Originally posted by BroMikey
to answer your other question about will it drive a H bridge unit?
yes I believe it will. I assume the H bridge unit you speak of is a pair of
IGBTs?
If that is the case then my 1000watt 20 amp 12-48 volt DC power supply and the ZVS driver would serve as an ISOLATED POWER SOURCE to drive the IGBTs and remain totally ISOLATED from the IGBTs separate FWBR high voltage input/output circuit making it possible to use them as SWITCHING transisters to drive an induction coil ! I believe that is what you were actually hinting at?
I mentioned in the past as soon as I proofed my alternate system I would also address the building of an IGBT driving module board. I haven't forgot you at all.
I also intend such a module board to later ALSO be another form of HIGH POWER voltage supply to add yet more voltage potential to my CAPTOR UNIT!
I'M not through yet by a long shot!
Clarence
Very interest. So you are still brainstorming the gates.
