Originally posted by Farrah Day
YouTube - cap_experiments_.avi
A few weeks ago, I experimented with two aluminum tubes with the inner tube a diameter of about 3 cm and a spacing of about 1 mm between the tubes. With these, I could easily produce gas feeding the centre tube with spikes using a solid state Bedini coil (using the secondary of a 12V transformer for halogen lamps as coil). I could also produce gas when I put a separate tube of about 1 cm diameter inside those two tubes and feed that with spikes. With that, gas would also still be produced in between the outer two tubes, while only the outer tube was connected to the positive of the battery (which really is the negative with respect to the spike, as is usually done with the Bedini schoolgirl schematic).
What happened is that the water gets blurry with white flocks after a while, which are most likely aluminum oxide. At this moment, this setup does not produce any gas anymore, probably because a lot of ions have dissolved in the water.
However, it turns out that two kinds of dielectric films can be made on aluminum, as I posted here: http://www.energeticforum.com/renewa...tml#post107606. The stuff I have in my water definately classifies as "a rather gelatinous nature" as mentioned in the book linked there.
Given the results of my experiments as shown on YouTube, I will try and see what happens if I clean the tube setup, add new demineralised water and soda so that the other, desired, type of dielectric film is formed. I will probably have to create the film with soda and try to produce gas with a new bath of water, but we'll see what happens when I find the time to do it. If the forming of the film goes the way I intend it to, I may be able to use tapwater after the film has become stable. Furthermore, my parents in law have some kind of filter that gets at least the calcium carborate out of the water. That may be worth a try, too.
Today I experimented a bit with a simple plastic bottle wrapped with aluminum tape and a single centre tube with a diameter of about 1 cm. With that I could produce no gas. Not with my solid state Bedini and not with a car ignition coil. However, the ignition coil did produce high voltage, but not spikes and the Bedini coil did produce spikes but not of a high voltage. It may still be that a Bedini coil with more muscles does work. As always, absence of evidence is not the same as evidence of absence...
