How can you make a Magnetic Gas?
  • #16
    Originally posted by Duncan View Post
    Hi Geronimo551 thanks for taking the time to watch and digest my offerings, magnetic and electromagnetic separation always a fascinating subject !! particularly when applied to fuel here is a simple demonstration of Ruggero Santilli's operation which I have uploaded even in this simple form it claims to be between 3 and 5 >COP over Faraday
    VTS_03_1.flv - YouTube
    That's a nice and easy setup!
    Great info Duncan.
    He talks about using around 32V
    Anyone know how many amps it takes aprox?
    I like to make a small scale version to play with.
    I designed something similar a few years back, but never built it. It's on the forum here somewhere, here is a pic:
    Here is my little "Sparp plug" version :
    Water under slight pressure comes in Glas tube trough one way valve
    As the water level touches both the electrodes, the gas vorming starts.
    An Underwater spark is formed between the two carbon balls
    Gas forms and is pressed out of the tiny opening at the plug head
    As all the water has turned to gas, the the Tungsten Spark head will become the lowest resistance and sparks the gas.
    This way only one continues voltage needs to be applied. ( In my theory/fantasy at least ;-)
    Around it I have an energizer only connected to one terminal, The pos or the neg, may change i will see, but the energizer coil will only be connected to one terminal.
    I never made it, but it starts to itch again..
    C'man
    • #17
      Plasma
      Is this a plasma gun? or some sort of alien tech?
      • #18
        No no no...
        Just my version of a water filled plasma spark plug. There was a thread a few years back and some guy tried to explain his vision on Stanley Meyer, with his views and my views combined I designed this little plug.
        Nothing special, its almost the same as in Duncans's clip, only a different housing.
        I did think it was to difficult to get a good spark in the water, but after seeing the you-tube from Duncan.. It seems 32V and some amps ?? is all it takes.. no circuit whatsoever..
        So I might try this for my little generator..
        Any suggestions welcome, although maybe not here, do not wanna hijack a thread.
        PS. Plasmagun.. When you think of it.. Put a barrel around it, a bullet in front.. ;-)
        • #19
          • #20
            I have attempted repeated typo correction of above post without effect. I'm done attempting correction. Non-Mission essential. typos do NOT detract from intent. Real-time commo is always 'broken and garbled', hence:
            "The essence of duty is acting in the absence of orders or direction from others, based on an inner sense of what is morally and professionally right...."
            Favorite Unknown U.S. Soldier: Baby Screams for help during an abortion procedure! THIS VIDEO WILL CHANGE YOUR LIFE FOREVER! - YouTube
            That soldier should have the Medal of Honor. Did you see his mother's thighs wiggle as he was fighting to the death ?
            General John A. Wickham Jr.
            • #21
              Good Sirs and possibly Ladies, how is it possible to hi-jack this thread when we all seek answers ?
              What would you build ?
              How come ?
              How ?
              re:
              You can't get any better Over-watch-- the others are all dead, even if you hire Blackwater and Back-Up. If not YOU, who ? If not NOW, when ?
              • #22
                Untitled on Vimeo
                This clip also seems to demonstrate some effects I would not have expected to see
                magnetic vortex on Vimeo
                It does at first glance seem that there are quite large lumps of magnetic theory missing from standard teaching , It would for instance be nice to have this very important theory validated and tested in some way.
                LeeskalninPhysics2.wmv - YouTube
                It was mentioned by John B that in the Cejaka files he had noted water being split by magnetic action alone Indeed here is a short taster clip I have cut out of the film for your inspection in which he roughly explains the principle
                magnet water split.wmv - YouTubeFelix Ehrenhaft: Magnetic Current --- 9 articles
                This post is Rock and Roll. Please articulate exactly WHAT you would BUILD. WHY ? HOW ?
                Smoke on the water - YouTube
                US. "Some stupid with a flag on burned the place to the ground." NYC 911/Twin Towers/Pentagon.
                We have everything save a functional device. Smoke on the water and fire in the sky.
                What do you have ?
                • #23
                  bubble.wmv - YouTubeOpie & Anthony: Stan Meyer's Water Car - YouTubeBob Boyce - YouTubeFleetwood Mac-Go Your Own Way - YouTubeLemon Jelly - Nice Weather for Ducks (Lost Horizons) - YouTube
                  Best wishes Duncan
                  • #24
                    Hi Duncan,
                    Yes validation is important. The guy in this video says his experiment is
                    validation of the existence magnetic particles, I don't see how it does.
