Imhotep's Radiant Oscillator Video
    ..... Please do not get me wrong, this is not a criticism and defiantly not a replication of your circuit.......
    Luc, I am not in this for myself and my self ego is solid enough. I do consider criticism very valuable here. Neither did I try to defend my system nor suggestions. I am seriously trying to get to the botom of this.
    If that was not my wish, I am sure I could use this circuit and all I have shown in the video's rather to get or scam BIG money from someone ignorant. Thus, it is here and hopefully we all can work together to make it workable for the people of the world. Later on we can figure out how to use this in modified form to make profitable products.
    Is this right, good and valid -
    A: IF YES, then lets fine tune it and release it to the world. Note my word 'release'. I doubt seriously that I would go into production of this kit.
    B: IF NO, then lets forget about it and go on searching for the valid one.
    • YouTube - Tesla Wireless Transmission with Aromaz circuit - Video 24
      Wireless transmission with Aromaz circuit
      • @ gotoluc
        Can you post a schematic of your lc oscillator circuit? I've been trying to make a colpitts oscillator / signal generator for when I get vacuum tubes (to switch coils instead of trannies which get soggy in my opinion) BUT nothing I make works. Except one, which would oscillate for about a second. I've got 2 variable 60 to 160 puffs and 50 k pots and rf resistor... Only other option I can think of is I found info on a type of tube which is specifically made to oscillate, and another type appears to be made as a cut-off diode... Also looked into crystals but their circuits are too steep a learning curve for me; I can't visualize what's happening.
        /// to all: made my move to under the house!!! Also found someone on this thread who works near where I live, so we'll probably get together for a think tank. So I'm extending an invite to all to take a peek at my lab...
        YouTube - Inquorate 15
        • @ nat1971a
          Have you tried pulsing your master tranny's base with a radiant charger? I couldn't get my 2n2222 to trigger properly at first, so I tried a 2n3055 as master. It too wouldn't work well. So I took the only oscillator I had on hand, my imhotep fan (99.9hz), and used it to trigger base of master 2n3055 with earth wire on base as well. Ran it for only a couple of minutes. By accident, turned system on later without fan running and she started up. I really don't think 2n2222 is necessary, but whatever it's switching (base) semiconductor is made of is susceptible to radiant waves, right out of the box.
          However, I believe (haven't tested any other transistors except 2n3055, 2n2222, and TIP35c..) any transistor can be 'conditioned'
          I've finished harping on about that now.
          • didnt have much time for experimenting today....will have another look at it next weekend....will see if i can get the exact 2n2222 that aromaz is using first...and try that out.......
            • what i did try was running it at 24 volts...and the lights were going purple....i think 24volts may be to much strain for the bulbs...hence when i tested the wireless parts out it didnt work....had to use a bulb that hadnt been used....but i want to get the exact 2n2222 first and rerun some tests on it
                Thank you Corrie for the great detailed photos and parts information
                I really appreciate all the work you have put into this.
                @everyone,
                I just completed some basic tests. The tests was to only try to get a coil primary to resonance and observe the effects. One thing I found that would be important is if you use a Analogue Meter it will give a false reading and if you use a digital meter you will need to set it to AC.
                Even though your source battery is DC the transistor is pulsing the DC through your meter and you will get a false reading if you use it on the DC amp. mode. This DC pulsing is also why an analogue meter will not work as we are pulsing the coil in the 20khz range and they cannot display a correct reading at this frequency due to the analogue needle coil frequency limit.
                Please accept my apology if all of you know this. I'm just trying to make sure we are all on the same page on the way we measure amps.
                Thank you for all your great work and sharing
                Luc
                @ all
                As Luc suggests current readings are not a reliable indicator of true power consumption in this field of HV / HF experimentation. The overal time taken to discharge the battery will reflect the true current drawn by the HV circuit. Also consider the possibility that the HV could be damaging the battery. If Aromaz's setup is really only consuming microamps then the battery will be able to power his circuit almost indefinately using the batteries shown in his video. If this is the case, he will be laughing all the way to the bank!
                Hoppy
                • fluorescent tubes
                  Could it be that the inside of these tubes are acting like capacitors and the coil is some way extracting this energy
                  • Ok. Guys for those of you who are playing with Aromaz self resonant Ignition coil schema. Try to put unmodified CFL into the chain, please share what you will see. In my case it was flashing every 3 sec. Current consumption didn't change.
                    Mike
                    • In unmodified CFL there is a cap, which probably is charged during this 3 seconds being discharged then to flash CFL. Better test if this bulb is still working with ordinary AC
                      • Special Request
                        I CAN NOT FIND IT IN THAILAND !!!!
