From: Floyd Sweet: Space Quanta Magnifier / Vacuum Triode Amplifier ~ Collected papers, diagrams, photos & videos
just to have it referenced in this thread
note that the core is rotating (think Muller )
The Motional E-Field
Of all the known fields --- electric, magnetic, gravitational and motional E-field --- the only ones incapable of being shielded are the induced motional E-field and the gravitational field. The nature of the motionally induced electric field is quite unique; in order understand it more fully we must start by parting with a few misleading paradigms. When magnetic flux is moved perpendicularly across a conductor an electromotive force (emf) is electromagnetically induced "within'' the conductor. "Within" is an artifact of the commonly used analogy comparing the flow of electric current within a wire to the flow of water within a pipe. This is a most misleading model theoretically. The true phenomenon taking place has little been thought of as involving the production of a spatially distributed electric field. We can see that the model's origins likely arose from the operation called "flux cutting", a most deceiving and misleading term. A better term, "time varying flux modulation", does not imply any separation of lines of flux. Truly, lines of flux are always in closure upon themselves and are mathematically expressed as line integrals. It is fallacious to use the term "cutting", which implies time varying separation which does not in fact ever occur. A motionally induced E-field is actually created within the space occupied by the moving magnetic flux described above. This field is present therein, whether or not a conductor is present in the space. In terms of a definition we can say that, when magnetic flux of vector intensity moved across a region of space with vector velocity, electromagnetically induced electric field vector BxV appears in the space at right angles to both and. Therefore,
(1)
It is this field that is related to gravity, it is virtually unshieldable. This field may be called the Motional E-field. According to T.E. Bearden, "It seems that the charged particles in the atom (electrons and protons) act like tiny magnets. Their motion in the space surrounding the atom would create this motional E-field". The field created by both the positive and negative charges would cancel to some degree, but due to the high orbital velocity of the negative electron relative to that of the positive proton the induced field of the electron should dominate the resulting field. The field produced as a result of these charges would vary proportionally to the inverse square of distance similar to gravity. The field produced by the translational motion of the charges would vary inversely as the cube of distance. This concept totally unites the electromagnetic and gravitational field theories and accounts for the strong and weak forces within the atom.
(1)
