Originally posted by Ufopolitics
Hello Hanon,
Yes, My mistake, they are N-S facing each others (As Figuera described)so they close magnetic field for each turn/side...I deleted the wrong picture at photobucket...I will fix it tonite, am not at CAD PC...sorry
Good observation..
Edit:Replaced/Corrected Image:
[IMG]
[/IMG]
UfopoliticsLast edited by Ufopolitics; 06-08-2013, 02:29 PM.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Read it.
@ UFO, i am pretty sure you know who could design IT.
Thanks UFO for picking up on how this rotating design works, i have looked at it several times, and scratched my head, it is so simple, even a farmer could build it!
(Thanks Boguslaw!)
@ Hanon, Have read whole thread now,Thanks for all your hard work on this. i will have a go, under UFO's design guidance, at replicating the rotating generator, when i have finished my MAG3 build, on UFO's asymmetric thread. I think i can see what UFO is seeing in this design.
Regards Cornboy.
This Farmer would have no trouble building it since I'm actually a boilermaker
by trade the construction of metallic structures is a piece of cake for me if I
so choose.
How about you CornBoy, do you have an engineering type trade certificate ?
Or are you just a Farmer. Neither is better than the other just curious,
farmers are generally very industrious and know how to make things work.
However I decline because I don't believe it can produce any free energy.
However I am eagerly awaiting UFO's "Over Unity" results when or if he ever
posts them. Considering several others have already tried it and none have
shown OU as yet as far as I know it would be good if UFO uses his skills to
build one and show us how it's done.
I for one hope it does produce thousands of Watts of extra energy, because if
it does it will change the world, and lot's of scientist type people will have to
explain why they did not already know of the possibility. But without showing
any extra energy it won't change much at all.
I wish UFO well with his build. And it won't make any difference to the result
no matter what I say. Even though some would have us think that people can
prevent devices from working by having an opinion on if the device can work
or not.
With UFO's Knowledge and skills he ought to be able to setup a device and
demonstrate some OU in under a month. I'll wait three years before I call bunk
should be plenty of time. No need to wish good luck, so I'll just say work well.
Jack of all.
Originally posted by Farmhand View PostThis Farmer would have no trouble building it since I'm actually a boilermaker
so choose.
or not.
Hello Farmhand, yes i farm for a living, and i sure could use a farmhand at the moment to help plant Garlic.
Once it is all in the ground, i can get back to my interpretation/ build, of UFO's MAG3 design.
I have several Trades, originally, Fitting/machining, then Motorcycle mechanic, then learnt how to build kitchens and staircases in a joinery, and have built a few houses, Jack of all- master of none!
Farming is my passion, and i farm Bio-Dynamically, certified, so vortex enlivenment is a natural everyday thing for me.
I am confident you won't have to wait 3 years.
BTW i have watched a lot of your Videos, you do good work.
Regards Cornboy.
Tesla presented his Egg of Columbus the previous decade at the World's Fair. Coincidence?Originally posted by boguslaw View Post...one single statement of Mr Figuera which explains everything ... the secret of his invention resembles the egg of Columbus. "
OU again?...
Farmhand,Originally posted by Farmhand View PostThis Farmer would have no trouble building it since I'm actually a boilermaker
so choose.
or not.
If I build this, It would not be about getting OU, or Free Energy......Why, everything have to "start" from OU and FE Farmhand?
There is absolutely no reason why this "Apparatus" will not work...
We are no "violating" Faraday's laws...We are "Moving A Conductor through a Magnetic Field..."
All friction/drag in that rotor would be caused by the weight of copper windings, the plastic insulation frame, air friction...bearings, etc...but NOT ANY Magnetic drag....and just not having a magnetic drag from a heavy laminated steel core, is a huge difference, mainly when we set heavier loads on that generator.
But Farmhand, maybe you could help Us all out here...when it comes to the Transformer Applications between Fixed "Primary" Outer Exciter...and Fixed "Secondary" Inner Exciter Core and windings...I know you are excellent on the field of Transformers.
After I lay out the 3D CAD designs you will see the structures better...since the two exciters could be sharing the same frame-core in like a Round "E Type" pattern with hollow center, where the shaft-bearings will mount to..
We need to stop seeing FE or OU as an "Individual Competence or Race" to see who gets there or not...but, to see it in a "Global Team Work"...then, no one could brake us apart...
Together we stand and make it happen...divided we will fall for another 130 years...
UfopoliticsPrinciples for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
"Tesla's device used a toroidal iron core stator on which four coils were wound. The device was powered by a two-phase alternating current source (such as a variable speed alternator) to create the rotating magnetic field."Originally posted by Ein~+ein View PostTesla presented his Egg of Columbus the previous decade at the World's Fair. Coincidence?
Originally posted by UfopoliticsTherefore, what he does is a "Static Simulation" of the same exact changes the conductor faces, by applying a pulsating or sine wave current to the exciting coils
......creating a "Virtual Rotary Pulse"...we could easily apply it here if we independently feed one channel per independent exciter coils
Source: Clemente Figuera patent 30378Last edited by hanon1492; 06-18-2013, 08:45 PM.
