Originally posted by Utopia Now
all energy comes from either ground or air. resonance is a way reverberate matter with small energy input using harmonics 1/4 wave harmonic can induce resonance in full wave harmonic. we always need earth for two purposes for grounding high voltage and to capture electrons. where as when we capture electrons from air we need to use magnetic lines of force which are neutral so electrons dont show up we have to split magnetic force by using L and C the way hendershot showed us. thus voltage and current are separated and utilized by an oscillator to produce power.
magnetic lines are hellical structures and inert in themselves we have to split them to use.
ground has free electrons just need to be pumped up. pump can be magnetic or electrostatic. magnetic pumps acts better as they utiilize earhs magnetic lines of force aswell as earth electrons. so dual advantage.
remember to learn about induction welding. work coil and sample coil. work coil has high frequency which induces high current in metal piece which is shorted coil in itself so eddy currnts are build up. these currents move in the sample coil or cylinder and have no way to go. so connect a wire in work coil and attach other end to earth now they can move in output and fresh current is fed throgh earth. cycle continues endlessly as long as the work coil has frequency working.
energy has to come from somewhere and the nearest and more reliable is earth grounding.
dunfasto
