Definitively something very bright coming up...
Nikola Tesla discovered the "Benefits" of using "Independent" (Asymmetrical) Energizing Circuits/Coils to be set on BOTH...Motor and Generator...and ONLY through Independent Asymmetries it would be further on possible...to EXCHANGE and utilize COMMON or INTERCONNECTED COILS between Motors and Generators...In order to produce what He called "Progressive Shifting" that would be in favor of rotation of both Machines, creating a very PRECISE SYNCHRONOUS MAGNETIC MOVEMENTS just like MECHANICAL GEARS DO...and NOT the way we all have been taught so far...where our Symmetric Motors would be completely isolated or Independent from Generator Coil Induced Circuits actions...so we have no other recourse than to use the Farting Gas Dinosaurs up to this date...to produce Electrical Power...
So You all would understand better...WHY...Nikola Tesla "Material" was completely VOIDED from ALL Electric Engineering Schools in our Planet...A Global Oil Conspiration?...Nah...
Some words from his Patents (Here are shown His MULTIPLE WAYS to Inter Connect Motor-Generator) to help you "Debunk Tesla"...
Fragments from Patent 381 968 "ELECTROMAGNETIC MOTOR"...
Tesla Patent 381,968 - Electro-Magnetic Motor
"The practical solution of the problem of the electrical conversion and transmission of mechanical energy involves certain requirements which the apparatus and systems heretofore employed have not been capable of fulfilling. Such a solution, primarily, demands a uniformity of speed in the motor irrespective of its load within its normal working limits. On the other hand, it is necessary, to attain a greater economy of conversion that has heretofore existed, to construct cheaper and more reliable and simple apparatus, and, lastly the apparatus must be capable of easy management...
...My present invention is directed to the production and improvement of apparatus capable of more nearly meeting these requirements than those heretofore available, and though I have described various means for the purpose, they involve the same main principles of construction and mode of operation, which may be described as follows: A motor is employed in which there are two or more independent circuits through which alternate currents are passed at proper intervals, in the manner hereinafter described, for the purpose of effecting a progressive shifting
Now, please...read and re-read this sentence very carefully...
"I am aware that the rotation of the armature of a motor wound with two energizing-coils at right angles to each other has been effected by an intermittent shifting of the energizing effect of both coils through which a direct current by means of mechanical devices has been transmitted in alternately-opposite directions; but this method or plan I regard as absolutely impracticable
It would be easy to discern that He is referring to Motors where Coils are Energizing at "right angles to each other"...sounds like Symmetry?...absolutely....and further on He writes..."effected by an intermittent shifting" (understand reversing) of the energizing effect on both coils...through which a Direct Current by "means of Mechanical Devices" (understand DC Symmetric Commutators) has been transmitted in alternately opposite directions...(must refresh here that Symmetry reverses their coils at each quarter or half of revolution...)
Resuming, Nikola Tesla...back in 1888 concludes that..."this method or plan (Read Symmetry) I regard as absolutely impracticable"...
..."for the purpose for which my invention is designed" (His Purpose here is to "Fuse" an Electric Generator with an Electric Motor...)
HIS CLAIMS:
1. The combination, with a motor containing separate or independent circuits on the armature or field-magnet, or both, of an alternating-current generator containing induced circuits connected independently to corresponding circuits in the motor, whereby a rotation of the generator produces a progressive shifting of the poles of the motors, as herein described.
2. In a system for the electrical transmission of power, the combination of a motor provided with two or more independent magnetizing-coils and an alternating-current generator containing induced coils corresponding to the motor-coils, and circuits connecting directly the motor and generator coils in such order that the currents developed by the generator will be passed through the corresponding motor-coils, and thereby produce a progressive shifting of the poles of the motor, as herein set forth.
Machine...Note how Tesla uses a "Toroidal Motor Concept" here...
Now, for purposes of very "Clear Interpretation" of this Patent Application...We understand that the Generator cited here...would be "driving" the Motor by the creation of this "Progressive Shifting"...transmitted through "Independent Circuits" that are "Shared" between BOTH Machines...
Therefore, thinking that this Patent applies "only" to the way Generators should produce an ISOLATED "Shifting Phase Order" (Interpret as not SHARING Circuits/Coils between Motor-Generator) to run a remote Tesla AC Induction Motor is completely absurd.
Now...for those who still have "any doubts"...let me remind you all... that Nikola Tesla was the Inventor and CREATOR of the First AC Poly Phase Generators mounted on Niagara Falls Hydro-Electric...that...for the FIRST TIME illuminated the US Chicago World Fair in 1896 in a Joint Venture with George Westinghouse...before...they were using the dimming and shimmering yellow poor lighting...from Thomas Alva Edison/J P Morgan/GE Rip Off...Pole to Pole Battery powered DC Currents...
Warm Regards and sorry for the long post...but had to write this...
..."for the purpose for which my invention is designed" (His Purpose here is to "Fuse" an Electric Generator with an Electric Motor...)HIS CLAIMS:
, I would consider those results as positive. If you place the two pole drawing over the toroid in the video, the fields are set up as I expected.
so I want to get as much done as I can over the next month or so