Different Patents...
Hello Hanon1492, Boguslaw, Ein~tein,Originally posted by hanon1492 View Post"Tesla's device used a toroidal iron core stator on which four coils were wound. The device was powered by a two-phase alternating current source (such as a variable speed alternator) to create the rotating magnetic field."
There is a big difference between both Patents (Tesla and Figuera)...even though both contain a "virtual rotating field"...
Tesla's Patent (The Egg of Columbus) refers to a Motor...a Machine that converts the AC Rotating Field to Mechanical Energy, by having a metal/steel/copper rotor that a rotary field drags within.
Figuera's Patents relate to a Generator, He uses the rotating field to Induce a Coil between magnetic fields.
Tesla's structure have the Coils generating the rotary field in the Exterior of rotor...While Figuera's have Dual Exciting/Rotating Fields, one Inner, the other located in the Outer Periphery...
Big difference there guys.
A Very Important Part to be Successful...
Hello Guys,
There is a very important "side" to be considered, when it comes to winding the Figuera's Rotating Induced Coils...
There are Two Main Ways to Wind the Induced Fields in any Generator...
[IMG]
[/IMG]
1-The more Typical "Closed Loop Winding", where the Coils create "O" Patterns or closed loops around the core poles...This design have a disadvantage for our purposes, because, once the copper wires gets induced, generate a strong magnetic field, even if there is only "air" as a core...I must remind You all here of the "Core-Less Motors"...where the rotor are just "O" looped coils without steel cores...
2-The Second Type of Induced Fields windings in a Generator are the "~~~" Sine Wave Pattern Winding, where wires NEVER CLOSE into a loop, and I find this type as Much More suitable, since they DO NOT generate a magnetic field once induced....so, zero magnetic drag then, when applying it to Figuera's Generators...
We can find this Pattern #2 in any Automotive Alternator Outer Generating Fields, and normally they have Three Sequences of Windings where the Sine Waves (~) are Overlapped/Interlaced, ending in three robust rectifiers (diodes) to convert the currents to DC....(the other three terminal wires end are joint together.
@Cornboy: I will start first at a smaller scale replication, with permanent magnets at Inner-Outer structures, and Sine Wave Coil Rotor "sandwiched" between rings of magnets...
...this will produce an AC sine-wave that we could rectify with a small bridge rectifier to DC...
Now considering the high torque of Asymmetric Motors....they could easily rotate, even the #1 looped winding style also...so I will build the Two Type Armatures...for Lab Testing purposes.
Regards to all
UfopoliticsLast edited by Ufopolitics; 06-08-2013, 03:42 PM.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Well, well...I think I should keep myself in silence , because I have nothing to say about rotating magnetic field in motor fields...yet I believe both Tesla and Figuera use the concept of "Columbus egg" to show something else....how is that called ? Parallelism ?? Nevermind... but it's interesting correlation
Future.
[IMG]
[/IMG]
Regards to all
Hello all,
@ UFO, You Know me by now, just a few questions,
1. The outer and inner laminated exciter cores would be made from one piece?, ie connected like a normal transformer?
2. What limit do you think would apply to gap between exciters, for coil thickness, meaning what wall thickness could drum be, based on say 200mm dia drum?
These are early , preliminary questions i know, and diagrams speak wonders to me, just like to have it in my head for a while to develop a mental picture, of future build.
Regards Cornboy.
3.
Look what I have found about a replication of this generator :
Blog with a replication
The IC is a VFD (Variable Frequency Drive) from a DC motor (PWM --> pulsed current)
Please share your thoughts about this info
Figueras Exciter Cores...
Hello All, Hello Cornboy555,Originally posted by Cornboy 555 View PostHello all,
Regards Cornboy.
3.
Not one piece, then it must be "solid"...not good, I would conceive it based on steel lamination plates, just like any other Generator...or Transformer Core.
Related to Air Gap, it could be at least around 10 mm or approx 1/2 Inch
Using from 16 to 18 gauge (awg) will be plenty of space for a few sine wave turned Layers.
[IMG]
[/IMG]
There should be some other laminations cut without the "Poles", just like washers or rings from the Outer and Inner Diameters, to raise/elevate poles structure on top and bottom, allowing room for windings, collectors/brushes...and same screw holes....allowing some long bolts to attach all laminates to just one lower Cap containing the lower bearing.
If we were to build it from scratch, I would rather select a Four Poles Machine, just like above picture shown by Hanon1492 on Figuera's Patent...Four Poles requires Half of the speed of a Two Poles...1500 for Europe/Australia/South America...and 1800 for US and Canada...instead of the "Typical" 3000 or 3600 RPM's.
Now, Cornboy, I know You...
...and again, this should be tested before at a small scale model prior to jump into a bigger "usable" prototype.
UfopolitcsLast edited by Ufopolitics; 06-09-2013, 01:05 AM.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
