Bodkins,
Radiant Free Energy By Ossie Callanan
Steve Jobs. Apple CEOTags: None
Hi Patmac
Sorry my friend i can get a visual of the setup you have put so much energy into. Can you make a drawing with one of them thing they call.....MMMmmmm
...what is it now ahhhh I got! Its a pencil
Ossie`s Stuff was real good for me documented in a way anyone pickup and go!!!
Bodkins,
Now my motor Ossie style is working with one mosfet and one reed, I want to buy two identical mosfet to test the schematics designed by me (Half H-Bridge), to see more info and pictures of Original Ossie's work look on overunity.com username Ossie.
I've not high speed internet here in my home, I'll try to take a photos of my motor and I'll upload.
Links:
A Working Radiant Free Energy SystemYour time is limited, so don't waste it living someone else's life. Don't be trapped by dogma — which is living with the results of other people's thinking. Don't let the noise of others' opinions drown out your own inner voice. And most important, have the courage to follow your heart and intuition. They somehow already know what you truly want to become. Everything else is secondary.
are you saying to me, can if use solenoid coil branded?
Yeah, maybe in audio stores or car tunning audio stores you can find them,
I've got one washer machine valve input on the junk.
Has 120 ohm, high, but works charging a capacitor with the SG jajaj.
I was testing Edwing Gray principle, you take the solenoid coil with core, you put a magnet on the core, and you connect the capacitor
charged, more voltage is better, with 200 volts the magnet is like a pistol shoot..... This principle is usefull, this shoot with only 200voltsX200uf???.
Edwing Gray motor undoubtly high torque...Your time is limited, so don't waste it living someone else's life. Don't be trapped by dogma — which is living with the results of other people's thinking. Don't let the noise of others' opinions drown out your own inner voice. And most important, have the courage to follow your heart and intuition. They somehow already know what you truly want to become. Everything else is secondary.
Ossie Callanan----Lidmotor CFL circuit
Ossie is right!
This does not have to be complicated to work. A solenoid coil will do the job just fine. I was amazed that it worked.
I put this together in a rush with things that I had on hand. I added a CFL circuit to his and let the magic happen.
YouTube - Ossie Callanan--Lidmotor CFL Circuit
Lidmotor
Build a custom coil for the Ossie
Thanks David,Originally posted by DavidE View Post
I think that we can build a custom coil for the Ossis's charger quite easily. If you think about what is going on here it is very simple.
Lidmotor
oh, this is great!
I've been waiting to try Ossie's idea, but had to wait until I moved. I'm working on the REAC part of it and have been calling around to used battery places. All I can find so far are car batteries. Do you think that would work - is there anything in particular to look for?
I'm going to work on the Bedini part of it this week - already have the wheel and will work on the reed switches shortly.
I'm so glad you started this thread!
In Peace,
Jen
Hi all
Been working on the earth battery and after seeing lidmotor solid state Im going to cross the two.
Creating a magnetic field in the earth magnetic currects i think will increase the power of the charging potential. will set this up with a scope to get the oscillations going.
when i was using reac i had big dead batterys you need them to be dead thats all.
I noticed that in the Ossie Callanan schematic the reed switch is connected to the positive of the charging battery. But in the video of Doug Konzen, he states the reed switch should be connected to the negative of the charge battery.
Doug Konzen - Free Energy Pulse Motor - AOL Video
Here is another video of a circuit that uses a reed switch and it shows up on the negative side of the battery...
YouTube - Circuit, I hope I am not boring you
Thoughts?Last edited by DavidE; 10-29-2008, 09:01 PM.
The simple coil Ossie
Hey Guys,
I used a regular simple electromagnet on this Ossie circuit and it worked great
I put everything on a small board and presto--a radiant charger/CFL. --that is quiet and easy to build. Here it is:
YouTube - Ossie Callanan--Lidmotor CFL Circuit #2
Cheers,
Lidmotor
