None Electrolytic Splitting Of H2o
  • Originally posted by superman9976 View Post
    Alex,
    Did you get your heating unit up and running?
    For the E-beam is this the unit that uses radio frequencies or is it something else?
    Chris
    E-beam or MNE-beam and MNSE-beam are a new slant on an old system, go here to read more on this
    centraflow systems, water molecule breaking, RF water splitting, micro fuel from water and air, none hydrolysis of water.
    This is my web site which I will keep up to date as and when I can, I have a lot of problems at the moment and things can be very slow.
    If you look up Sabatier you will see that that part is very old, but I have found a way to bring this tech: into the 21st century and over ten times more effective, so effective that it has as good as 100% convertion rate at low input power by using a novel way of two dielectric barrier discharges to a common anode.
    These discharges are at two different frequencies "part of my old system", so what we have is a very high energy none thermal discharge at a blanket rate giving off heat and ultra violet radiation along with a broad band vibration from the RF developed inside the reactor. This DBD is unique and has not been done before as DBD, even though it has been around for some years now, is still in an area of finding what it can be used for, "your TV is one and material molecular manipulation in manufacturing is another and the oldest is the making of high volume O3 ozone for water purification is another".
    Look these things up and you will see where I have come from to develope this system, it is molecular manipulation, moving electrons into different orbits so as bonds are broken and new bonds made by using directive catalysts such as nickel in the sabatier reactor.
    The RF comes from the frequencies used for the high voltage discharges, and as so the circuit for driving this is very simple apart from adjusting the phase between each discharge. No elaborate RF circuits are required any more, you could say that the RF is similar to the original spark gap transmitter, but in this case it is a none thermal spark gap, it still produces heat, but it will not ignite any combustable gas.
    This system will produce more energy than is consummed but does not break ANY LAWS, the excess energy comes from chemical change. It is so simple that I think that it has just been overlooked.
    One thing now is that this system can now never be patented as I have placed this in the open, it now has a prior art and so not patentable.
    The basic design of this system is for energy storage to be used as and when required "gas tanks" and not an instant production use system, it maybe that it could be used as such one day, but I think a home production unit is more interesting where it can be used for many things all from one plant.
    The energy required could come from solar or wind power and as so make it very cheap.
    Mike
    • Untitled on Vimeo
      There are Three sections to this recording here is another short one concerning the Santilli fracture method as I guess its "Non electrolisis" I'll be cheeky enough to post it here VTS_03_1.flv - YouTube
      there is another long section where Bob Boyce is interviewed but I havent converted it yet
      Best wishes all
      PS here's Bob Boyce Bob Boyce - YouTube
      • Originally posted by Duncan View Post
        Untitled on Vimeo
        There are Three sections to this recording here is another short one concerning the Santilli fracture method as I guess its "Non electrolisis" I'll be cheeky enough to post it here VTS_03_1.mp4 - YouTube
        Best wishes all
        Hi all
        this is a test that Gilbondfac made and i simply replicate it.
        I don't know if that is something to do with Santilli's work, but i used one carbon rod and the lightning in the jar seems to be the same ??
        what do you think what gas is getting out of that ??
        hope this helps
        Good luck at all
        Laurent
        high voltage for splitting water 1 .wmv - YouTube
        • I havent read this whole thread but wanted to add in the metal alloy PY5Me2 into the conversation
          Cheap New Metal Catalyst Can Split Hydrogen Gas From Water at a Fraction of the Cost | Popular Science
          0P3N S0UR(E 3NG1N33R1NG
          • Hi all
            today i better fixed the electrode and i could stabilise the process
            So i made a short video to better show the process.
            If some of you can explain what is going on , or share some thread or link to better understand, i would be very happy.
