Tesla Armature Cores...
Nkola Tesla Cores Laminations Design...
[IMG]
[/IMG]
Did You ever found something "different" to the way Nikola Tesla wound/displayed, His Coils in most of Designs, except for the "Toroidal Type" ?
They seem to look like a "Thick Ball" of wires...
Such difference from the way any motor or generator we know...always caught my attention...Then I started to make a Study of How the Laminations or the Structures could look like...as why?...looking for any advantages to the types we use.
[IMG]
[/IMG]
I took some of them into CAD...and came up with the following:
[IMG]
Radial" Wound Coils Geometry...where wires travel from one end to other end of the total Armature Diameter.
We utilize "Axial" Wound Coils in most of all our Electrodynamic Machines...where Coils are wound in the Outer Periphery of the Armature Structure.
[IMG]
[/IMG]
On the above Image...I am just showing (Contoured in Teal Blue)...the Coil that is at "Idling" stage...all its vertical conductors are out of the Stators Field reach...
All this sequences need to be broken down in steps with degrees of rotation, in order to see the result better...or in an Animated 3D CAD Video...
The dragging or counter forces...or Lenz Effect...on this type of winding configuration is much less by far...than a Typical Axial type we all know...plus adding the fact that Tesla utilized all his Coils with Independent or Open Circuits.
And when applied to Motors...the Forces of this Type of Coils are Greater and Stronger... since they project "Face to Face" on straight line...the Interacting Fields with Stators...or, whenever utilized as Induction Machines...the Attraction to the center Rotor or Disc "D" on Tesla's Pancake Motor are much bigger than a typical closed, axial type Symmetrical AC Machine...
Warm Regards and Light to All
[IMG]
[/IMG]Did You ever found something "different" to the way Nikola Tesla wound/displayed, His Coils in most of Designs, except for the "Toroidal Type" ?
[IMG]
[/IMG]I took some of them into CAD...and came up with the following:
[IMG]
Radial" Wound Coils Geometry...where wires travel from one end to other end of the total Armature Diameter.We utilize "Axial" Wound Coils in most of all our Electrodynamic Machines...where Coils are wound in the Outer Periphery of the Armature Structure.
[IMG]
[/IMG]On the above Image...I am just showing (Contoured in Teal Blue)...the Coil that is at "Idling" stage...all its vertical conductors are out of the Stators Field reach...
