That will be the chlorine at the anode, which at least goes to show that it is indeed proper electrolysis that is occuring.Originally posted by woopy View PostHi all
Salted water get yellow and smell not so good.
Did the dramatic reduction in current consumption come at the expense of a dramatic reduction in gas evolution? I would expect this to be the case.
I would suggest that this is occuring: You are causing the water to ionise as in your first experiment, the diodes are acting as a charge exchange bridge as before and gas evolves from each leg. However, by putting an earthed wire around the container, you now effectively have added another ground source to attract the H3O+ away from the wire cathode. Hence, as you have pulled some of the charges away, less current will flow through your diode bridge. At least that's my take on it.
Try using stainless steel instead of carbon rods.
This is great stuff, Woopy.
Farrah
Hi Farrah
i just repeated the experiment to be sure, and i can confirm that when i move the outer coil from water level to the bottom of the glas , and further more when i completely remove the coil away from the glass, the electrolisis seems to stay at the same level. No dramatic change in the bubles quantity or form . Only the current goes up ?
But of course we need to make a much bigger experience to be able to measure that fact precisely. That's why we need a cct which can excite a much bigger Slayer exciter and produce more power electrolisis.
Any idea ?
What about a 1 meter high and 20 cm diameter L1. what copper wire diameter for the winding and what would be the cct ?
good night
Laurent
That should do it, lol.Originally posted by woopy View PostWhat about a 1 meter high and 20 cm diameter L1.
Seriously though, I'll try to reproduce your experiment in the next few days so I can get a feel first hand of what's happening, because I'm already having second thoughts on my explanation in the previous post. I just feel I'm overlooking something.
All the best
Farrah
Sec Hho
Dear All
please check in the S cell HHO and HHO @5 Volts . Can add two s cell shaped 316 stainless mesh screen to the ends of Avrenko diode plus lye to increase production of hydrogen ..... wihtout heating up the solution
Ive ran out of transistors as well as the store so endurance test is on my list for the week end for the SEC lighting @12 volts
2 paralllel 2n2222 plus one MPSA06 C to B and base to E of the prallel circuit
Current draw without and with MPSA06 128 and 56 mA ,,,,,,,,that solve my problem of overheating
Had been running for 8 hours now and the circuit still the same warm LOL
the circuit affects my wireless mouse in my deskstop
totoalasLast edited by totoalas; 06-05-2010, 08:39 PM.
Sorry to keep butting in guys, but because of recent observations made by Woopy, I'm going to attempt today to replicate his experiment first.
Can I just confirm the operation of the cct.
Is it simply that on power up, the capacitor is charged through the resistor, (the resistor determining the rate of charge) and once charged enough - which is very quickly - the voltage on the base of the transistor is then enough to switch it on allowing current to flow through the collector to the coil. However as soon as this happens, the capacitor starts to discharge, thereby turning off the transistor base voltage and hence the current through the collector. So the cycle repeats, Would that be a fairly accurate description of how the cct is resonating?
Sorry if I'm covering old ground... I'm a newbie at this! I'll try not to become annoying
Incidentally, I've just taken a failed FL bulb apart for the little toroid, and was quite amazed by the amount of components therein.
1 toroid
2 transistors
5 non-electrolytic caps
1 large and useful 1.5mF 400V electrolytic
6 diodes
6 resistors
1 3mH inductor
and a small signal transformer.
Blimey you guys could save these manufacturers a fortune on components alone!
Farrah
Hi Totoalas
it seems that you have a good circuit , but could you please send a shematic how you connect the MPSA06 to the parallel 2N2222
thank's
Farrah
The circuit i use is the Slayer 007 cct. The capacitor is not absolutely necessary but it reduces the current when tuned correctly. Slayer 007 recommend a variable capacitor to fine tune L2 with L1. As i have no variable capacitor i try different capacity . But this is not the best way to get the best result. So i would recommend you a variable cap .Relative question where can i find a big variable capacitor (from 5 to 600 pf) in europe ?
At all
yesterday afternoon i spent all the time to test the electroliser with the
outer glass-coil grounded in my house plug, than my wife came back home and ask me what i did , because all the house smelled ionised air
.Not only my lab , So is it possible that by grounding the electroliser , all the house electric system is also ionised ?
good luck
Laurent
waooow Xenomorph
very nice big coil in the center of your pix.
I will wound something like this as soon as possible.
If i see right you use a PVC pipe which diameter, and what copper wire.?
Have you measure the inductance and resistance?
And i can see in the background the Slayer 007 cct , but in the front there is another circuit with it seems to be Mosfet. So my question do you use a mosfet cct to drive the big coil ?
Thanks for sharing, i would be glad to replicate your big coil and cct.
good luck
Laurent
good luck
Laurent
Thanks Xenomorph
i will go to sleep now and probably the night will add some new ideas to go ahead.
If any suggestion to wound a 1 meter 10 cm diameter (or more) coil perhaps with 0.4 or 0.5 mm copper ??
And of course i will try to trigger a powerfull mosfet with a small 2N2222a or other transistor.
As the frequency seems to stay around 600 khz perhaps somebody could propose a cct.
good night
Laurent
Ah, a variable cap - I thought something should be variable.Originally posted by woopy View Post
Farrah
But I'm puzzled Woopy, by you saying that the capacitor is not absolutely necessary - perhaps someone can help me here. I thought I'd figured out how the cct worked, but it doesn't hold up without that capacitor. How can this cct possibly resonate without the capacitor??
Farrah
Sec@12 Volts
Xeno,Johnny and Slayer
thanks for the advice I connected a 30 ohm resistor on my positive input
2 paralllel 2n2222 and the third MPSA06 the collector connected to the base of the 2 2N2222 in parallel and the base (MPSA06) connected to ground
Using a car battery 12.46 V dc 70Ah I run the circuit with warm transistors for 8 hours (70 mA) but without the 30 ohms resistor the current jump to 120mA which unfortunately burned my 2n2222
From my observation 100 up mA will raise the temperature of the 2N2222
with 70 mA im in the comfort zone
I useda 0.69nf varible cap ( range 2 nf)
Also can you please show the charging side of the circuit????
thamks again to all..... will start to make a permanent circuit
totoalasLast edited by totoalas; 06-07-2010, 11:48 AM.
This is how i charge batteries with the circuit:
Uploaded with ImageShack.us
The negative charging has turned out to be effective for bringing back
dead desulfated batteries (in my case).
But you should be aware of the fact that once they are charged this way,
you will have a hard time charging them in any other way again.
Slayer has also a drawing of his original circuit here : YouTube - Exiter Circuit And Current Draw.mov
The charge in the battery that was charged off the little tower turned out to be fluffy. The reason is probably the fact that there is not enough charge current being captured with the tower. On the other hand, if there was more current then one would probably get shocked being just near those things, as the whole surrounding area is highly potentialized (>100 Volts)Last edited by Xenomorph; 06-07-2010, 02:21 PM.