            Thank's
            Laurent
            high voltage for splitting water part 2.wmv - YouTube
            • chemistry
              Originally posted by woopy View Post
              Hi all
              Thank's
              Laurent
              From what I see in your video is, you are using a carbon electrode and a copper electrode and creating a HV discharge in water. This is going to break the water molecule and also combine both oxygen and hydrogen with carbon from the one electrode "hydrogenation and oxygenation of carbon". Your resulting gases are going to be a big mix of carbon oxides and hydrocarbons.
              In chemistry all reactions have to be controlled if you want just the gas or gases you are looking for.
              Catalysts are used for this as shown above in the other post, also none thermal plasmas are the way to go using other directive catalysts. The combination of both have some very remarkable results.
              Mike
              • Hi Woopy,
                You may wish to research "dissolved gases" as it appears you are setting up a situation that is causing the them to be undissolved which makes the water look cloudy.
                • Hi Mike & Alex
                  Mike
                  Mike and Alex,
                  Life has been very busy lately and haven't had much time to experiment and work on projects. I did look at the website though but didn't get a chance to read your PDF. I have been talking to Russ about what you have going and he found time to read at least some maybe not all of this thread. I believe he will be posting soon. I hope that you guys can help us out with some of the questions we may have. I tried to donate on your site but for some reason its not in English and I cannot switch the paypal page to English. Why is that? There's an English translator on you site I saw that but nothing in paypal. What can be done about this?
                  If you had a chance to look at the site we have the five coil setup wound for testing. Ran a generator on hydrogen just to see how much it takes. Pretty soon should have a VIC worked out. Overall I think much progress is being made. We have a good group of guys willing to help out.
                  Do have plans on visiting this year's energy conference?
                  Chris
                    Mike and Alex,
                    Chris
                    Sorry but can't make the conference this year due to lack of funds. Looking into the paypal a7c, but due to the fact I live in Spain it seems I can't change it to English. The format is the same so you should be able to use it with no problem
                    If you want to contact me you can use the e-mail address on my web site, it is used only for this work centraflow@gmail.com
                    Mike
                    • Gases
                      Creating only HHO for using as a fuel is not a good idea, can be very dangerous and also is not ideal for creating power on it's own, you have to transform this gas for any reasonable chance of making a generator run and not use more energy in than the generator can put out. This is a fact which can't be disputed
                      Mike
                      • Thanks Mike,
                        I will try to donate this friday. I will find paypal in English as an example then. I appreciate your time and what you have done so far. I will also let Russ know about the email.
                        The generator did seem to run just fine but we had two flashback arrestors in line to make it safer. It was actually just a bottle of hydrogen. Russ made up a plate with four ports on it for connecting various gases and vaccuum lines.
                        All these small experiments to see what works and how is really educational. Fun too.
                        Sorry to hear that you wont be coming to the conference. I figured if you were there I would definitely go. I am on the fence about going. I think my resources would be spread to thin. I should focus on what is in progress now.
                        Chris
                        • hello
                          you may find this intresting its high voltage water splitter here
                          most important thing is that production is not related to current flow !!!!
                          cheers from poland
                          wojsciech
                          • mistaken post. Apologies
                            • video
                              I am uploading a video at the moment and it should be on my website in a couple of hours if the powers that be leave me alone to get it loaded.
                              This IS electrolysis, but very efficient, around 185%, but it is not only that, it is producing a hydrocarbon gas from water and CO2.
                              Please note the change in colour to black of one of the electrodes, "this is carbon" produced on the half cycle and on the other half cycle combined with hydrogen to give a hydrocarbon.
                              SMD as I call it will be coming available in the near future, and yes for a price, I need money to keep me alive and to fund e-beam.
                              enjoy
                              Mike
                              • Originally posted by Michael John Nunnerley View Post
                                enjoy
                                Mike
                                Thank you for the update Mike. Looking forward to seeing your video.
                                Where will the video be located on your website?
                                You website:
                                http://www.centraflow.yolasite.com/about-us.php
                                Also, your Paypal Donation link did not work for me here in USA. It just times out in error, no connection established. What is your Paypal email link so USA folks can send you donations directly by Paypal?
                                Mike
