Here in this clip at 3:15 I tune the primary to over 150 volts peak to peak the
primary has only 0.5 Ohms resistance, lets say it has 1 Ohm so that would
mean the peak current would be about 150 Amps I think, and with 3.6 Watts input,
the increased voltage on the tuned primary is normal and high oscillating
current in the tank is normal from an accumulation of energy.
The video with the RMS measurements from the scope I can't find, it's a
mystery, I probably will need to remake it. I have an external drive to search,
but I was sure I uploaded it.
Two Receivers and Armstrong Oscillator Transmitter - YouTube
If a circuit is tuned to resonance and there is no load the voltage will be high
and the oscillating currents will be high, but the output is nothing.
If the circuit is tuned to resonance and there is a load the voltage will be less
and the oscillating currents should also be less but there will be an output.
.Was actually thinking about the Shoebox device and the Build Your Own Version during the last section of Don's 1998 Interview.
