Radiant Free Energy By Ossie Callanan
  • #16
    Another great video from 'Lidmotor Home-Productions Incorporated'
    I used a regular simple electromagnet on this Ossie circuit and it worked great I put everything on a small board and presto--a radiant charger/CFL. --that is quiet and easy to build. Here it is:
    YouTube - Ossie Callanan--Lidmotor CFL Circuit #2
    Lidmotor
    I may be missing the point here Sir Lid, but surely Imhotep's Oscillating relay does everything we see here, except make noise!
    What do you fella's think are the main benefits/differences and can we please have a clear diagram to help newcomers interested in building this?
    Excellent work from everyone here and thanks to Patmac for introducing us all to Ossie Callanan's work.
    "I say that if a TEN year old can do this and win, what the **** is wrong with the whole World?"
    ~ John Bedini ~ 8 Mar 2000 - http://www.keelynet.com/bedmot/bedmot.htm
    • #17
      He Lidmotor....
      Good work, definitively the Ossie's setup is a good option to take advantages of Adams and Bedini.
      I've been work hard on my motor.... Tricoil, but needing more copper my results last nigght are good:
      Two Batt1 = 4aH, Batt2=2.5aH
      Batt1= 12,53 volts
      Batt2=12.63 volts
      Then Batt1 running the motor by 6 hours
      Both voltages were taken after one hour resting
      Batt1 = 12.37 volts
      Batt2 = 13.05 volts
      Now Batt1 and Batt2 were inverted..... Later I'll re-edit this post with more results.
      OK Bad news... the motor work well but 2.5aH batt is sulphated, only ran the motor by 45 mins and the motor only draws 110 ma. 4aH batt ran this motor by 6 hours and measured 12.37 volts so, perfectely 2.5aH batt can run this motor by 6 hours too.
      I'm testing the batt to see if is possible desulphate it, now is connected on PC FAN Bedini. I think 20 hours can make the work... Sorry, if the battery does come back to live, I'll buy another and retest all the process....
      Steve Jobs. Apple CEO
      • #18
        Okay, but what is the implication of these experimental results?
        I have not tested the solid-state version of Ossie's circuit, but I have been working on the mechanical version of Ossie's circuit. In my experimental setup, I also got one battery charging up with virtually no problem, while the voltage of the other battery was found decaying. But these results do not necessarily imply the system gains any free energy.
        Any thought? Can we keep a system running perpetually without having to replace any of the batteries?
        Originally posted by patmac View Post
        He Lidmotor....
        Batt1= 12,53 volts
        Batt2=12.63 volts
        Batt1 = 12.37 volts
        Batt2 = 13.05 volts
        • #19
          Okay, what about the source battery?
          Does the voltage of the source battery stay constant for as long as you wish?
          Ossie is right! This does not have to be complicated to work. A solenoid coil will do the job just fine. I was amazed that it worked. I put this together in a rush with things that I had on hand. I added a CFL circuit to his and let the magic happen.
          Lidmotor
          • #20
            Another comment: There is no point to measure the current of the circuit using a multi-meter. The reason is because there is no pure dc nor any pure sinusoidal ac in the circuit. I stand to be corrected.
            • #21
              But- But --Why are we doing this???
              Anut,
              Those are all valid questions. The truth is that I'm doing these experiments perhaps for different reasons than others. I'm after efficiency in a lighting system. The Imhotep Radiant Oscillator Lite project has spun off in several directions. The reason I came over to this thread was to try out Ossie's circuit on the CFL light, present it here, and see what people thought about the idea.
              The way that I am using Ossie's circuit is not to acheive an OU situation. This design to me is another way to produce radiant energy charging and another way to light up a modified CFL. If I can produce usable light and recover SOME of the energy at the same time ----that is all I'm after.
              As far as what energy is going in vs what is going out--you are right about the digital meters. They lie. Not their fault. They just can't do it very well on these circuits. Analogue meters are better. The digitals do give some idea of what is happening and that is all you can expect.
              Byjove, Here is Ossie's reed switch circuit and my modification of it to run the CFL. The second part of his design (the energy capture part) and the rotor part of the charger, I have not built. Today I ran my little reed switch unit hard and overheated the electromagnet coil with too much amp draw. I didn't kill the poor little thing but I think that I hurt its feelings. It wouldn't run again until it cooled down.
