The electric field of a magnet
  • Bumped up because of spam.
    • Dave , i don't know if you have seen it but i think it is worth checking it out
      A I R Magnetic phenomena's 2012 - YouTube
      Signs and symbols -Confucius.
      • Here is what I believe. Energy on secondary is a copy of energy of primary. Hard to believe but this is it, if you eliminate Lenz law.
        • Originally posted by Dave45
          Coming to a theater near you soon
          Im having to much fun
          then you are Alive .... any trailers before hand
          looking forward to see the results of your tests
            Ezechiel's wheel within a wheel
            • Ezekiels Wheel is the first recorded "Machine" in History. Two intersecting toroid fields has been my prime study. Its a difficult configuration to deal with and not much experimentation is done with it.
              Just one idea I have on it is a toroidal Pmh with the poles being separated somehow at the intersects of the "wheel". One pole on each intersect. The magnetic current flow stays inside the materiel though. Question is can you access the magnetic current at the intersects,think cavity where the 2 toroids join,and use it to generate an electrical field in the other toroid.
              Then there is pulsing an electric current through one toroid creating a magnetic field in the other.
              • Dave ....check this out :
                a wheel within a wheel
                The Vega Science Trust - Electrical Generator Demonstration
                might interest you .. a simple test yet much to be learned
                he has a nice youtube channel with all kinds of test ... the one i was looking for was graphene
                VegaScienceTrust - YouTube
                • Dave , what will you be seeing ( the blue circles drawn will be facing you ) when you look at your set up side ways
                    Looks like one could move through the inside of the other eh
                    indeed, however keep in mind that the South pole ( - sign ) is smaller than the North Pole .... so in the drawing the Negative Pole with arrows would be a bit smaller ( asymetry )
                    Think of it this way, The South Pole Wheel has to fit within the North Pole Wheel a Standing Wave
                    North Pole and South Pole ( look closely at the circles )
                    an Alchemical Analogy for you would be:
                    When the Sun meets the Moon (the sun is larger and More immaterial than the moon )
                    the same is shown here :
                    • Apply that pic to the 2 intersecting toroids. If I remember correctly the Rodin coil math showed the zero point below the center. That would be the approximate location of the white circular dots in the pic.
                      Just an observation.
                      • Nice designs Dave
                        You talk the Talk .... and you walk the walk
                        ps: Check your pm .... when you have a moment
                        • This is very interesting approach Dave I've been trying similar concept couple years ago with conical coils. I think, my mistake was in employing another coil in between to collect, while it should be different component - just as you're doing.
                          Great work
                          Vtech
                          General D.Eisenhower
                          http://www.nvtronics.org
                          • We have to search for clues
                            in this vid the aluminum ring gets hot, that tells me current is running in the ring,
                            If a ring were placed on the other side of the coil current would run through it too, but in the opposite direction.
                            Lenz's Law & Eddy Currents - YouTube
                            the magnetic field is in the iron core this reaction is caused by the electric field.
                            Walter Russel saw the answer
                              The Image you chose of walter Russell 's work reminded me of a topic we just discussed ... the 100 year old battery ... think about it using Russell's Lens .... 3 large circles to form one unit :
                              Silver circle , Blotting Circle and Zinc Circle
                              find silver and zinc on the periodic table below
                              • Originally posted by blackchisel97 View Post
                                Great work
                                Vtech
                                You cant see it in the pics but there is 1 1/4 in. pvc that connects the two cones, I plan on using a primary as in the Don Smith device to power the coils, well actually two primary's pulsed out of phase, wound bifilar, one winding shorted.
                                I plan to also use permanent magnets in my core, I hope to make the system versatile so I can change it up easily, Im a very slow builder but I'll get there.
                                dave
