How to Move Mountains... Leedskalnin Style
  • Remember
    • Another
      • made a wording mistake in the first one.
        • Dave45.
          Why don't we start from the start of Ed's notes.
          The magnets themselves like to start at the middle but we should begin at the start.
          You have to stand the right way and everything has to be in the right position ect ect, otherwise it gets confusing.
          When you get to the end of Ed's notes you will have a description of "things" which does not couple with electrons. So it would be better to put them aside until you do Ed's work....then you can make a comparison and see which describes reality best.
          • Hi, im new to this ed and his rock castle or coral castle, saw the documentary few days ago, been looking at stuff from egypt aswell.
            i had some time to think about these stuff recently, the thing i found out in my head that i think these things
            the U shaped tool, as everyone seems to think is a magnet, is what i beleive a tuning fork, just without a handle. I also think that, you may be able to change the frequenzy of the fork by using copper wire and a radio transmitter. OR and this is important i think. the coils is for tuning the frequenzy. by lowering them or just sliding them higher. (if this works, then you don't have to manufacture forks to get desired frequenzy)
            Thats all.
            ps. or he used the radio transmitters to listen to frequencies, to tune the fork. also, it is magnetic and electric, but to simplify i think its a tuning fork
            • singularity
              I just joined this forum and must say there are quite a few interesting theories here, lots of great photos on a related facebook page which let me find the forum, lots of interesting people here serious on making it all work.
              I've been making youtube videos on Leedskalnin concepts of my own, I've erased many more than I have up now, mostly because I'm such a perfectionist.
              I'm not afraid to admit when I'm wrong.
              This avenue of thinking seems to have progressed my theory well I think.
              The most important discoveries I've made are in my particle physics theory outlining how the largest particles ,bosons, will form in different numbered groups based on mach angles of velocity interaction/flow opposition... or in other words, how space can have 7 different forms in 7 different times, even in the bible in John he mentions the 7 different levels of heaven.
              Well to the point though;
              there is a way you can get both poles to share the same wire by holding both magnetic currents in a STANDING WAVE line of force just like a supercooled type 1 superconductor will do.
              My theory is simple; you get both a low and a high antenna for ham transmission to build up the charge, and positive ion charge will be produced when they are both suddenly shut off.
              Do this beween 2 points and you are oscillating ion charge instead of magnetics, ie the chain hoist and the iron mass in the room with the wheel.
              So by design the wheel creates a positron matrix which is ideally just a simple energy vortex that works in harmony with all possible resonant frequencies- this is the only way you can allow for a true vortex of all ambient white noise in space to help the process of the vortex, or it would not be a vortex, sending energy to ground while it's opposite, mass, falls off the chain around the stone in the form of bosons as heavy as iridium/ platinum / gold, which build a format of a stack of 3 sets of 7 (see video on gold on my youtube channel mikefromspace).
              The earth's magnetic squeeze allows the fluxing resonance called Schuman Resonance which was 9hz in Ed's time but now is 11hz or close as earth's core slows down and putters out. The cycle will begin again very soon to speed it up don't worry. The charging cycle starts 12.21.2012 during black hole-sun-earth alignment, but earth might not pick it up 'till 2019 during a solar flare 'short' out event most likely.
              Well I feel I understand what needs to happen, but I could probably use some help in getting the radio and antennae configured properly. I have made a miniature version of Ed's wheel in my garage using neodymium magnets.
              Aside from Ed's device I've found how the same geometry can be used in another device that just runs magnetic current super fast, and would be alike to a more advanced one of the Ark of the Covenant designs. Has 24 pairs of tuning fork 3rd stage windings, 6 secondary, 1 primary at center among the 6 cores ; ; a bible reference again here; 7 candlesticks 24 thrones, it was a plan for this thing, Jesus had divine knowledge of the ages in sacred geometry and proved it there.
              Well hope this stirs up some good conversation. I've invested thousands in equipment; I have a 1kw 1kv dc power supply I might be able to use with the right modulator if I can build one or buy one somewhere but need help figuring how.
              • I've not read anyone's book but would like to see your views on the complete theoretical configuration of Ed's system for levitation based on what you've seen. I've been working on my own. See my other post on singularity. It's a shame, it seems some trolls took metal for scrap off Ed's devices making it very difficult to understand it all.. but it's only difficult when we try too hard.
                • Ed's sweet sixteen is the element sulfur it occurs naturally in that area,
                  the bottles with coils wrapped around them, was filled with a sulfur compound
                  the pmh is an electronic tuning fork soak the stones an ring twice
                  there are three fields not just two
                  • Ed's flywheel
                    Check out my blog post from today on Ed's flywheel.
                    I shows the flux flow involved in the flywheel device pretty clearly I think, and some may find it instructive.
                    Flux Flow Analysis of the Edward Leedskalnin Flywheel | Energy Research
                    -Alex
                    alex petty
                    email: alexander.petty@gmail.com
                    skype: alex.petty
                    mobile: +001.540.272.7970
                    • Nicely done Alex
                      I think though, that the flux is coerced to stay within the metal around the heel.
                      The reason I feel this way, is because the permeability of the magnets is much higher than the surrounding air and there are very few examples of flux crossing paths or interleaving. Those examples we do have are on the Sun and in high powered experiments like those done at Sandia Laboratory.
                      So the actual path will look more like an Ice Cream cone with the air flux being the Ice Cream and the metal flux being the cone for each U shape magnet - a closed path for each magnet.
                      On another note - Bloch walls and Neel Walls are generally reserved for reference to the interior domains themselves, not to the entire magnet. The NULL region midpoint between the two poles is more accurately referred to as the Equator, or Equatorial region.
                      Cheers,
                      Harvey
                      • Here's an interesting vid. I haven't seen it posted here yet.
                        Coral Castle Ed Leedskalnin Tripod and Black Box - YouTube
                        • Missng
                          Originally posted by Loadstone View Post
                          Hi all.
                          Here is a PDF I just made from my Magnetic Current booklet.
                          I had to touch up a few errors my printer made but it should be ok now.
                          This is missing the most important part the symbol on the front that tells yuo with the other books how to wire the PMD
                          • For some reason none of the links to pictures are working for me. Anyone else having this problem?
                            I would love to get a visual of what you are describing. Although I am familiar with this already and have a good idea of what you are referring to. But, boy, do I love me some pictures.
                            • Loadstone, thanks a bunch for uploading these to us. I cant wait to tear through this stuff.
                              • Molecules
                                Does anyone know if Ed used any methods of tuning his stones? By tuning I mean getting them to vibrate and thus be more aligned to the regional magnetic energy. I've always found it interesting how the world is full of mythologies and tales of old wise men chanting stones into the air. Was this an ancient method of tuning?