              Lidmotor
              • #22
                REAC - Ossie Callanan
                Today I set up the REAC battery bank (4 batteries) just as on the schematic... something about the connections seemed wrong.
                Within 15 seconds, the charging battery was spewing acid out of the caps.
                Has anybody else set this up successfully?
                • #23
                  I had lots of really dead beatup(by me)batterys if you can charge any of the reac batterys you floors going to get wet!
                  What i see is when you try and charge a dead dead battery the volts go up really high really fast(in secords). best one battery i got for the reac what one i pickup from the side of the road. 3volts put it on charge i think i got 20 volts flying all over the place.
                  LOL your charge acid spewer is now you first reac one
                  • #24
                    Lidmotor
                    Thanks Sir Lid!
                    Can you tell us what problems you had to overcome before getting good success with the cfl? I have watched your videos and followed the threads and tonight I finally got around to trying the Bedini/Imhotep fan with an ignition coil and also a transformer, but the results are not satisfactory. I've used a variac and pot to adjust current draw, but I'm not a happy bunny.
                    Major problem is getting a good light output. When I get good white light output, it is pulsing too much and using over 100mA.
                    I want to go through all the different stages and experiment, before I try the Ossie rotor-less idea.
                    By Jove!
                    • #25
                      Hey, Bedini has one motor called window motor, highly efficient run with a big capacitor by months, is full overunity if you look the work on the shaft.
                      The multimeter was used, but with the batt DISCONNECTED AND ONE HOUR AFTER RESTING.
                      And one comment to you: Bedini for example use analog ampmeter, the digital mult meter works too if the circuit no has GAP - SPARK, if the neon is flashing digital meter goes crazy. But if you put the charge batt works perfectly. I've tested this procedure by using 1ohm resistor and reads the same values in mVolts that on amp meter mode.
                      You must remember that battery is a chemical process no electrical, NO MECHANNICAL - NO THERMO DYNAMICS
                      • #26
                        Bodkins
                        Thanks.
                        • #27
                          Bright light CFL with low amps-----Hummmm
                          Originally posted by byjoveoldchap View Post
                          Thanks Sir Lid!
                          By Jove!
                          Byjove,
                          You have just discovered the reason that we are still working on this project. The group has tried many things. It boils down to how much energy do you want to spend on how much light --and do you mind listening to a buzzzz while it is happening. You get more light with more amps or more voltage. And don't forget about the charging aspect. You are getting some of your energy back.
                          If you can get good light(enough to read by) for under 1/2 an amp then you are doing good.
                          Lidmotor
                          • #28
                            I have done some rough experiments on the REAC idea before. The batteries I used are Ni-MH rechargeable batteries. My experimental results are:
                            The charging battery got charged up much faster. As usual, the source battery was discharging, but I cannot tell at this stage whether the discharging rate was faster or not.
                            • #29
                              The reason why I brought up the issue of OU is because, during my experiments, the discharging rate of the source battery is not zero, or close to zero, even though the amp draw may be in the order of nano amperes.
                              CFL lamps (or other gas-discharge lamps) are negative resistance devices. They do not require too much power (or current) to operate. In most cases, a negative resistance device can be mathematically modeled as a system containing one or more subharmonic current generators.
                              Most of the systems we have tested involve inductive collapses, each of which normally lasts for a fraction of microsecond. I am not sure whether the current shown in a multimeter is dc, or ac, or the rms of a square wave. I don't think it is easy to tell how much power it consumes or recovers until we examine the output waveform.
                              Anut,
                              Lidmotor
                              • #30
                                Anut,
                                It sounds like you know alot more than I on this subject. From what I have learned so far one has to do load testing front and back to tell what is happening. Mart Hale has done alot of this and runs a computer program to graph it. When you use big batteries the testing is difficult because the time envolved to charge and discharge the batteries is long. If you use too small a battery then the energy capture is poor. All I can say is that the source battery drains down and the charge battery/batteries fill up. Build a good device, test em, and see what happens. Don't expect to start selling electricity to the power company any time soon.
                                Lidmotor
