Another display of stupidity. From obvious meter readings, battery current does not change signs (- to +) at switching to and from "Regen acceleration" and during test, battery voltage is always below battery open circuit voltage (77Vdc, shown on meter after test shutdown at end of video).Originally posted by BroMikey View Post
If you listened at one point he says the voltage is also 74vdc which was during normal operation or conventional discharging. So I am not sure why that is a problem. If you have a technical question that I can understand I will do my best to answer it. What is the question?Originally posted by bistander View Post
Let's lay out the machine first. Ebike has motor running at 5 amps and 75vdc approx (without splitting hairs) then lexan boxes in the back end capable of holding 24 coils using both side only has 3 coils send energy back to the batteries. I hope this clears things up. Other consideration for conversion are not discussed as this is standard practice for those who are skilled in the art. "Skilled in the art" someone who half-azzed knows what he is looking at.
ReGenX has already gone into production in 2020 according to Thane.Last edited by BroMikey; 05-01-2020, 09:37 PM.
It is such a simple idea. The ebike motor out of the factory delivers 5 amps at 75vdc (approx
The ReGenX rotor (Approx 14" dia) with 1" magnets (approx 20) at 1/2" thick pressed into holder sleeves which are press fit/ epoxied. Probably sleeves are spot welded to rotor then mic-ed- then pressed . Next is 3 C Core coils that gently assist the back wheel which in turn slightly eases battery consumption while delivering 5.34 amps back to the battery at the said voltage. Unlimited range is so simple.
If you see what I see then you would know.
Do you know how to use a battery? How to discharge a battery? How to charge a battery?Originally posted by BroMikey View Post
How can you charge a battery with a current through the battery which is in the same direction as when it was discharged?
How can you charge a battery when its terminal voltage is lower than its open circuit voltage?
I don't have time to skill you in the art so to short form the answer look at an automobile and the way it draws power from the battery and the alternator charges the battery at the same time. Feel free to ask any question but remember that you or I do not know everything. If you stay open something new can enter your thought process.Originally posted by bistander View Post
Also note that on the Ebike there is a charge controller. It is located where the gas tank normally is but this is an electric bike. The ReGenX coils probably produce anywhere from 100vac-300vac depending on RPM with each coil producing around 2 amps max in this setting. In previous video's the coils actually have a substantially high max amp rating. 5 amp max but heating up.
Many charge controller are available in electric car systems. As a simplified for instance coils must be designed to produce 20-30vac in a car alternator depending on the RPM of the car's gas engine in order to regulate down to 13.8vdc after including rectification. These systems are not as simple as Thane may make them look. Always remember that Thane is an engineering genius, way out in front of the pack.Last edited by BroMikey; 05-02-2020, 01:01 AM.
Thane is an idiot. If he was right in what he claims and says at the end of that video that the electric scooter can run forever without charging, why doesn't he prove it by just not turning it off. Just leave it run, and run, and run. For hours, days, weeks, and more. He can't because it doesn't remotely function as he claims. He is full of BS.Originally posted by BroMikey View Post...Always remember that Thane is an engineering genius, way out in front of the pack.
You can't charge and discharge a battery simultaneously. And you can't charge a battery at lower potential than it is at open circuit.
Again as per usual your comments are bias and insulting. Ignorance is no excuse for the laws presented. Name calling, very poor taste just as yucky as they come. Please refrain from such speech. If you have something intelligent you may enter a comment.
Cars charge the battery at the same time they are being discharged. The head lights drain the battery and the alternator puts the power back into the battery as needed. In the old days I have removed my battery once the car was started and the system works without a battery, same same happening here.
Again this lack of basic knowledge shows complete ignorance on your part of common systems in use today. Yet you claim preeminence concerning higher learning in energy systems. A back yard mechanic can see right thru.
These demo's are easy to understand. The only complication left is to engage a number of engineers to fit the devices into one package.
Actually you can not charge and discharge the battery simultaneously. When you start the car the alternator charges the battery while all other loads are drawing power from the alternator, the battery at this point is simply another load in the overall circuit. You can remove the battery because your powering the alternator with and external source of energy. If the charging ( or alternator output ) is lower than the load requirements then the output is shared between the battery and alternator output. For instance a 200 watt load with a 100 watt output of the alternator - the alternator would supply 100 watts and a watt meter would show a 100 watt drain on the battery. If the output of the alternator was 200 watts and you had a 100 watt load then the battery would be charged with 100 watts while the load dissipated 100 watts. There really isn't any "magic" going on there nor in Thanes machines...
Thank you dragon. Seems obvious. Easy to confirm in the literature or on the bench.Originally posted by dragon View PostActually you can not charge and discharge the battery simultaneously. ...
images from: https://www.matsusada.com/column/kind-of-cell.html
2 Photos
Just an update. Spoke to Greyland. He was in the shop working last night. He has the generator running on 11.5 volts at 12 amps right now. Will probably test tonight to see if it will speed up under load. It's possible, but I DOUBT it will at that voltage because of the speed. I doubt it is going fast enough. But he has to start somewhere. Will keep you all informed.
Oh yeah David Bowling, good to hear the news about Greyland feeling better and back working his heart out on these awesome extra energy project. All that needs to be done is to show 10watts output higher than the input. This will shatter all of the old science.Originally posted by Turion View PostJust an update. Spoke to Greyland. He was in the shop working last night. He has the generator running on 11.5 volts at 12 amps right now. Will probably test tonight to see if it will speed up under load. It's possible, but I DOUBT it will at that voltage because of the speed. I doubt it is going fast enough. But he has to start somewhere. Will keep you all informed.
I have been noticing Thanes charge controller and how important conversion is in the end. I can see why you are using dc motors now. That generator Greyland is testing is the 5 magnet pole? Or is the 10 magnet poles?
The rotor has twelve 1" x 1/2" thick neos on it. (Actually twelve on EACH side of the rotor) There are 12 coils. Each coil is made of 12 strands of #23, each strand 253 feet long. Four strands are connected in series (Three groups of four) so three parallel strands come off the coil. Right now the machine is only drawing 156 watts, but I DOUBT it will speed up under load, so probably not much output to speak of. He will be lucky to run two coils, and the RPM running on 11.5 volts won't be much.
