Diodes...
Hey Machine!
Nice set up there...now, you are not running Imperial through the Monster Pulsers?...but, through the Liquid Solenoid circuit , right?
You can run it without diodes, however, commutators will get hot, and amperage will raise...You could use a small but powerful external fan...but amperage will increase when you add loads to Generator Head.
And the thing is, Imperial will increase its Reversed Generated Energy (Radiant) when it is under a mechanical load, and based on this connection, we are using all gates for Input, so there is no way for Machine to "exhaust" that extra energy, through the Generator Gates, reason why amperage raise.
You could try using High Wattage CFL's...not incandescent bulbs, as a load to absorb reversed flow, by connecting the CFL's parallel to Diodes, one for each...then diodes may work cooler...try High Wattage CFL's ...not incandescent bulbs.
However, my Friend...You will need to get Dana's codes...Arduino and Four Monsters...to be fully successful here without "doubts or headaches". Like I wrote in my previews post to you...This is the way to go here, on this Imperial-MeccAlte set up.
Regards and good testing!
, but...shhh don't tell anyone else...
