Interesting post by Dunfasto that seems to support what you say, Dave:
Link: http://www.energeticforum.com/renewa...tml#post238315
As you say, it's a question of finding an efficient way to strip electrons from the magnetic field. You have described how the direction of windings will enable us to carry voltage in one direction, and current in the other.
If the interplay between magnetic lines of force and the LC circuit in the basket weave - cap arrangements facilitated this process for Hendershot, are you looking for a silmilar, but simpler kind of setup to enable this electron "stripping" to take place?
Or is the setup you're seeking perhaps more to do with the aether, voltage and current in coils and less to do with the earth's magnetism?
Bob
all energy comes from either ground or air. resonance is a way reverberate matter with small energy input using harmonics 1/4 wave harmonic can induce resonance in full wave harmonic. we always need earth for two purposes for grounding high voltage and to capture electrons. where as when we capture electrons from air we need to use magnetic lines of force which are neutral so electrons dont show up we have to split magnetic force by using L and C the way hendershot showed us. thus voltage and current are separated and utilized by an oscillator to produce power.
magnetic lines are hellical structures and inert in themselves we have to split them to use.
ground has free electrons just need to be pumped up. pump can be magnetic or electrostatic. magnetic pumps acts better as they utiilize earhs magnetic lines of force aswell as earth electrons. so dual advantage.
Bob
It would seem the frequency would be mirrored, would it be in phase or out of phase with the pulsed coil.