                        Could someone please try for me an experiment - most likely UK or Aussie.
                        On my system - or any other high voltage line like original Imhothep - PLEASE try and see what are the effects of using a SODIUM VAPOUR light bulb in compatison to our CFL's.
                        In the UK they are called SOX - Low Pressure Sodium Vapour.
                        Produced specailly by Phillips, GE and some bit by Osram.
                        If not sure, refer to this page:
                        The Low Pressure Sodium Lamp
                        I might be onto something and need to play around with Sodium and Nitrogen as gas in the tube - to replace the fluorecent mercury vapour. First I want to know how they will lit up in the HV single conneciton.
                        Further in this line: Does anybody have an idea about practical use of NITROGEN as luminence in lamps - or more important as conductor for electricity potential (Volt)?
                        • For those interested in the why of our tubes
                          Here is some nice pieces of education about our wonderful CFL's and the Fuorecent tube: (Edited to key phrases)
                          The fundamental means for conversion of electrical energy into radiant energy in a fluorescent lamp relies on inelastic scattering of electrons. An incident electron collides with an atom in the gas. If the free electron has enough kinetic energy, it transfers energy to the atom's outer electron, causing that electron to temporarily jump up to a higher energy level. This is why the collision is called 'inelastic,' as some of the energy is transferred.
                          This higher energy state is unstable, and the atom will emit an ultraviolet photon as the atom's electron reverts to a lower, more stable, energy level. Most of the photons that are released from the mercury atoms have wavelengths in the ultraviolet (UV) region of the spectrum predominantly at wavelengths of 253.7 nm and 185 nm.
                          This is not visible to the human eye, so must be converted into visible light. This is done by making use of fluorescence. Ultraviolet photons are absorbed by electrons in the atoms of the lamp's fluorescent coating, causing a similar energy jump, then drop, with emission of a further photon. The photon that is emitted from this second interaction has a lower energy than the one that caused it.
                          When the light is turned on, the electric power heats up the cathode enough for it to emit electrons. These electrons collide with and ionize noble gas atoms in the bulb surrounding the filament to form a plasma by a process of impact ionization. As a result of avalanche ionization, the conductivity of the ionized gas rapidly rises, allowing higher currents to flow through the lamp.
                          • If you want to check for radiant energy activity you can use a capacitor in the proximity of the components (don't touch them) and see what happens to its potential. This can be a simple conducting plate hooked to one terminal of the capacitor and a the other terminal of the cap to the ground. You can go around the circuit with the plate and see whether the cap charges and then maybe look at places/angles where it charges most and fastest.
                            According to Tesla radiant energy creates electrons (ie electricity) on impact with a conductor. So this can be some sort of a radiant energy meter.
                            • explosion of thoughts
                              I was responding to a message bodkins left on a youtube video of mine ages ago, re fluffy charge and being unable to run a load...
                              Got caught up in idea explosion and put everything that came into my mind down... Ended up so it won't fit on as a post here, so I started up a blog page I don't intend to continue with, but it's all there for anyone to read.
                              Deep thoughts
                              It kinda takes up from where I was going previously with posts re longitudinal aether compression waves and how they interact with transistors.
                              I took same principle to capacitors, and things started falling into place. However, it's first draft. Prob hard to read... my brain works in an odd way...
                              Ps, it incorporates tiny bits of a book I wrote once after motorbike accident, couldn't walk for almost a year... It includes string theory which I'm realising is a red herring, but asides from that, can be an enlightening read.
                              First 2 paragraphs,
                              "This book is about the relationship between energy and consciousness. This relationship is too often ignored by science, despite mounting evidence to the contrary. Nor is it fully appreciated by psychologists, and it is over dramatised by enthusiastic adherents to the school of new age thought.
                              This book explores the relationship between the nature of humanity, aspects of the mind and emotion, the nature of belief, thought forms and psychology. It covers the emerging studies of chaos, randomness, structure and order in our experience of society, nature and the individual."
                              I'll never get round to trying to get it published, 300 or so A5 (book) pages.. Anyone wants a free pdf of it, PM me with email.
                              Just keep in mind that aether physics is behind all the quantum phenomena, string theory is elegantly misdirected, and I'm beginning to strongly suspect that the interaction between aether flows polarized by electromagnetic fields is the cause of inertia, as well as of gravity..
                              I don't think we're in kansas anymore, toto..
                                boguslaw you absolutely correct. And I'm using it as efficiency test for my system. It takes 3 sec for my coil to provide enough energy to get CFL to designed brightness. So my system is roughly 1/3 efficient to light the CFL.
                                Mike
