Imhotep's Radiant Oscillator Video
  • Shapes
    Think about electrons sitting on the skin of a perfect sphere. They all push on one another equally and are very hard to budge. The smaller aether particles are not so hard to budge.
    Now imagine many spheres in a row... The aether particles keep bouncing free, but electrons don't move much at all.. Ie OOOOOOOO......
    Hence Tesla's pancake coils, primary outside, pulses at 90 degrees travel across full diameter of secondary coil, or up full length..
    • Tesla's Longitudinal Electricity
      ________________________________________
      Go to the 20 minute mark to see the longitudinal electric tests...
      longitudinal electricity - Google Video
      • @lidmotor,
        I was at the local solar shop last year asking some questions......and apparently you can connect solar cells in series like you can with batteries or caps.....so you could connect 2 12v solar cells in series to make a 24 volts cell to float the batteries...
        • Vacuum tubes
          For those that said they feel like playing with vacuum tube instead of transistors, here's a site with HUGE reference data sheets. If you can't find a tube's specs here, you made a typo
          TDSL Tube search
          Also, here's an ebay site selling tubes. Some for auction, most for constant (limited # sometimes) sale.
          eBay Shop - Vacuum Tube Supply: VACUUM TUBE SALES: NEW IN BOX HYTRON 6B5 POWER TRIODE TUBES
          And here's some (for sale at above site) I find promising AND at my price range... Ok, this is part wish list to be honest
          * 6b5 direct-coupled power triode $30 au
          NJ7P Tube Database Search
          ** 6ay11 dual diode and dual high mu triode $ au
          * High mu power triode $23 au
          *** Full wave Rectifier diode $19 au
          *** Clipper diode / rectifier 5 to 17 kv, pulse 25uSec every 100uSec $53 au
          TDSL Tube data [3B29]
          6299 high mu triode up to 3300mhz $76 au
          *** half wave rectifier, 2800v high amp (for valves) cold cathode $15 au
          TDSL Tube data [CK5517]
          Full wave rectifier $15au
          *** uhf freq conv / oscillator Tube [5744-WB] $14 au
          TDSL Tube data [5744-WB]
          ** HV Clipper diode $12 au
          TDSL Tube data [3B26]
          Etc etc etc......
          • Get rid of the blindfolds.
            ........Could you please do a test on your Dual setup by removing only your Tube Coil and after check the amp draw in order to conclude if it is the tube coil making the difference (low amps) or is it the Dual setup that is making the difference.
            @Gotoluc - and everybody else. There are two extreme critical things to know and realize - imprint this into your minds completely and consider this as the ultimate LAW OF ANCIENT ENERGY.
            FORGET ABOUT CURENT. FORGET ABOUT AMP. They are poison to Radiant Energy.
            Yes, because of our stupidity and closed minds, we are still using them to get the energy from the vacuum. BUT soon we will learn how to get the pure ancient energy WITHOUT current/electrons.
            Let me try to expand here a little bit first:YouTube - Aromaz 020x - Missing part of No 020
            which is the missing part of last night re. Playing with sparks
            #021 = YouTube - Aromaz 021 - Ancient Energy vs Modern Meters
            I show you practically why micro amps is possible and why the lights does not need amps.
            • Amoraz Thats it,
              The diffenence in potential LOL WE GOT IT
              Time to get to work gentlemen we need to get this out there
              Wait a minute!! Sounds making the light flicker, Makes sence "Speakers "
              Will be talking to you thought the ground soon
              • magnetic current and time
                Electricity consist of Potential (Volt) and Current (Amp) as well as .......
                Now Volt can exist without current. Current can not exist without Volt.
                Radiant Energy - It moves through space, not conductor. It can move around the conductor. It is a free radical, it can not be contained! IT CAN NOT BE STORED. So how can we use it? I do not know.
                Hi Aromaz,
                I think your work is awesome and I'm following it taking notes, etc... as well as seeing different applications for what you're doing but I won't post anything to distract people yet. If I can get some more RCA3055's locally, I can show something. Also, I'm paying attention to the incredible work everyone else is doing here as well.
                There are a few things I'd like to chime in on because they are important distinctions and are not just about semantics.
                Actually, current can exist without volts.
                There are two kinds of currents. There is hot electron current that flows over the wires. And there is magnetic current that also can flow over the wires...and I do not mean magnetic field...I'm talking about literal magnetic "particles" that flow over a conductor, which is cold and does not need voltage to perform work as hot current does. This magnetic current can make things happen without voltage potential.
                See more here:http://www.energeticforum.com/37124-post69.html
                I give myself some disclaimers on that post, but the reality is that my beliefs in that post are backed by real experiments that I have done myself and a lot of fortunate happenings.
                This magnetic current can be tapped from the ground magnetic currents or more external magnetic field of the Earth. OR, magnetic current can be manipulated on a circuit to flow by doing specific things.
