Are you suggesting that electrons enter the magnet at the a vector?
Harvesting Energy From the Sun Using Crystals
I pulled the cell this morning the bucking magnets make the A vector field chaotic, might be easier to catch in this mode.
Mags if you read this try to put bucking magnets on top of the one's you already have, it wont be easy
Im going to put the cell in with the magnets in attraction mode with a small distance between them to see if the A vector fields are attracted to each other, we could probably guess on that one but want to see the interaction.
DaveHalf of the Answer is knowing the right Question
Here's a link to the pics with the bucking fields
bucking permanent magnet pictures by Dave45_bucket - PhotobucketHalf of the Answer is knowing the right Question
Electricity will move through the structured column of ice, the magnetic field createdOriginally posted by Dave45 View PostMM gotcha , the field is electrical in composition, it cracks the ice, electricity will not propagate through ice therefore it cuts through the ice.
Look what I found
3, 6 and 9
The symbol of 6 and 9 are simplified version of :
more on this here: http://www.energeticforum.com/renewa...netism-20.html
a fractal construct has an 'efficient function', it has a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:Last edited by MonsieurM; 09-15-2011, 11:10 PM.Signs and symbols -Confucius.
JLN Labs - The TEP Project - Bifilar VS Bucking coils
I have conducted some tests to understand better the working process in the TEP.
The main goal of these series of tests is to compare Bifilar coils and Bucking
coils for their inductive and Back EMF effects.
I have used :
- a BIFILAR coil L1,L2 ( interweaved ) which has a calculated inductance
of 0.59 mH ( each )
- a BUCKING coil L1,L2 ( in serial ) which has a calculated inductance
of 0.75 mH ( each )
The tested coils are switched through a transistor BDX53C by a square wave
generator..
The inducted signal is received through a coil L3 ( wounded around the bifilar ).
Calculated inductance : L3 = 7.6 mH
you reminded me of this news i posted a while back...
Underground river 'Rio Hamza' discovered 4km beneath the Amazon | Environment | guardian.co.uk
Scientists estimate the subterranean river may be 6,000km long and hundreds of times wider than the AmazonSigns and symbols -Confucius.