                    The experiment in the video to me just shows that when the gas bubbles are
                    formed by electrolysis they don't like to rise straight up, so what I see is they
                    (just like smoke particles) prefer to rise in a spiral. Just the same way water
                    prefers to spiral down a drain pipe.
                    I think the initial direction of the spiraling of the rising gas bubbles may well be
                    affected by the magnetic field of the magnet, but could also be influenced by
                    a slight rotational current in the water simply by a very slight swishing around
                    of the water in the other direction by hand when the magnet is flipped.
                    Even if it did spiral the opposite way by itself it is no big deal, it's just the
                    same as a water down the sink vortex or a smoke plume vortex, truth be
                    known if a strong enough magnetic field with the correct polarity was placed
                    at the drain hole of a sink when some water was drained out the rotation
                    might well be affected as well. Things tend to have a propensity toward
                    stability and a vortex is stable structure. It's a natural thing that can be seen
                    all over the planet with lots of different things.
                    • #25
                      MAGNETIC VORTEX SPIN built by Magnetflipper Sept 2011 (Uploading due to his Channel being taken off) - YouTube
                      • #26
                        These posts are great. I am anxious to build, however seek confirmation of success prior to construction. No research will change the US market place or C.O.T.S. H.F.C. dearth, but it may well enhance the survivability and prosperity of individuals who develop hydrogen fuel cell technology.
                        Domestic enemy US traitors have a self evident agenda:
                        "In total, all states (US) are expected to be about $140 billion short of revenue to cover costs, with five states, California, Texas, New Jersey, New York, and Texas accounting for about half of the $140 billion. Every U.S. household would have to be assessed an additional $1,200 in taxes just to cover the shortfall."
                        Thank you for helping us understand Water as Fuel.
                        • #27
                          I got some good email news. I am away from Internet for many days at a time when sometimes infiltrating a drug distribution & ***** strongpoint for the purpose of helping interdict child mass-murder, human flesh trafficking, and human experimentation associated with Pro Choice Stem Cell harvesting & CO2 = P x S x E x C human genocide agendas. I'm just one average man doing what is easily at-hand AND I do NOT want to MISUSE this volunteer asset below. How may we BEST accomplish the mission with this additional help ?
                          contact@panacea-bocaf.org
                          May 13 (3 days ago)
                          to me, Derek
                          SAR RTO , thanks for contacting us, Dr Derek from HH@.us will be able to
                          advise for this project.
                          Ash (trustee)
                          • #28
                            Duncan, Good Sir. There is no THREAT from private sector or government. The efforts of MagneGas Corporation
                            and that is OK. I seek only to accomplish the mission.
                            • #29
                              Santilli H+H+CO=H2O fundraiser. Mikvah anyone ?
                              Excellent Jacuzzi Beachcomber series 300 model 321
                              Has anyone been in contact with Cliff Ricketts of Middle Tennessee State University ? Cliff reports first hand evidence of Herman Pleasant Anderson's HHO powered automotive applications. Cliff is not responding to email. Has anyone identified political chattel THREAT to suppressed green energy technologies ? Identify these traitors by face, name(s), areas of operations, church congregation membership and post the data Online and kiosk style real-time.
                              Open Source Oxygen Therapy and Gaseous Ozone Intravenous Therapy
                              Open Source Santilli carbon arc rod plasma generated H+H+CO=H2O green fuel project
                              FileSwap.com : Upload Files, Free File Hosting, Cloud Storage
                              Open Source Login Data:
                              Geronimo551@gmail.com
                              Password:
                              13YHWH1Kransberg
                              Current File Availability:
                              Oxygen Therapy Instruction TNS Lo Quality Audio wav demo.zip
                              Aug 09, 2012
                              77.79 MB
                              Solutions ? TNS RADIO - Seeking solutions
                              • #30
                                Tell me the name!
                                VTS_03_1.flv - YouTubeone of the 100 KW units is supplying power to a Swedish airport, Two machines I know of are operational in Greece
                                many of the machines are in use by various US municipality as Santilli explains himself here
                                Alternative fuel Magnegas - YouTubePatent US603058 - ELECTRICAL RETORT - Google PatentsCornish Hydrogen Generator - KeelyNet 01/10/02
                                Let me know and I will track it down for the benefit of mankind!
                                Thanks D
                                "Being myself a remarkably stupid fellow, I have had to unteach myself the difficulties, and now beg to present to my fellow fools the parts that are not hard. Master these thoroughly, and the rest will follow. What one fool can do, another can."
                                Silvanus P. Thompson, F.R.S.