                With radiant energy, it is possible to store it and use it. Capacitors can cultivate this radiant energy. This radiant energy IS a subatomic gas-like fluid in and of itself. It can be stored by using TIME. It is TIME POTENTIAL. Put it into a capacitor, do it enough over TIME so that it cultivates...then it can be dumped to a battery over and over (TIME) and out comes work in measurable joules of energy.
                Even our human bodies use this infinite potential as our life force...it comes in and through us to provide the necessary potential needed to cause electrical action by every single biochemical diopole in our body.
                Any potential difference in anything in our body by any chemical reaction breaks the symmetry of the aether in its vicinity and causes the positive potential to flow to the positive pole of the chemical and the negative potential moves to the negative pole.
                Every nerve impulse draws on this infinite potential from its environment. AND our body has certain areas where this potential is stored EXACTLY like a capacitor.
                So we can use this radiant by storing it and using it.
                TIME is the magic word my friend...TIME POTENTIAL.
                People just see that a super high voltage spike without current is "radiant energy" without realizing that LITERALLY, TIME POTENTIAL itself has been cultivated and stored in that spike. It is what TIME is made of. Time is not some 4th dimension like is commonly said.
                All that potential is stored up time...STORED TIME...that is why you see no current. When that STORED TIME is released to do work, then the time is let out of it. This isn't a goofy analogy...this is what many people don't understand. This is literal.
                The Bedini chargers are Time Machines. They charge batteries with stored up TIME POTENTIAL. I know this is a challenging thing for some people to believe but it is what it is.
                Application here is for lighting but the same principles apply - as far as the radiant potential.
                • Thats It Im Buying Your Book Arron
                  • I do not know what to say
                    Just posted video # 022 - this is a further finding on the same set-up as I had in video # 021. Only thing changed here is a longer 32W flouorecent tube and a spare wire. Add in BIG sparks plenty of Osone and gunpowder smell - even on my hands and clothes
                    Truely, this thing is escalating - like a snow ball.
                    Please note: Once I removed the Amp meter, I had difficulty to get all going. Place it back - worked fine. So I replaced amp meter with small coil and it worked fine again. When connected Amp meter up to battery + I failed to get oscillations, though there is a momentary flash. I used a bigger 10 Amp from battery + still the same.
                    No amp meter, small coil on line to is good starting.
                    Amp meter on line to earth - also good starting.
                    I checked complete with 4 tubes in one long line - series. All lit up same value, quite bright and amp meter to ground shows same 0.08 amp.
                    While waiting for this to 'go live' I tried to get back to earlier experiment in my little lab.
                    AND I duplicated it - but not excatly the same. However - IF video #023 does not rock you .................
                    Wait, let me upload it.
                    • Agree on more than one current - but amp meter ....
                      Hi Aromaz,
                      Actually, current can exist without volts. ,,,,,,,
                      Aaron, I am inexperienced and I am led to do things in a mysterious way. You would probably be one of the few people that understands.
                      What I have done this far is not mine, it is not my intelligence and it is not things I have learned elsewhere.
                      For now I will reserve comments on this; Exept for agreeing with you that there are more than one kind of current. Whatever other kinds of current there are - they are still not measured with our AMP meters.
                      To the present, though we saw some of it in earlier experiments; I have never seen/heard not had prove from anyone actually finding exactly the same as Tesla describes re cold current.
                      In the mean time, Video # 023 "If this does not rock you" is upoading now.
                      • Gone wireless
                        Gone wireless, video #023 is on line. Though it is mostly due to the HV around everything in the complete place. Single system, 24Vdc, fluorescent tube with copper wire, nice sparks - and eventually nice toy - Normal light bulb corona discharge.
                        Now I am done with this series. The last video will be a persoanl view, overview and where I hope this will lead to. Hence on I will work to undertand the complete reasons, workings and why's of this all - my way - then I will work on making all of this usefull and applicable for generel purpose.
                        YouTube - Aromaz 023 - Gone Wireless and play with Corone
                        • Aromaz can I ask how deep/far you have studied Tesla's work? This is important for me to know before discussing what you said and found.
                          • Originally posted by broli View Post
                            As much as I could but, I have not as much as I would have liked - my resources are limited. I do share one thing with him: My interest is very wide with quite a collection of general knowledge. i.e. Medicine, geology, hydrology, human science .... all subjects for which N Tesla is less know.
                            • Originally posted by Aromaz View Post
                              That's quite surprising Aromaz because what you said earlier is very spot on with what Tesla found. I would really like you to read this certain chapter about Tesla that I'm willing to send through pm. It'll probably be very scary as it has many things you already believe and new things to better understand and improve on the current experiments.
                              I yet have many things to learn from you guys but hopefully I'll catch up.
                              • question regarding amplifiying current
                                We Know that transformers can be used to step up and down voltage. would we get a step up in current if we got one electron working to free up two electrons in a circuit? or would this simply be an increase in voltage?
