Thanks, but
all I did was summarise my understanding of whats in this thread.
Not sure what your referring to.If you mean whats left in the reactor vessel, jetsis makes it clear in an earlier post;charcoal which will need to be scraped off of the inside of the vessel, and can be pressed into brickets, and used or sold.
This is something which will need to be taken into account, when designing the vessel; making it easy to get access, to do this cleaning/removing of the charcoal.
Not sure what would happen if you DIDN'T clean out this charcoal after each run; I suppose it would just build up in a progressively thicker 'crust'.
Anyway, this frustrates my original idea;-( a tank with no door; would put the plastic in using a shop-vac, with a screen over the opening.Another opening on the tank would have a hose, that i could shove down into my container of plastic, effectively vacuuming the shredded plastic into the tank.
Was thinking I could use a gas water heater tank, and feed exhaust from an ICE, (infernal combustion engine) up the center 'tube' or chimney, to melt the plastic.Originally was thinking of using the exhaust from my diesel step-van. Now I'm re-thinking it, and considering using the exhaust from a gasoline generator.That way I have a use for the gasoline product, and can save the diesel for my truck.Still haven't figured out a practical, easy way to make a square or rectangular door, though. I'm now thinking the hot water tank would be laying horizontal.Exhaust from the gen-set would be wrapped with exhaust wrap to insulate, and would feed into the center 'tube' of the H2O heater.By insulating the tank, I'm fairly confident that would give me enough heat to melt/vaporise the plastic. Just can't figure out how to make the door!;-( Jim
