.energeticforum.com/renewa...tml#post169677
                  Here you can see my start :
                  Colas07 Whith unconditionnel love.
                  • What is the resonance fequency of your yoke device ?
                    • i dont know yet ! I'm little too busy at work...
                      But befor trying to connect it, i want protect my frequency generateur ! and i don't know how protect it ! I still waite for an aswers...thanks if you know !
                      • Originally posted by colas07 View Post
                        Hi,
                        IF your generator has a high enough output level, higher than what your tests need, then the simplest protection is to use a low wattage resistor network like T or Pi attenuator so that the resistors can smoke before any kick-back pulse would reach the generator output. For this, use at least two stages of attenuators in series with capacitive coupling between them.
                        Another possibility is to use a MOSFET driver IC (like TC4422 etc) which is driven by your generator but this has to have as high DC supply voltage as your test actually would need from the generator directly of course. In case of trouble the driver IC smokes but your generator output remains ok. Notice that such driver ICs put out the full supply voltage when their output is High so consider its supply loading capability together with the output current capability of such ICs when you attempt to load their output with a very low resistive coil.
                        Good luck.
                        Gyula
                        • OK ! this is good for you ?
                          I have already make this amplifier, it can output 20W HF. it is very good around 1 Mhz to 5 Mhz, the output signal is very pure at this frequency...
                          I have to make an other one for the 50Hz coil...or i can simply use a transformer with a resistor to limit intensity , because in French we have 50Hz in home power.
                          resistor like that :
                          amplifier like that :
                            Then nothing is connected to copper plates the amplitudes is not very high .
                            In my experiment they nor exeded 600 V .
                            At first you must to know the Frez of core to decide what equipment to use .
                            The old ПЦ 90 russian cores have it on 1.5-1.9 mhz . Other experimenters on
                            overunity.com
                            use yokes from modern TV sets and CRT monitors and have Frez on 3-5 Mhz .
                            There you can find summary of the posts from overunity com regarding yoke device experiments .
                            • Hi colas07,
                              Yes that HF amplifier is very good. You can improve its linearity and its bandwidth by using a resistor feedback between transistor collector and base electrodes. Just connect a 1kOhm (or maybe 680 Ohm only) between collector and base via a series DC blocking 100nF capacitor. However the "penalty" is a reduced amplifier gain of course but bandwidth may widen down to the 150- 200kHz lower limit and up to and beyond 10MHz or so. Of course if you do not need it, do not use feedback.
                              Regarding the 50Hz amplifier, have you considered using audio power amplifiers? There are either "HI-FI" amplifiers or you can build one from integrated circuits, see here: TDA Amplifier Circuits
                              You show a wire wound variable resistor for the 50Hz power control: well it seems ok (depending on the power level of a few Watts) but remember a transformer works in both direction equally good so a kick-back from its output goes back (albeit transformed) to its input where your generator output is connected so isolation in this respect is not really insured. MAybe with the resistor divider T between your gen and the transformer input and the potmeter you show and placed at the transformer output could give a better protection. An amplifier is surely safer...
                              rgds, Gyula
                              • Nice replied ! I feed back when i know my core frequency...
